Re: A body 833 w/ shifter and rods; $500
[Re: DaveRS23]
#3204359
01/13/24 03:11 PM
01/13/24 03:11 PM
Posts: 1,385 Az
69hemibeep
Az
Good price and not to be a negative Nancy but with the input cut that short it wouldn't even engage a roller bearing. So I would expect some internal wear if it was run like that.
1969 Hemi Roadrunner 2nd owner
[Re: mopacltd]
#3204493
01/14/24 12:37 AM
01/14/24 12:37 AM
Posts: 12,237 Looking for a way out of Middl...
IMGTX
Maybe cut for a Chevrolet When you have a crank undrilled for a manual transmission people will cut the tip off and use a roller bearing in the crank register. That one looks cut far shorter than usual but they are repairable.
[Re: IMGTX]
#3205212
01/16/24 11:40 AM
01/16/24 11:40 AM
Posts: 75,069 U.S.S.A.
JohnRR
U.S.S.A.
Maybe cut for a Chevrolet When you have a crank undrilled for a manual transmission people will cut the tip off and use a roller bearing in the crank register. That one looks cut far shorter than usual but they are repairable. Someone bought it . I had a Hemi trans years ago that someone cut down, I sent the input shaft to Liberty and they retipped it for 100 I think was the cost.
