Re: Throttle cable measurement
[Re: topside]
#3201644
01/02/24 01:40 PM
01/02/24 01:40 PM
Posts: 75,047 U.S.S.A.
JohnRR
U.S.S.A.
I seem to recall some swap where the Slant 6 cable was the "hot tip", but they're pretty long... Yes it was , think it was in Mopar Action before the current crop of available lengths ?
[Re: NITROUSN]
#3201722
01/02/24 04:11 PM
01/02/24 04:11 PM
JohnRR
U.S.S.A.
This is the Mancini number. This cable will work. MRE8668 That might be the 6cyl cable , that one is almost 30" total length
[Re: tboomer]
#3201776
01/02/24 07:37 PM
01/02/24 07:37 PM
Posts: 5,632 Detroit area
6PAX
Detroit area
I think I have an old 6 cyl. cable in the garage. I would be happy to measure it for you. Thanks. I'd be curious to see if it is the same length as the one from my car.
[Re: 6PAX]
#3201858
01/02/24 10:58 PM
01/02/24 10:58 PM
Posts: 18,424 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
As I mentioned in my original post, I tried my original 6 cylinder cable and it is way too long. Post some pictures of what you have going on. This is done every day with available mopar cables and they do not need to be cut.
[Re: topside]
#3203241
01/08/24 05:00 PM
01/08/24 05:00 PM
6PAX
Detroit area
Seems to me that moving the cable jacket rearward in the intake bracket would effectively take up the slack at the pedal end, wouldn't it ? In other words, pulling more of the cable forward inside the jacket. As I mentioned, I tried that, It didn't change anything.
[Re: 6PAX]
#3203251
01/08/24 05:27 PM
01/08/24 05:27 PM
NITROUSN
Seems to me that moving the cable jacket rearward in the intake bracket would effectively take up the slack at the pedal end, wouldn't it ? In other words, pulling more of the cable forward inside the jacket. As I mentioned, I tried that, It didn't change anything. It has to.
[Re: Torq37]
#3203302
01/08/24 08:50 PM
01/08/24 08:50 PM
Posts: 9,851 MI, usa
dvw
MI, usa
The factory overall inner cable length should adjust fine. If it's loose at one end it is because either the throttle cable bracket is to far forward. Or the pedal assy is bent (unliklely). Who's bracket is it? I always make my own. The only issue with using a factory long cable like a 6 cylinder is you may hae to loop it a bit behind the left head. The relation ship between th einner length and the outer casing of all factory cables i ssimilar enough to allow adjustment. I can cut and weld it for you if you need. Get a measurement of where it needs to be. I'm in Waterford Mi. Just finished one for the turbo Duster project I'm working on. Doug
[Re: dvw]
#3203309
01/08/24 09:22 PM
01/08/24 09:22 PM
Torq37
The factory overall inner cable length should adjust fine. If it's loose at one end it is because either the throttle cable bracket is to far forward. Or the pedal assy is bent (unliklely). Who's bracket is it? I always make my own. The only issue with using a factory long cable like a 6 cylinder is you may hae to loop it a bit behind the left head. The relation ship between th einner length and the outer casing of all factory cables i ssimilar enough to allow adjustment. I can cut and weld it for you if you need. Get a measurement of where it needs to be. I'm in Waterford Mi. Just finished one for the turbo Duster project I'm working on. Doug You just solved my problem and hopefully the OP’s as well. I have a similar bracket as the OP and I think I can just weld an extension on the existing tab and move the clamp stud backward about an inch.
