Mopar Transmission For sale - 1st Quarter #3202019
01/03/24 08:11 PM
01/03/24 08:11 PM
Norwich CT USA
moparts Offline OP
moparts  Offline OP
Norwich CT USA
Re: Mopar Transmission For sale - 1st Quarter [Re: moparts] #3202100
01/03/24 10:21 PM
01/03/24 10:21 PM
Detroit area
6PAX Offline
6PAX  Offline
Detroit area
New in original box Mopar Performance flex plate P4529751. 6 bolt crank flange 7/16" bolt hole 10" converter bolt spacing. This is like new as it hasn't been used but it is old as I bought it many years ago. $50
904 transmission dipstick and tube. $30
New TCI Break-a-way TC 2400 stall torque converter #141200. Includes flex plate to t.c. bolts. $400 https://www.summitracing.com/parts/tci-141200
New in the box B&M Quicksilver shifter #80683. $325
2 finned aluminum 727 trans. pans. Not sure what the additional capacity is but they are about 2" deep. I have media blasted and painted them. No pick-ups. $125 each.
Big block 727 dipstick tube. I have 2. $20 each
Two 727 factory flex plates. 5/16" Bolt holes with 11" bolt circle. $20 each
I have numerous sets of factory flex plate to crank and flex plate to converter bolts. $8 for a set of crank bolts, $5 for a set of converter bolts.
Prices do not include shipping. gt340 at yahoo.com No Paypal.
Re: Mopar Transmission For sale - 1st Quarter [Re: moparts] #3202322
01/04/24 10:48 PM
01/04/24 10:48 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
727, 518 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 727, 518, 46RH, and 46RE transmission. The rear servo piston is a 1-piece design that replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. The piston is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. It comes in a kit with a heavy duty stainless steel return spring that will eliminate 1-2 shift overlap, a new seal, and a .075 extra thick retainer made from stainless steel that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This kit fits 67 and newer 727, 518, 618, 46RH, and 46RE transmissions. I also have a kit that fits the early 62-66 727’s. The price for either rear kit is $80.00 plus shipping. 100% Made in the USA. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!!
Re: Mopar Transmission For sale - 1st Quarter [Re: mrrandyj] #3202325
01/04/24 10:51 PM
01/04/24 10:51 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
727-48RE DUAL RING FRONT BILLET SERVO KIT
Dual ring billet front servo kits for 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. The front servo is responsible for applying the front band during the 1-2 shift. This servo is based off of the highly desired 71 and earlier Chrysler “small pin” servo that is ideal for use in performance transmissions, only this one is much better. The piston and cover are CNC machined out of solid 6061 billet aluminum and the shaft is CNC machined from prehardened 4140 steel. There are 2 return springs custom made out of stainless steel that will help eliminate the 2-3 shift overlap that these transmissions are known for. There is also a o-ring in the cover that seals it to the shaft to stop internal leakage and help more oil get to 3rd gear where it is needed most. The piston has 4 total sealing rings, doubling the sealing capacity of the original Chrysler servos. This is a ready to install kit, all the sealing rings and springs are included. The price for this kit is $125.00 plus shipping.
100% MADE IN THE USA
If you have any questions or to place an order my email address is mrrandyj@aol.com
All parts layed out.jpg (1142 downloads)
Re: Mopar Transmission For sale - 1st Quarter [Re: mrrandyj] #3202326
01/04/24 10:53 PM
01/04/24 10:53 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
904 BILLET REAR SERVO KIT
High performance low/reverse billet rear servo kit for a 1967 and newer 904, 998, 999, 500, 42RH, 42RE, 44RH, 44RE Dodge Plymouth Chrysler Jeep or AMC transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the after market shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1 piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the piston, a heavy duty return spring that will help eliminate the 1-2 shift overlap, a new seal, and a .075” extra thick stainless steel retainer that will not bend around the retaining ring and pop out of the case like the factory steel retainers do. This is a complete ready to install kit, no extra parts are needed and it is 100% Made in the USA. The price for this kit is $80.00 plus shipping.
If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!!!
