69 hurst four speed console shifters?? #320618
05/17/09 05:56 PM
05/17/09 05:56 PM
MOORESVILLE NC
69four46 Offline OP
69four46  Offline OP
MOORESVILLE NC
Can anyone tell me if the 69 road runner hurst b body console only shifter would be the same as a 69 dart a body hurst console only shifter?? Thanks
Re: 69 hurst four speed console shifters?? [Re: 69four46] #320619
05/17/09 07:06 PM
05/17/09 07:06 PM
S.E. Florida, USA
rrunner Offline
rrunner  Offline
S.E. Florida, USA
No, They are not the same
Re: 69 hurst four speed console shifters?? [Re: rrunner] #320620
05/17/09 09:48 PM
05/17/09 09:48 PM
MOORESVILLE NC
69four46 Offline OP
69four46  Offline OP
MOORESVILLE NC
Can you explain the differnce? I am looking at one to buy and the seller is not shure of what type of car it came out of. THANKS
Re: 69 hurst four speed console shifters?? [Re: 69four46] #320621
05/17/09 10:21 PM
05/17/09 10:21 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
If you look at the flat stock at the base of the shifter handle .....
A-body - up out of shifter, 90* bend to the left, flat stock is cut to position HURST "lever" forward 45*
B-body - up out of shifter, 90* bend to the left, flat stock is parallel to dash to position HURST "lever".
Which are you looking for?
Re: 69 hurst four speed console shifters?? [Re: 6bblgt] #320622
05/17/09 11:47 PM
05/17/09 11:47 PM
Las Vegas, NV
6bblgt Offline
6bblgt  Offline
Las Vegas, NV
Here's a b-body HURST shifter-lever-handle ......
Re: 69 hurst four speed console shifters?? [Re: 6bblgt] #320623
05/18/09 08:35 AM
05/18/09 08:35 AM
MOORESVILLE NC
69four46 Offline OP
69four46  Offline OP
MOORESVILLE NC
I am looking for a b body shifter, any idea of what typ of price range they should be in?? I know they are SUPER HARD to find. Thanks for all your help
Re: 69 hurst four speed console shifters?? [Re: 69four46] #320624
05/18/09 11:08 AM
05/18/09 11:08 AM
North Carolina, USA
Silverbullet2 Offline
North Carolina, USA
Check with brewerperformance. Four speed experts and super nice guys!
Re: 69 hurst four speed console shifters?? [Re: Silverbullet2] #320625
05/18/09 01:43 PM
05/18/09 01:43 PM
Ohio
64dodge572 Offline
64dodge572  Offline
Ohio
Brewers Performance Inc.
4-speed transmission and parts specialists
PH 937-947-4416 or 937-698-4259
FAX 937-947-4419
www.brewersperformance.com
Re: 69 hurst four speed console shifters?? [Re: 64dodge572] #320626
05/18/09 04:45 PM
05/18/09 04:45 PM
SE PA.
Q
QuickBpBp Offline
QuickBpBp  Offline
Q
SE PA.
Does that repo shifter say HURST I am guessing not?????? Thanks...
Re: 69 hurst four speed console shifters?? [Re: QuickBpBp] #320627
05/18/09 04:50 PM
05/18/09 04:50 PM
At a gas station near you
badblack68 Offline
badblack68  Offline
Check with Tony at Tonysparts.com. He usually has a few originals in stock and may also have a like new re-chromed one. The last time I checked his price for that handle was pretty resonable.
