2008 1500 4x4 problem #3203962
01/12/24 12:47 AM
01/12/24 12:47 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
The weather here has just last few days turned to s.h........
I put my 1500 into 4x4 .. light went right on in dash, appeared to be working properly,, drove 22 miles to work thru a fair amount of snow all the way 3-7 inches most of the way
went to go home, honestly. I thought it was engaged .. stopped at stop sign and then , it spun .. clicked it over to lock , it again the light went right on , I though once again it was all engaged
got about 7 miles down the road, lit a light in dash "service 4x4" .. I got to home and thought I'd find a spot to fool with it and it was in 2wd
today stopped got actuator for front, put it on .. heard what I thought ws it engaging went for test drive ,no the lights in dash blink a few times and go out .. and it still does not work
looked for a you tube video to match the problem and googled it but, haven't found the answer.
any ideas ?
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
Re: 2008 1500 4x4 problem [Re: bigdad] #3204110
01/12/24 03:41 PM
01/12/24 03:41 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
Lots can [censored] the system. Need to get the codes read. Sometimes you can fool it. With the engine off put it in 4wd. Then start it and see what it does. 4wd most likely will work. I know on mine when an ABS sensor was acting up the 4wd would not engage. Doing as I suggested by tricking the system would allow mine to work. Replaced the RR ABS sensor and that fixed the problem. Did the same when the LR sensor went out but I did not know how to trick it back then. Toyota guy told me on his Toyota thats what he would do. Worked on my Dodge to as well as the wifes Jeep.
Re: 2008 1500 4x4 problem [Re: NITROUSN] #3204178
01/12/24 07:49 PM
01/12/24 07:49 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
I will try that Pete , thanks
Re: 2008 1500 4x4 problem [Re: bigdad] #3204786
01/14/24 08:24 PM
01/14/24 08:24 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
So, tried that .. didn't work but ..
It is really cold here so I decided to take it for a local warm up drive around to see how many roads were clear ( not many , lol ) ..
1st thing, after a fair amount of driving the temp gauge looked like it was getting hot ?? it was blowing cold so .. I turned around and revved the engine couple times .. something then opened up and instant heat ?
well that's odd ?
I put it in neutral tried 4x4 again .. nope ..
drove a little more, stopped , put it in neutral again .. nope , backed up about 100 ft .. tried it, instant light lit and is the 4x4 working in auto ? Kinda seems like it but , I haven't owned a 4x4 pickup since 1998
lived south for all those years and when I came back 2 AWD cars .. when I tried a u turn , it did fight , like it was in 4x4 .. but, slick road , step on it .. it for sure spun rear tire but, it does get moving like front assist
so I will see tomorrow what happens
Re: 2008 1500 4x4 problem [Re: bigdad] #3204913
01/15/24 11:19 AM
01/15/24 11:19 AM
N
N
There is an actuator on the front axle that could have an issue. It is electric so possibly from lack of use it might of stuck. Get it on flat ground so there is not load on the driveline and shift it in and out of 4wd a dozen times. When was the last time you used it?
Re: 2008 1500 4x4 problem [Re: NITROUSN] #3205097
01/15/24 11:48 PM
01/15/24 11:48 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
Couple times last year , I changed that actuator out
Re: 2008 1500 4x4 problem [Re: bigdad] #3205694
01/17/24 05:20 PM
01/17/24 05:20 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
crazy thing , i took it out of 4x4 auto .. cause roads here are almost dry, now won't engage ..
Re: 2008 1500 4x4 problem [Re: bigdad] #3205779
01/17/24 10:12 PM
01/17/24 10:12 PM
N
N
You are going to have to jack it up and see if the transfer case is going into 4wd. Then see if the front actuator is locking. As far as I know the light is controlled off the actuator. I know my 2002 and 2015 are.
Re: 2008 1500 4x4 problem [Re: NITROUSN] #3205886
01/18/24 01:51 PM
01/18/24 01:51 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
scanner says
Re: 2008 1500 4x4 problem [Re: bigdad] #3205914
01/18/24 03:14 PM
01/18/24 03:14 PM
N
N
It sounds like the transfer case shift motor is bad. Beware if its like the AWD Gm transfer cases the problem can be in the transfer case and not the shift encoder motor. When its in the AWD mode any slippage the system tries to apply the front wheels for traction. This wears things out in the transfer case. When this happens the range of movement in the transfer case goes beyond limits and causes an error. Seen this in lots of GM vehicles. Dodge uses a different model transfer case but I am pretty sure the internals and electronics function the same. I can't help you much more at this point unless I start to lie.
