Need front sway bar frame brackets #3204275
01/13/24 09:55 AM
01/13/24 09:55 AM
poplar bluff mo.
toplescuda Offline OP
I Whine
I Whine
poplar bluff mo.
I didn't see a sub page to post this in....
I need a pair of the brackets that bolt to the frame rails that hold the front bushings up (sway bar bushings)
Need to be from a 80s up to at least 1990 dodge truck ramcharger (d100/d150)2 wheel drive NOT 4x4 as they are totally different
Thank you
1970 barracuda convert. 1 of 59
1970 pro street A.A.R. clone (panther pink)
1971 charger
2015 hellcat challenger. Redline red
2014 quad cab 4x4 ram 8 speed hemi
Re: Need front sway bar frame brackets [Re: toplescuda] #3204277
01/13/24 10:01 AM
01/13/24 10:01 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Iirc they're nothing fancy, could be made from channel though I believe OEM were Z shaped.
Angry white pureblood male
Re: Need front sway bar frame brackets [Re: ruderunner] #3204523
01/14/24 09:12 AM
01/14/24 09:12 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
Yes they are nothen fancy. At the moment I have no way of fab any of them
1971 charger
Re: Need front sway bar frame brackets [Re: toplescuda] #3204543
01/14/24 11:11 AM
01/14/24 11:11 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Thank you
I think I have a couple in my suspension box.
Abe Lincoln
Re: Need front sway bar frame brackets [Re: dart4forte] #3204894
01/15/24 05:43 AM
01/15/24 05:43 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
That would be awsome if you did.
Let me know please
1971 charger
Re: Need front sway bar frame brackets [Re: toplescuda] #3205330
01/16/24 06:47 PM
01/16/24 06:47 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Sorry, got waylaid, I’ll check tomorrow. Just to be clear, you need the two front brackets?
Abe Lincoln
Re: Need front sway bar frame brackets [Re: toplescuda] #3205331
01/16/24 07:00 PM
01/16/24 07:00 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Let me know please
Ran out to the shop, I have a PST packaged brackets and bushings
Abe Lincoln
Re: Need front sway bar frame brackets [Re: dart4forte] #3205340
01/16/24 07:24 PM
01/16/24 07:24 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Let me know please
He needs the z brackets.
Re: Need front sway bar frame brackets [Re: NITROUSN] #3206280
01/19/24 05:32 PM
01/19/24 05:32 PM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I think I located a pair. Will know f9r sure this weekend. Thanks guys
1971 charger
Re: Need front sway bar frame brackets [Re: toplescuda] #3208812
01/28/24 03:54 PM
01/28/24 03:54 PM
USA
Hooligan Offline
Hooligan  Offline
USA
If all else fails. I had a1974 D100 without the factory front sway bar. I'm not sure what year trucks have the same frames. Well, I wanted a larger diameter anyway. I bought a 1.125" bar from a '72 Chevy C10. It came with mounting brackets, which I bolted right to the bottom of the frame rails.
Looked way better than the factory bar hanging down bellow the strut rods. Dilled holes in the lower control arms for the supplied 90 degree brackets. Just had to grind a little clearance on the lower control arms for the end link bolts.
Re: Need front sway bar frame brackets [Re: Hooligan] #3208942
01/29/24 01:44 AM
01/29/24 01:44 AM
poplar bluff mo.
I Whine
I Whine
poplar bluff mo.
I have found some brackets. Thanks every one
1971 charger
