Re: Hello Mopar friends!
[Re: scannman70]
#3205893
01/18/24 02:16 PM
01/18/24 02:16 PM
Posts: 19,405 north of coder
moparx
glad to hear the both of you are getting better ! i had no idea the both of you got busted up. thoughts and prayers for a complete recovery !
[Re: scratchnfotraction]
#3206050
01/18/24 10:34 PM
01/18/24 10:34 PM
Posts: 8,485 Candler,NC / Myrtle Beach, SC
JDMopar
Man....I thought about you the other day! I was digging around looking for something in the garage, and found those truck wheel center caps I got from you a few years back. Still ain't used em!! I'm about ready to stick the 5.9 Magnum into that 88 D100, along with a 518, a truck 8 3/4 with 3.91's and a pair of 5.5 bolt pattern axles I picked up from a guy on FABO. Hope your getting better everyday, and good to see you back.
[Re: JD340]
#3209222
01/30/24 02:43 PM
01/30/24 02:43 PM
Posts: 5,319 Land 'O Lakes
RoadRunnerLuva
Land 'O Lakes
Good to hear from you! Glad you are doing better! Keeping busy is good medicine IMO. The Jeep sounds like a lot of fun 😊 Good luck to you and your wife!
Plymouth Makes It!
[Re: RoadRunnerLuva]
#3209641
01/31/24 08:33 PM
01/31/24 08:33 PM
Posts: 15,866 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
That sounds like a cool build Mike! Glad to see you healing!!!
Two demerits for being missing so long!
Facts are stubborn things.
#3209775
02/01/24 02:10 PM
02/01/24 02:10 PM
Posts: 16,146 Mesa, Arizona
dart4forte
Mesa, Arizona
Hi All,
been a little while since I have been on line here. I am doing much better with the leg, wound is healed up and i am walking on it now.. I use a cane and I still have post op swelling after I am up and doing a lot of walking/standing on it. have not worn shoes in over a yr now. cant bend ankle with the 9 screws down low. the 9 screws and L-shaped metal plate 8" below knee cap lets me get about 80% knee bending . I can lift whole leg ok and Must Be Getting Better as I walk off and have to go back looking for my cane. LOL!
Road the Harley for the first time after 11 months of recovery, Have rode a few short rides... made me a heel-toe shifter and added floorboards but feels weird with one boot and a compression sock. this week I have found a pair of the cheap slip on shoes to start with.
been rocking the 97 wrangler TJ 4 cyl 5 speed getting back into 4x4s gone through it and have it scratching very well. here what I have done to it since Feb.23
4" lift
long arm kit
rebuilt the D30/D35 with 4.56 gears - true trac lockers front & rear CV front axles/alloy rear axles rebuilt the 231 xfer extreme short shaft SYE kit 2-low kit for 2-hi 4-hi N 4lo 2lo add 6 gear planetary 1.25 chain/gear upgrade cv joint long slip drive shafts front & rear 10x15 rims 33x12.50x15 TSL BOGGERS badlands 12000LBS winch added a SS long tube header/4" round Magnaflow muffer/tail pipe all 2.5 ID pipe new rear oil seal/ clutch/PP/TOB complete hydro clutch system timing chain/gears
now I can say it scratches to my liking..
started a 4.0 to 4.7 stroker 6cyl engine (why I don't know)
4.0 block .030 over bore 4.2 crank/rods .030 4.0 pistons slight machine work for 9.2 comp ratio
far as I got on it so far.
still looking for a B-body 883 4 speed to go behind my 328LA roller cam engine I have had ready a couple yrs now.
well that catches me up for the most part skipping a lot of the boring life stuff.
my wife is still hanging in there and I am truly blessed to still have her around 8 yrs later. she is getting tired and stays sick a lot more with a lot of days in bed but does have good days up and moving around with the paw paw & maw maw school bus service the last yr..... man! grand baby is 6 yrs already..
ok I will let yall chime in a little now
scratchin What happened with the leg?
Abe Lincoln
