68-70 B body4 speed console molded carpet?
#3203192
01/08/24 12:58 PM
01/08/24 12:58 PM
Posts: 10,032 MN
JERICOGTX
MN
What is the trick for applying new carpet, on the driver side hump, that goes on a B body 4 speed console? Does that piece come molded to fit, or is it a PITA?
Suggestions welcome.
Thanks.
69 GTX
68 Road Runner
Re: 68-70 B body4 speed console molded carpet?
[Re: JERICOGTX]
#3203200
01/08/24 01:27 PM
01/08/24 01:27 PM
Posts: 75,043 U.S.S.A.
JohnRR
U.S.S.A.
It comes molded to fit the hump , you need to unroll it and let it sit out somewhere warm for a bit so it will flatten out after being rolled up for however long it has been .
[Re: JERICOGTX]
#3203425
01/09/24 01:58 PM
01/09/24 01:58 PM
Posts: 19,470 north of coder
moparx
a small heat gun helps as well. just use enough heat to allow some extra conformity to be obtained. too much heat will deform the carpet's pile or loop design.
[Re: JERICOGTX]
#3203497
01/09/24 09:30 PM
01/09/24 09:30 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Thanks. Hope you didn't buy the 4spd molded console carpet from Classic Industries?....if you did, toss it, piece of crap, buy the 4spd console carpet set from ACC....
[Re: DAYCLONA]
#3204295
01/13/24 11:47 AM
01/13/24 11:47 AM
Posts: 10,032 MN
JERICOGTX
MN
Thanks. Hope you didn't buy the 4spd molded console carpet from Classic Industries?....if you did, toss it, piece of crap, buy the 4spd console carpet set from ACC.... I haven’t bought anything yet. Thanks for the heads up.
69 GTX
68 Road Runner
[Re: fuelishnsilly]
#3205828
01/18/24 09:36 AM
01/18/24 09:36 AM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
[Re: 69Cuda340S]
#3205843
01/18/24 11:12 AM
01/18/24 11:12 AM
Posts: 7,369 Iowa
burdar
Owen's Dad
Owen's Dad
Iowa
What are you'all using to glue the carpet to the console? I am looking to glue carpet on '69 A Body console carpet. While not "correct", I used Velcro strips. I didn't have good luck with gluing it. The fit wasn't that good and I needed to make slight adjustments so it fit the floor. The Velcro allowed me to make those adjustments for the best fit.
[Re: burdar]
#3206043
01/18/24 09:37 PM
01/18/24 09:37 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Id deal directly with ACC, seen to many "substitutions" from several vendors pushing stuff off as ACC, best to go directly to ACC's site and purchase, keep in mind the 4spd console kit is available in other ACC carpet grades other than 80/20 loop....cut pile, high cut pile, etc to match the mat'l grade of the main carpet set MikeG