Re: 2008 1500 4x4 problem [Re: NITROUSN] #3206084
01/19/24 02:29 AM
01/19/24 02:29 AM
5thAve Offline
5thAve  Offline
Could it be a bad connector or wire somewhere? It almost looks like that from the codes. On GMs the switches can also cause problems but don't know if that's an issue with Dodge too. My Ram is manual 4x4.
You shouldn't have to go into neutral to engage high.
Re: 2008 1500 4x4 problem [Re: 5thAve] #3206118
01/19/24 09:12 AM
01/19/24 09:12 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
It is really acting up, doesn't do exact same thing twice it seems ..
Re: 2008 1500 4x4 problem [Re: bigdad] #3206399
01/20/24 12:03 AM
01/20/24 12:03 AM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
and this afternoon , it decided to engage again .. ?? lol
Re: 2008 1500 4x4 problem [Re: bigdad] #3206535
01/20/24 03:19 PM
01/20/24 03:19 PM
moparx Offline
moparx  Offline
as i know absolutely nothing about this system, i would start at the switch, remove it, then go over it with a fine tooth comb to see if there may be a problem with it.
then, remove the entire wiring harness associated with this, and repeat, paying special attention to the connectors for cracks, pin "push outs", and any other defects such as hard, brittle, burnt, or frayed wires.
next on the list would be any vacuum lines if any are used.
then finally, pull the actuator from the front axle and inspect carefully for anything amiss, then make it work without it being attached to watch it's action.
and of course check anything else in that system i may have missed, such as relays, the relay holders, etc.
there is definitely SOMETHING going on, you just have to FIND it.
beer
Re: 2008 1500 4x4 problem [Re: moparx] #3206601
01/20/24 06:23 PM
01/20/24 06:23 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
If you can get a wiring diagram for the electrical part of the system, I would suspect any factory splices where several wires are connected together. Mopar doesn't have a good history with factory wiring splices, especially ones located where they might be subjected to the elements or high vibration.
Chasing that stuff sucks.
Re: 2008 1500 4x4 problem [Re: poorboy] #3206867
01/21/24 02:34 PM
01/21/24 02:34 PM
moparx Offline
moparx  Offline
Originally Posted by poorboy
If you can get a wiring diagram for the electrical part of the system, I would suspect any factory splices where several wires are connected together. Chasing that stuff sucks.
especially intermittent problems, and you are correct about the factory splices.
which is why i do not have hair on the top of my head. panic laugh2
beer
Re: 2008 1500 4x4 problem [Re: moparx] #3207749
01/24/24 10:20 AM
01/24/24 10:20 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
I had an 08 1500 4x4 and had similar problems. Mine ended up being a bad TIPM. I took it to the dealer and they put a shift motor in it, that lasted a day. I took it back and they warrantied the part and it failed again. They warrantied that part and put a TIPM on it and it was good to go and by then the weather had returned to normal lol. Mine had the auto 4wd function which seemed kind of rare for a mid optioned truck, I really liked that feature though it worked awesome.
68 Barracuda Formula S 340
Re: 2008 1500 4x4 problem [Re: Bad340fish] #3208085
01/25/24 01:11 PM
01/25/24 01:11 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
It went into 4x4 last week, won't now come out .. lol, took it to a guy good at fixing electrical issues
Re: 2008 1500 4x4 problem [Re: bigdad] #3208100
01/25/24 01:49 PM
01/25/24 01:49 PM
Middle of A Field
O
OrangeProwler Offline
O
Middle of A Field
Keep us update. If I remember correctly these trucks and Dakotas had a problem with the 4x4 switch in the dash but, if I remember correctly I think a common failure point was the actuator in these with the electronic 4x4.
Re: 2008 1500 4x4 problem [Re: OrangeProwler] #3208135
01/25/24 05:04 PM
01/25/24 05:04 PM
S.E. South Dakota !
bigdad Offline OP
Still Posting A Lot
bigdad  Offline OP
Still Posting A Lot
S.E. South Dakota !
it seems to do opposite of what I want, dumb thing.
hopefully he finds the issue before our next snow storm
