02 Sensor Placement #3200323
12/27/23 05:22 PM
12/27/23 05:22 PM
Minnesota
R3 Racing Offline OP
Minnesota
I am installing a Holley Sniper EFI on our dragster. Where in the header collector is the best location for the O2 Sensor? The collector is not long enough to install it per the instructions.
Re: 02 Sensor Placement [Re: R3 Racing] #3200326
12/27/23 05:39 PM
12/27/23 05:39 PM
Ambridge, Pa.
rickraw Online content
rickraw  Online Content
Ambridge, Pa.
Lengthen the collector just enough so the bung can be welded in.
Re: 02 Sensor Placement [Re: R3 Racing] #3201244
12/31/23 09:38 PM
12/31/23 09:38 PM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
I put my O2 in the leanest pipe but I am not EFI.
Re: 02 Sensor Placement [Re: Clanton] #3201250
12/31/23 09:58 PM
12/31/23 09:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Put it in the collector. The readings will not be accurate at idle but will be fine at full throttle which is what matters
