Will this be faster? Or just look cool? #3201347
01/01/24 09:24 AM
01/01/24 09:24 AM
Tulsa OK
Bad340fish Offline OP
Tulsa OK
Switching up the intake setup for 2024. My Dad has always loved stack injection, fresh off of drag week and looking over some stack injected cars this W2 Kinsler manifold popped up on marketplace. I sent him the link and next thing I know he bought them! So off came the tunnel ram and the Kinsler manifold EFI conversion is underway.
First thing I learned is that Kinsler components are expensive but quality pieces. Second, the injector fittings are removable so changing them over for electronic fuel inectors is easy. Third, this manifold came off of a short deck block because the valley cover isn’t even in the zip code of working. I’ll either widen this one or get one made from somewhere.
Thoughts on performance? The current combo has been a best of 10.40@127. 3535lbs 10:1 W2 418”. I don’t expect it to hurt anything I just don’t know how much this combo has left in it. It for sure won’t have any lack of airflow with a 2 5/8” throttle blade for each cylinder. Nothing else will be changed other than the components needed to make this intake work.
68 Barracuda Formula S 340
Re: Will this be faster? Or just look cool? [Re: Bad340fish] #3201368
01/01/24 10:34 AM
01/01/24 10:34 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
We first saw this concept on the Ed Pink or Kieth Black SB mopar for a stillborn Indy attempt in the 60's?
Its way cool btw. Kudos to your Dad.
Re: Will this be faster? Or just look cool? [Re: Bad340fish] #3201381
01/01/24 12:03 PM
01/01/24 12:03 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Don't know about "Way Faster" but should provide an improvement. Gets a little easier (control wise) if your converting to Elec injectors but more parts are going to be required, TPS, EGT sensors plus injector control unit, Assuming you are sending it out for the conversion they should be included in the package. Keeping it mechanical, I would tell you to send it out and have it flowed to your combination and start from there, I have not worked with a Kinsler set up but they are similar to Enderle as far as fuel control goes, once its flowed, make some passes and read the plugs, change the Main accordingly (bigger Main Jet = lean, Smaller Main Jet = rich). Once your close on the base main jet your can then start tweaking the port nozzles to optimize individual cylinders.As you tweak Port nozzles you will need to move the Main Jet up or down to keep the overall balance in check. A word of advice is always favor the Fat side of a fuel tune...Lean can get expensive real quick.This is regardless of fuel type.
You can improve performance with Injection vs Carbs do to better cylinder control as mentioned previously, where a carb kind of averages and has a better (less fussy) window, With Injection you can be more specific and has a more finite tuning capability and make changes closer to the time of need (make changes in the staging lanes) for best performance based on current weather conditions..or you can just leave it alone (fat tune) and run it...depends on what effort you want to put into it. Its one of the aspects of racing I enjoy.
Also I would recommend you get these from Kinsler, good info and How to stuff including parts (Mine are old....looks like from the 90's) and do some research as well, there's lot s of info out there.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Will this be faster? Or just look cool? [Re: W.I.N. Racing] #3201391
01/01/24 12:32 PM
01/01/24 12:32 PM
Tulsa OK
Tulsa OK
The car already has EFI so I have all that stuff. I will need to get creative with the tps though as there is no provision for a standard TPS.
Re: Will this be faster? Or just look cool? [Re: Bad340fish] #3201417
01/01/24 01:34 PM
01/01/24 01:34 PM
Byron, NY
Byron, NY
...Might be a draw then. But the Cool factor is way up up
'60 Willys CJ5
Re: Will this be faster? Or just look cool? [Re: W.I.N. Racing] #3201432
01/01/24 02:26 PM
01/01/24 02:26 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
You had a tunnel ram with dual 4bbl throttle bodies already, right? I don't think it's going to pick up much but that is incredibly cool and awesome of your dad to pick it up!!
I don't know how the IAC is integrated on the Kinsler setup but I had a little bit of experience on the Roush crate motors with 8 stack injection. They were very touchy both for the IAC and the throttle/bellcrank ratio. Very small movements in blade position gets you a ton of airflow in comparison to a single 4 or dual 4 setup, so it ends up being jumpy unless you go with a progressive bellcrank and more pedal travel.
Re: Will this be faster? Or just look cool? [Re: Blusmbl] #3201464
01/01/24 04:59 PM
01/01/24 04:59 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
Would it be possible to just plumb an 8 way brake size line to a separate manifold that mounts an IAC and just have the butterfly's close for idle?
Re: Will this be faster? Or just look cool? [Re: Bad340fish] #3201473
01/01/24 06:10 PM
01/01/24 06:10 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
It will likely tilt the power curve towards higher rpm.
