New style of 727, 518 shift shaft seal
#3203890
01/11/24 08:41 PM
01/11/24 08:41 PM
Posts: 12,292 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My favorite old, semi-retired tranny guy turned me on to this new seal. I am going to try it this time around as I often have a leak there even with a new stock type seal. He also showed me another stock style seal that was taller than the original ones to get away from a possible groove in the shaft. That one is only a couple of bucks. The new style in the pic is over $10. Worth it IF it actually stops the leak. He also mentioned that he can get a brass bushing to go in the case to tighten up the dip stick tube O ring which is another place I often have a leak. That bushing will be in next week. Apparently, it just taps in place. When I get it, I will post pics of it and it's package for those that might be interested.
Master, again and still
Re: New style of 727, 518 shift shaft seal
[Re: dvw]
#3204062
01/12/24 01:47 PM
01/12/24 01:47 PM
Posts: 25,992 Rio Linda, CA
John_Kunkel
Rio Linda, CA
I've always thought that it's the grit that accumulates around the shaft that eventually leads to seal failure.
[Re: John_Kunkel]
#3204185
01/12/24 08:18 PM
01/12/24 08:18 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My tranny guy says it's the converter drain back that puts the pressure on the seal causing it to leak. He sees it all the time. Good pump seals with no grooves in the housing and a converter drain back preventer is the best preventative course according to him. I do have converter drain back and didn't want to tear into an otherwise very good operating 518. So, I will try this seal.
[Re: DaveRS23]
#3204287
01/13/24 10:55 AM
01/13/24 10:55 AM
Posts: 75,094 A Banana Republic near you.
JohnRR
My tranny guy says it's the converter drain back that puts the pressure on the seal causing it to leak. He sees it all the time. Good pump seals with no grooves in the housing and a converter drain back preventer is the best preventative course according to him. I do have converter drain back and didn't want to tear into an otherwise very good operating 518. So, I will try this seal. The pressure is your base atmospheric pressure on that seal when the fluid finds it's level with the trans off.
[Re: JohnRR]
#3204288
01/13/24 11:08 AM
01/13/24 11:08 AM
Posts: 5,949 ohio
ruderunner
ohio
This and JK. The dirt buildup damages the seal and shaft which allows it to leak even with no pressure on it.
As for the dipstick tube, make sure the end is round and inserted straight. If you have to bend or shim the support bracket do so.
Don't forget the seal on the TV shaft too.
Angry white pureblood male