904 Rear Servo Kit.jpg (1138 downloads)
Re: Mopar Transmission For sale - 1st Quarter [Re: mrrandyj] #3202327
01/04/24 10:56 PM
01/04/24 10:56 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
47RH 47RE and 48RE Billet Rear Servo Kit
High performance, low/reverse billet rear servo kit for a 1994-2007 47RH, 47RE, and 48RE Dodge Cummins Turbo Diesel and SRT10 Ram truck automatic transmission. This rear servo kit features a redesigned 1-piece piston which replaces the stock piston, inner spring, piston plug, snap ring, and the aftermarket shim used in performance rebuilds. It is CNC machined out of solid billet aluminum so it will not crack like the stock cast aluminum pistons are known for doing. You will also get much less internal leakage with the solid 1-piece piston compared to the stock assembly, that means more holding power for the rear band. Included in this kit is the billet aluminum piston, a heavy duty return spring that will eliminate the manual 1-2 shift overlap, a new seal, and a extra thick CNC machined billet steel retainer that will not bend around the retaining ring and pop out of the case like the factory retainers do. This is a complete ready to install kit, no extra parts are needed. The price for this kit is $90.00 plus shipping.
Re: Mopar Transmission For sale - 1st Quarter [Re: mrrandyj] #3202329
01/04/24 11:00 PM
01/04/24 11:00 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
BILLET DUAL RING ACCUMULATORS
These will fit just about any Torqueflite transmission including the 727, 904, 998, 999, 500, 518, 618, 42RH, 42RE, 46RH, 46RE, 47RE, and 48RE, almost every rear wheel drive transmission from 1962 on up to the 2007 48RE Cummins Turbo Diesel overdrive transmission. These are a great upgrade for all the 727s and 904s and are also perfect for replacing the plastic accumulator that Chrysler switched to in the late 80s. The plastic accumulators are known for cracking and causing problems in performance transmissions. I have done these 2 different ways: First is an exact stock replacement, this one will accept all the stock springs whether they go between the case and the piston or the piston and the valve body. These are perfect for the turbo diesel guys that have tighter aftermarket torque converters, or for the person doing a stock type rebuild on a gas transmission. Second is with a built in blocker rod that will stop the accumulator from moving in the bore and firm up shifts. No need to cut down round stock and make a blocker rod anymore, I did it for you. Comes with all 4 sealing rings. The price on these are $45.00 each plus shipping.
These are 100% Made in the USA. If you have any questions or want to place an order email mrrandyj@aol.com
Re: Mopar Transmission For sale - 1st Quarter [Re: mrrandyj] #3202330
01/04/24 11:02 PM
01/04/24 11:02 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
727-48RE FRONT BAND STRUTS AND BILLET BAND ANCHORS
Heavy duty, double thick, billet steel front band strut and billet front band anchor for a Dodge, Plymouth, Chrysler, or AMC 727, 518, 618, 46RH, 46RE, 47RH, 47RE, and 48RE transmissions. This fits from the 1962 727 transmission, all the way up through the 2007 ½ Cummins Turbo Diesel 48RE, and everything in between. The OEM Chrysler front band struts are prone to bending, and the OEM band anchors are known for breaking in high performance and heavy duty applications. The band strut is CNC machined from 1/4” thick steel, which is twice as thick as the factory strut and it is zinc coated for corrosion protection. The band anchor is also CNC machined from billet steel. Both are made in the USA. The price is $25.00 each plus shipping.
I also have the struts for a 904 transmission, same price
Email mrrandyj@aol.com
Re: Mopar Transmission For sale - 1st Quarter [Re: mrrandyj] #3202331
01/04/24 11:04 PM
01/04/24 11:04 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
BILLET 4.2 and 5.0 LEVERS
Billet steel 4.2 and 5.0 ratio front band apply levers for just about any Torqueflite transmission including the 727, 904, 998, 999, 500, 518, 618, 42RH, 42RE, 46RH, 46RE, 47RH, 47RE, and 48RE. Almost every rear wheel drive transmission from 1962 on up to the 2007 48RE Cummins Turbo Diesel overdrive transmission. These levers are CNC machined from solid billet steel. They are much stronger than the factory powdered metal forging levers, which are known for failing under the higher line pressures that performance transmissions run. The ratio is laser engraved into the tip of the lever in a large font size so it can be easily seen both in and out of the transmission. These are 100% made in the USA. $49 plus shipping. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!!!
