Re: Whats the latest on annular boosters in 4150's
[Re: mopar dave]
#3205254
01/16/24 01:16 PM
01/16/24 01:16 PM
Posts: 1,142 Loudoun County, VA
Brad_Haak
Loudoun County, VA
Just my OPINION based on my personal experiences, but... I think 4150s with down leg boosters will be easier to tune for that combination. FWIW, I'll be trying out a couple of different 4150 annular carbs in the future to see if I can get them to run as clean on the street and still perform well on the track as my "go to" 4150 down leg carb(s).
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
[Re: Brad_Haak]
#3205263
01/16/24 01:36 PM
01/16/24 01:36 PM
Posts: 9,847 MI, usa
dvw
MI, usa
My racecar runs 24 hole annulars built by Lightning Racing carbs. Since I footbrake with a large plenum intake (Indy 440-25) they were suggested. The 60 ft be much more consistant. I've been very happy with them. Mark is great to work with. It's actually had 2 different pairs of main bodies. NMCA wouldn't allow me to run thr billet bodies. Dumb rule. It runs exactly the same with either set. Car has a 285/292@.050 cam. Idles fine at 900. Obviously no street driving . It drives fine in the pits and doesn't load up. https://www.facebook.com/lightningracingcarburetors/Doug
[Re: mopar dave]
#3205278
01/16/24 02:23 PM
01/16/24 02:23 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
Still getting my 572 Hemi with Stage v heads together. Gonna run the Stage 2x4 intake with the carbs sideways. I have 2 850's with down leg boosters. Just curious of the latest tech with annular booster in a 4150 body? Street/strip deal with 12:1 compression and a 275@50 on 110 solid roller. All opinions welcomed. Well, I run a 1050AN Quickfuel on my engine. 493 stroker that is mostly street driven. Smallish SFT cam (259/266 duration @ .050). Lift is .627/.633. Track time is usually 4-6 times a year. No issues what so ever with the carb. Nice throttle response, runs clean. NO issues with tuning. Just my 2 cents.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
[Re: AndyF]
#3205306
01/16/24 04:58 PM
01/16/24 04:58 PM
Brad_Haak
Loudoun County, VA
"Never mind..."
[Re: mopar dave]
#3205532
01/17/24 11:27 AM
01/17/24 11:27 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
I have had excellent results with my QF 1050AN. Waaaay back when I stsrted running it everyone said it was junk lol.
[Re: mopar dave]
#3205590
01/17/24 01:14 PM
01/17/24 01:14 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
There are some interesting tech articles on Pro-systems website. I think where the annular shines is in a larger carb with lower vacuum signal applications. https://www.prosystemsracing.com/choosing-a-carb-size/
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: mopar dave]
#3205652
01/17/24 03:43 PM
01/17/24 03:43 PM
Posts: 4,457 Washington
madscientist
Washington
Still getting my 572 Hemi with Stage v heads together. Gonna run the Stage 2x4 intake with the carbs sideways. I have 2 850's with down leg boosters. Just curious of the latest tech with annular booster in a 4150 body? Street/strip deal with 12:1 compression and a 275@50 on 110 solid roller. All opinions welcomed. If it’s pump gas then for certain you want a GOOD annular booster. They ain’t all the same. Call Mark Whitner at Lightning Racing Carbs and buy your boosters from him. He makes the best AB’s out there and the second best isnt even close.
