A body 833 w/ shifter and rods; $500 #3204284
01/13/24 10:36 AM
01/13/24 10:36 AM
Benton, IL.
DaveRS23 Offline OP
Special needs idiot
DaveRS23  Offline OP
Special needs idiot
Benton, IL.
Master, again and still
Re: A body 833 w/ shifter and rods; $500 [Re: DaveRS23] #3204359
01/13/24 03:11 PM
01/13/24 03:11 PM
Az
69hemibeep Offline
69hemibeep  Offline
Az
Good price and not to be a negative Nancy but with the input cut that short it wouldn't even engage a roller bearing. So I would expect some internal wear if it was run like that.
1969 Hemi Roadrunner 2nd owner
Re: A body 833 w/ shifter and rods; $500 [Re: 69hemibeep] #3204457
01/13/24 09:36 PM
01/13/24 09:36 PM
yarnell,az
mopacltd Offline
mopacltd  Offline
yarnell,az
Maybe cut for a Chevrolet
Re: A body 833 w/ shifter and rods; $500 [Re: mopacltd] #3204489
01/14/24 12:23 AM
01/14/24 12:23 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Need to see the insides of these things. Who knows whats going on in there.
Might be a F-body overdrive unit too. No mention of front bearing retainer diameter.
Re: A body 833 w/ shifter and rods; $500 [Re: mopacltd] #3204493
01/14/24 12:37 AM
01/14/24 12:37 AM
IMGTX Offline
IMGTX  Offline
When you have a crank undrilled for a manual transmission people will cut the tip off and use a roller bearing in the crank register.
That one looks cut far shorter than usual but they are repairable.
Re: A body 833 w/ shifter and rods; $500 [Re: IMGTX] #3205212
01/16/24 11:40 AM
01/16/24 11:40 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Someone bought it .
I had a Hemi trans years ago that someone cut down, I sent the input shaft to Liberty and they retipped it for 100 I think was the cost.
