Re: "hate this piston design" [Re: slantzilla] #3206297
01/19/24 06:18 PM
01/19/24 06:18 PM
West Palm Beach, Florida
Craig J Offline OP
Craig J  Offline OP
Originally Posted by slantzilla
What is the purpose of those grooves?
I have heard them referred to as anti-detonation grooves however, I do not know if that’s correct
Re: "hate this piston design" [Re: slantzilla] #3206298
01/19/24 06:18 PM
01/19/24 06:18 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Quote
Contact Reduction Grooves
These grooves are machined into the top ring land above the top ring to minimize contact drag when the piston rocks over upon reversal. They add minimal volume to the crevice volume, and they also help resist detonation by disrupting flame travel into the crevice volume where pressure spikes might unseat the ring.
Re: "hate this piston design" [Re: fast68plymouth] #3206311
01/19/24 07:15 PM
01/19/24 07:15 PM
AndyF Offline
AndyF  Offline
The grooves are a good idea, but it looks like the top groove was too high. Maybe a design error, maybe a machining error. I don't really know without seeing them. Sometimes pictures don't show everything.
Re: "hate this piston design" [Re: AndyF] #3206386
01/19/24 11:28 PM
01/19/24 11:28 PM
Craig J Offline OP
Craig J  Offline OP
I believe the pistons I have are just an older version of this one from 440source. This discussion now has me a bit curious....I am certainly not a professional engine builder, and have never had an engine assembled in my garage on a dyno. Due to covid parts shortages I have a not very good combination in my car: 440 +0.032 (yes...32 over) with very old style L2295F30 TRW pistons, LY rods, 75 cc Performer RPM heads, a Hughes "real 6 pack" cam, performer 440 intake (fits under a flat e body hood) and iron hp manifolds. It has sky high cranking compression, but I think it would probably be safe on an engine dyno up to 6000 rpm with 112 octane fuel and conservative timing.
If I can find a dyno around West Palm that would put up with my nonsense it would be amusing to make 3 pulls with this not so great ~12.1:1 440, then go home and put the same heads, intake, carb, exhaust manifolds, and cam onto this ~9.8:1 CR 493 with the 'hate' pistons and run it again on the same dyno to compare the results... does ~10% increase in displacement overcome ~20% lower static static compression ratio?
Re: "hate this piston design" [Re: Craig J] #3206409
01/20/24 01:38 AM
01/20/24 01:38 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Thank you.
Re: "hate this piston design" [Re: fast68plymouth] #3206410
01/20/24 01:39 AM
01/20/24 01:39 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Quote
Thank you too.
Re: "hate this piston design" [Re: Craig J] #3206444
01/20/24 10:00 AM
01/20/24 10:00 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
Cranking compression would probably still be up there with the same cam I bet.
Re: "hate this piston design" [Re: B1MAXX] #3206730
01/21/24 04:21 AM
01/21/24 04:21 AM
Washington
madscientist Offline
Washington
I called Icon about these pistons several years ago. For use with open chamber heads you can run the pad proud of the deck. On closed chamber heads you run them to zero deck.
They reduced the outer band as a way to increase piston volume while keeping the dish reasonably shallow.
That’s all it is.
Re: "hate this piston design" [Re: madscientist] #3206944
01/21/24 06:05 PM
01/21/24 06:05 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
i use an icon 836 with edelbrock 84cc heads that has the same basic design. i have good quench distance with a felpro gasket, compression is what i want for pump gas, and i'd buy another set if need be.