- Stu Harmon
Re: Will this be faster? Or just look cool? [Re: jcc] #3201481
01/01/24 07:07 PM
01/01/24 07:07 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Yep-that's one way to do it, although in cold weather you'd typically need 1/4" line to each stack to provide enough air. Lots of the manifolds have a common plenum area underneath and the IAC can be remote mounted and plumbed to that as well.
Re: Will this be faster? Or just look cool? [Re: Blusmbl] #3201552
01/02/24 02:48 AM
01/02/24 02:48 AM
Washington
madscientist Offline
Washington
No stack injector will make the power of a tunnel ram. BTDT long ago.
Re: Will this be faster? Or just look cool? [Re: madscientist] #3201560
01/02/24 03:54 AM
01/02/24 03:54 AM
Cab_Burge Online work
Cab_Burge  Online Work
Tuned by you maybe work
I've seen more than one Comp Eliminators car go faster with stack injection that it did with a tunnel ram with two big 4 barrel carbs. tuned by the same racers that were fast work shruggy
Re: Will this be faster? Or just look cool? [Re: Cab_Burge] #3201568
01/02/24 09:38 AM
01/02/24 09:38 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
This conversation is above my pay grade, I thought the TR vs Stack debate was more of the tradeoffs of the hp benefits of a plenum manifold vs the throttle response crispness, ease of stack length tuning, and precise fuel metering of stacks, the last advantage being somewhat diminished by the addition of port EFI to TR's.
Re: Will this be faster? Or just look cool? [Re: jcc] #3201575
01/02/24 10:15 AM
01/02/24 10:15 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I am all on board with the cool factor, and with EFI conversion the fuel curve tuneability gets much easier. And when tuning don't forget the length of the stacks control where the rpm range that the torque is made, you can't tune intake length with a tunnel ram. Not saying that there is enough science on the books to build tunnel rams the right length runner, but you are kind of stuck with what you have. I remember the early prostock days when covers on the manifolds helped hide the length and shape of the runners as a team's speed secret.
Re: Will this be faster? Or just look cool? [Re: madscientist] #3201577
01/02/24 10:25 AM
01/02/24 10:25 AM
Tulsa OK
Tulsa OK
I guess I will find out lol.
Blusmbl I don't plan to run an IAC, I will drill all the runners for a vacuum line in order to make a small chamber for a common map signal. I'll turn on timing control to help maintain an idle speed. I will only miss it on cold starts most likely.
Re: Will this be faster? Or just look cool? [Re: Cab_Burge] #3201589
01/02/24 11:18 AM
01/02/24 11:18 AM
Charlotte, NC
LSP Offline
LSP  Offline
Charlotte, NC
I've not noticed that, who are the Comp racers that went faster with stack injection?
Re: Will this be faster? Or just look cool? [Re: Bad340fish] #3201606
01/02/24 12:21 PM
01/02/24 12:21 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have a small vac block that is connected to each runner, from there I have a line that goes to a vac storage can it is an overflow tank that seals up that has 2 connections, the other goes to the MAP sensor, it dampens the pulse .smooths out the signal to the MAP, no need for an IAC, going from a Indy single plane & carb to 8stack efi the ONLY change, my converter flash went from about 4200rpm to 5100rpm, smooth idle, much higher vacuum, LOVE IT, just takes some effort to get them dialed in. also NO pcv, just have a catch can breather.
Re: Will this be faster? Or just look cool? [Re: CSK] #3201608
01/02/24 12:27 PM
01/02/24 12:27 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
catch can
Re: Will this be faster? Or just look cool? [Re: CSK] #3201616
01/02/24 12:43 PM
01/02/24 12:43 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
This car had mechanical injection, thoroughly worked out by Chrysler and Hilborn, so probably not typical.
It was a friend of mines car and it was really fun to run.
Hopefully Clark will have as much fun with his setup as we did with this one.
Re: Will this be faster? Or just look cool? [Re: Cab_Burge] #3201638
01/02/24 01:27 PM
01/02/24 01:27 PM
Washington
Washington
Or maybe, just maybe (and it’s highly likely because over the last FOURTY YEARS I’ve seen very few actual carb tuners or ignition guys) they couldn’t tune a carb.
I know Kinsler says their stack injectors give “each cylinder a precisely measured volume of air to each cylinder” and that’s not only wrong, it doesn’t matter.
There is a reason why you don’t see nearly as many stack injected cars out there as you did in the 60’s through the 80’s.
I stand by my post. Stack injectors are for nostalgia, not making power.
Re: Will this be faster? Or just look cool? [Re: madscientist] #3201649
01/02/24 01:45 PM
01/02/24 01:45 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
LOL, as you said people cant even tune a CARB, Stack EFI is not for that type of person, it takes a LOT of work to get the 8 stack working right, you can also TUNE it with different length ram tubes to match the engine, & guess what ???????? that make more power LOL, mine is a street strip car drive great & the power is INSTANT !!!!!!
