Re: For Sale - Race Parts - 1st Quarter
[Re: moparts]
#3202155
01/04/24 09:58 AM
01/04/24 09:58 AM
Posts: 2,412 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
This is an 1150 gas Dominator built by IRD carburetors, I pulled the bowls off and checked everything for cleanliness, it’s clean and ready to use depending on your tuning requirements, the documentation for the carb is in the first pic, this is all I know about the carb, it had maybe 10 passes on it after it was bought and was replaced with a 1250 IRD carb, any questions just ask and I will answer to the best of my ability, this carb is part of an estate sale that I am in charge of, asking 600 shipped and it comes with a 4150 to 4500 adapter if you want it, payment needs to be cash or postal money order only, thanks, pm me here or email me at alilblacktruck@gmail.com
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: moparts]
#3202158
01/04/24 10:05 AM
01/04/24 10:05 AM
RapidusMaximus
Weatherford, Texas
J&W Bell housing to adapt a big block Mopar to a Powerglide, it is brand new and still in the box, transmission builder and I got our wires crossed and both bought one, so this one was not used, included is a used 8 bolt crank adapter and adapter flywheel, both are used but in good condition, I also have a 6 bolt flywheel but no crank adapter to fit it, I can include whichever one you prefer. I’ll take 650.00 shipped in the CONUS for both, there not doing any good collecting dust on my parts shelf, pm me here or email me at alilblacktruck@gmail.com, I don’t do pay pal, payment will be cash or US postal money order, thanks, Rob
[Re: moparts]
#3202177
01/04/24 11:33 AM
01/04/24 11:33 AM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
all sold
[Re: moparts]
#3202317
01/04/24 10:38 PM
01/04/24 10:38 PM
Posts: 1,544 CT
mrrandyj
CT
Rear trailer tie down brackets for most A, B, or E body vehicles (doesn’t fit the 7 ¼ rear axle). These piggyback onto the bottom of the stock shock plate mounting nuts and then 4 more nuts hold these tie down brackets on. You must have enough extra thread hanging down on the bottom of your U-bolts to fit the ¼” thick tie down bracket and another nut. No disassembly necessary, just slide the brackets over the extra thread on your U-bolts, install the included nuts, tighten them down and you’re done. Takes about 10 minutes to install. These eliminate all the hassles that come with using axle straps. Fits A, B, and E body cars with the standard shock plates like shown in the pictures. $60.00 per pair plus shipping. I also have these available for cars with CalTracs, same price. Made in the USA. Email mrrandyj@aol.com
Milodon Nostalgia Super Stock Oil Pan SBM
[Re: moparts]
#3202349
01/05/24 12:57 AM
01/05/24 12:57 AM
Posts: 148 Albert Lea, MN
GTX5877
Albert Lea, MN
Milodon 8 quart Nostalgia Super Stock oil pan for 318-340 small block Mopars with oil pump and swivel pickup assembly. 10" deep with draglink tube for ultimate rear sump on stock suspension Mopars. Pan was recently sent back to Milodon for new yellow/gold cad plating making it almost NEW appearance. This pan has swivel pickup as other versions were static pickup. If you are restoring an old Super Stock racecar, pan would make a perfect addition to period correct! $650 + shipping. Prefer US Postal money order or cash. E-mail GTX5877@yahoo.com or PM. more pix available
1967 Dart GTS 426 Gen III Hemi 1968 Hemi Cuda 572 SS/AH Clone 1988 Chrysler LeBaron Coupe S/S 2003 Dodge Ram 1500 4dr SLT lowered 2012 Ram 1500 2wd Lowered 1970-1/2 Camaro Z-28 1974 VW Karman-Ghia
[Re: 80arrow]
#3202667
01/06/24 10:17 AM
01/06/24 10:17 AM
Posts: 488 Charleston, SC
SCDaytona
Charleston, SC
MSD Front drive distributor kit and Weber mount with MSD adapter- Both new. $550. Aluminum door stand $100, Stroud Cam lock belts- Blue. SFI ran out last year $85. Parts are in Charleston SC and can be shipped although door stand may be expensive due to size and box required. Distributor and belts are sold
Re: For Sale - Small Block Tach drive distributor
[Re: moparts]
#3202978
01/07/24 01:23 PM
01/07/24 01:23 PM
Posts: 19,470 north of coder
moparx
Mopar Performance Small block Tach Drive distributor for sale. very slightly used piece. comes in the original MP box. asking $160.00 shipped anywhere in the lower 48 states. [offer ?] contact me here, or : moparxz "at" comcast "dot" net. put sb tach drive distributor in subject line. Thanks for the add MOPARTS !
update
[Re: moparx]
#3203247
01/08/24 05:20 PM
01/08/24 05:20 PM
Posts: 136 ca
Swingin70
ca
update
update
[Re: Swingin70]
#3203248
01/08/24 05:22 PM
01/08/24 05:22 PM
Posts: 136 ca
Swingin70
ca
update
[Re: moparts]
#3203475
01/09/24 06:53 PM
01/09/24 06:53 PM
Posts: 31,050 Oregon
AndyF
SOLD
