Strange key fob issue #3205845
01/18/24 11:26 AM
01/18/24 11:26 AM
Ct
W
Wirenut Offline OP
Wirenut  Offline OP
W
Ct
Have a 2020 Challenger. Push button start . Ran the key fob through the wash. Dried it out (6 months ago now) and changed the battery , now if I lock the car , then next time I’m within 10-20’ of the car with the fob the right tail light flashes and the driver door unlocks. Sometimes it will do it when I’m walking away after locking it . So I figured ok I screwed up and the fob is somehow permanently damaged.
Here’s where it gets strange .
I also have a 2014 Ram . Key fob goes in the dash to start it . Out of the blue it starts doing the same thing as the Challenger.
Changed the battery , still does it .
Should mention I’m not pushing any buttons. Just happens on its own.
Any ideas?
Re: Strange key fob issue [Re: Wirenut] #3205854
01/18/24 12:08 PM
01/18/24 12:08 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My 2012 Challenger key fob acts up once in a while also. Mine pops my trunk as I slide my hand under the door handle as the car unlocks. I close the trunk and it will pop right open again. I smack the fob a few times and it may go away for a day or more or sometimes weeks, but comes back eventually. I think at times the fob get compressed in my pockets which is somehow keeping the trunk button pushed slightly.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Strange key fob issue [Re: 6PKRTSE] #3206113
01/19/24 09:04 AM
01/19/24 09:04 AM
VA
dragon slayer Offline
VA
So take it apart as if changing battery and look at the rubber assembly with the push buttons. There are thin concave disk that are glued in place under each button. They activate the circuits on the pcb when button pressed down. I have a 2012, that the glue broke free and the disk slide into different spot causing erratic operation of the fob. Including popping trunk and killing battery, even multi cycling as if trying remote start when key fob in range. You need a good 3M rubber cement to glue them back in place. Fixed my fob.