Re: Mopar Transmission For sale - 1st Quarter [Re: mrrandyj] #3202333
01/04/24 11:07 PM
01/04/24 11:07 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
SPEEDOMETER BLOCK OFF PLUGS
CNC machined billet aluminum speedometer hole block off plug. These will fit almost every rear wheel drive automatic and manual transmission from 1966 on up. Uses the factory bracket and bolt to secure it to the transmission. Includes a new o-ring. This is a direct bolt in replacement for the factory speedometer adapter, no modifications are necessary. 100% Made in the USA. $30 each plus shipping. If you have any questions or want to place an order email mrrandyj@aol.com
Re: Mopar Transmission For sale - 1st Quarter [Re: mrrandyj] #3202334
01/04/24 11:09 PM
01/04/24 11:09 PM
CT
mrrandyj Offline
mrrandyj  Offline
CT
Reverse wound direct clutch pack spring for the 904, 998, 999, 500, 42RH, 42RE, 44RH, 44RE. The stock spring in the direct clutch drum loses its tension at high RPM and causes the direct clutches to drag in 1st gear. This spring is wound in the opposite direction which eliminates that problem and keeps the clutches from burning up and also helps eliminate 2-3 shift overlap. This spring should be used in any transmission that will see 5500 RPM or more. This is a direct replacement for the stock spring, no other parts or modifications are necessary. These springs have been through a shot peening process that drastically increases cycle life and they are 100% made in the USA. $30 plus shipping. If you have any questions, or would like to place an order, please email me at mrrandyj@aol.com Thanks!
Re: Mopar Transmission For sale - 1st Quarter [Re: budman1965] #3203082
01/07/24 08:02 PM
01/07/24 08:02 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
b&m 10239 and a 10236. 85.00shipped. will take pp or usps m/o. file too big for 10236 at 4.53
Re: Mopar Transmission For sale - 1st Quarter [Re: trw1982] #3203116
01/07/24 10:20 PM
01/07/24 10:20 PM
delhi,il
trw1982 Offline
trw1982  Offline
delhi,il
b&m 10236 flex plate. 85.00 shipped. will take pp or usps m/o.
Model 618 Overdrive Early Non Lock up Cummings Tranny [Re: moparts] #3205161
01/16/24 09:49 AM
01/16/24 09:49 AM
blewbyu Offline
blewbyu  Offline
I have a Cummings diesel 618 Overdrive early non lock up tranny. These are the good trannys which do not require a computer. $500.00 plus shipping from Florida blewbyu2bad@aol.com
618 1.jpeg (973 downloads)
618 2.jpeg (974 downloads)
618 3.jpeg (973 downloads)
727 small block or Big Block and 904 small blocks [Re: blewbyu] #3205163
01/16/24 09:51 AM
01/16/24 09:51 AM
blewbyu Offline
blewbyu  Offline
I have alot of cores available, no special part numbers for HP cars. $200.00 your choice plus shipping from Florida. blewbyu2bad@aol.com
4 Speed A Body Tranny set up [Re: blewbyu] #3205214
01/16/24 11:43 AM
01/16/24 11:43 AM
blewbyu Offline
blewbyu  Offline
I have everything you need do have handle forgot to put on before pics $1300.00. Tranny, bell with fork, shifter box with shift rods and handle. Plus shipping from Florida blewbyu2bad@aol.com
a 4 sp.jpeg (960 downloads)
a 4 sp1.jpeg (964 downloads)
Re: Mopar Transmission For sale - 1st Quarter [Re: moparts] #3205712
01/17/24 06:11 PM
01/17/24 06:11 PM
Cannelton, IN
mike337 Offline
mike337  Offline
Cannelton, IN
New Transmission Crossmember Bolt Kit. Includes 4 bolts, eight washers, and 4 nuts. Never installed. $15
9-24-2023 2-38-43 PM.jpg (902 downloads)
70 E body Automatic Floor Shifter [Re: moparts] #3206715
01/21/24 01:02 AM
01/21/24 01:02 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
70 E body Automatic Floor Shifter. Used, $450 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Call Steve 810-629-1097
70-74 E-B Body Floor Shifter Replacement Plate / With Instru [Re: Memongo] #3206716
01/21/24 01:03 AM
01/21/24 01:03 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
70-74 E-B Body Floor Shifter Replacement Plate / With Instruction. New, $70 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
Torqueflite Automatic Transmission Flex Plate [Re: Memongo] #3206717
01/21/24 01:05 AM
01/21/24 01:05 AM
Fenton, MI
Memongo Offline
Parts peddler
Memongo  Offline
Parts peddler
Fenton, MI
Torqueflite Automatic Transmission Flex Plate. Used, $35 + Shipping. Payment via US Postal Money Order Only! Shipping: US Address Only!
