Re: Lowering an '85 pickup...... [Re: TooMany62s] #3199967
12/25/23 01:46 PM
12/25/23 01:46 PM
Alberta
440_Offroader Offline
Alberta
Ok, I'll put in my twocents. I really think the proportions have to look right. Having a truck dropped right to the ground, makes the cab look too tall. With a long bed, it makes it look worse. It goes the other way as well. Having a Ramcharger with a 12" lift looks too tall with its short wheel base - looks like it'll summersault on a hard braking situation. I like TooMany62s truck, just the right amount of drop, cab doesn't look out of proportion, and I like his wheels too!
Just my opinion, and I don't want to offend anyone who's truck is outside my preference. XmasTruck
Re: Lowering an '85 pickup...... [Re: TooMany62s] #3200171
12/26/23 10:15 PM
12/26/23 10:15 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by TooMany62s
I used dropped lower control arms and flipped the springs on the rear to lower my '84.
Sharp looking truck ... and the wheels are NOT FUGLY
Re: Lowering an '85 pickup...... [Re: JohnRR] #3200269
12/27/23 02:22 PM
12/27/23 02:22 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
I had a lowered 91 back in 2003/2005 era. It was not done correctly and I was always looking for new posts by Cheeto to update up on the best ways to lower the trucks, before they had any aftermarket support.
Cheeto had a killer truck with little alien heads or something similar incorporated into the flamed pinstripes.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Lowering an '85 pickup...... [Re: JDMopar] #3203841
01/11/24 04:13 PM
01/11/24 04:13 PM
poplar bluff mo.
toplescuda Offline
I Whine
toplescuda  Offline
I Whine
poplar bluff mo.
Originally Posted by JDMopar
That's the best way to lower a Dodge truck of that era. I like short beds lowered, but not long beds. If I were to do one for myself, I would use a C or E body 8 3/4 on top of the springs as it's a bolt in and I have several, and I would change the front rotors to 4 1/2 in bolt pattern so I could use Year One 17" Rallye Wheels.
a ebody rear is not a bolt in
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Lowering an '85 pickup...... [Re: toplescuda] #3204036
01/12/24 11:58 AM
01/12/24 11:58 AM
Candler,NC / Myrtle Beach, SC
JDMopar Offline
JDMopar  Offline
Well..... with a Wal Mart socket set, no it ain't! I shouldn't have assumed that the vast majority of folks that would attempt it would know that you need to move the spring perches in to the proper width after you take the center pin out of the leaf springs and flip it over to be on the top of the springs instead of the bottom. There's a lot of wiggle room in the rear wheel well area of the D series trucks and C or E body 8 3/4's fit great.
Re: Lowering an '85 pickup...... [Re: JDMopar] #3204809
01/14/24 09:40 PM
01/14/24 09:40 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Best way to lower one of those trucks? DON'T!!!!!
Re: Lowering an '85 pickup...... [Re: volaredon] #3205746
01/17/24 08:08 PM
01/17/24 08:08 PM
scratchnfotraction Offline
well..on my 88-440/727/8 3/4 d-100 swb truck I used a rear shackle flip... then flopped axle on top of springs... tubed the bed...bolted in a A-body 8 3/4...added a set of 15x12 - 4.5 BS rims & M/T 29x15x15 SR radials...then used a 11" stock front coil spring with a 235/75/15 on a 7" rim 4.5 BS so the swaybar clears a parking stop by a 1/4"
IMHO this gives the best handling, stance, traction for a street truck.
looks same as tomany62 but yellow/black paint.
still scratchinfotraction with it since 2010
hey TM62 hit me up I have a few old wire harness for trucks.
FYI..A body 8 3/4 bolts in on the truck 43" centers & tucks a 12" rim with 29x15x15 M/T bed tubbed flush o frame rails 1.5 stock tubs
my 85 step side runs a 67 C-body 8 3/4 relocated perches tucks a 10x15 4.5bs rim 275/60/15 tire real nice...mine is tubbed but do think it fits without tub work.
mid 90 jeep/mopar 8 1/4 axle have 43" perch centers and are real close to A-body measurements & add gear choices. I just scored a jeep 8 1/4 with 3.73 gears and one with a 4.10 gear
Re: Lowering an '85 pickup...... [Re: scratchnfotraction] #3205747
01/17/24 08:13 PM
01/17/24 08:13 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
It's about time you returned!!!! grin
Facts are stubborn things.
Re: Lowering an '85 pickup...... [Re: larrymopar360] #3205750
01/17/24 08:23 PM
01/17/24 08:23 PM
LOL! hi Larry... now if I could only post pics....
Re: Lowering an '85 pickup...... [Re: scratchnfotraction] #3205753
01/17/24 08:27 PM
01/17/24 08:27 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Are you all healed up Mike? scope
Re: Lowering an '85 pickup...... [Re: Hugh Jorgan] #3205755
01/17/24 08:30 PM
01/17/24 08:30 PM
I will start a post so not to muck this one up on pleasantry's with no good info.
Re: Lowering an '85 pickup...... [Re: hp383] #3216522
02/27/24 03:58 AM
02/27/24 03:58 AM
ID/MT
Cheeto Offline
Cheeto  Offline
ID/MT
Thank you. I still have it. In fact I actually visited it in it's "storage hell" a couple weeks ago. frown
The flames and skulls are airbrushed though not pinstripes.
Cheeto
It's not perfect.
It's not correct.
It's not yours!
