Meziere 336s pump flow? #3204020
01/12/24 11:05 AM
01/12/24 11:05 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got this pump for my intercooler and the hose for now is 1 1/4"inlet 1' from 3 gal tank and the outlet pressure side is -12 3/4"14' length of hose back to tank.I will upgrade as I can but if you have any flow data that may help me as to what to expect I would appreciate it.TIA
Re: Meziere 336s pump flow? [Re: Clanton] #3204083
01/12/24 02:22 PM
01/12/24 02:22 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
A quick google search says that pump flows 55 gallons per minute. I am sure that is using much larger hose. That seems like way overkill.
68 Barracuda Formula S 340
Re: Meziere 336s pump flow? [Re: Bad340fish] #3204101
01/12/24 03:01 PM
01/12/24 03:01 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I have a friend that used this pump on his intercooled 25# boost ls engine and he was filling the tank with ice.
Re: Meziere 336s pump flow? [Re: Clanton] #3207483
01/23/24 12:20 PM
01/23/24 12:20 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I am going to mount the water tank in the seat so it is easy to fill,drain.The flow to the pump should be good with a little gravity feed of 3 gallons/24#.
