1984 D100 Engine Wire Harness #3199582
12/23/23 09:29 AM
12/23/23 09:29 AM
Greer, SC
TooMany62s Offline OP
Greer, SC
I replaced the lean burn slant six in my '84 D100 with a 440 more than thirty years ago. The wiring of the engine harness has become brittle over time. Of course the harness is no longer produced. Does anyone know where I might find a decent used harness. My guess would be any old harness has the same problems as mine. Any suggestions on what to do?
Re: 1984 D100 Engine Wire Harness [Re: TooMany62s] #3199666
12/23/23 04:10 PM
12/23/23 04:10 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I got lucky at a local junkyard when I had to redo my 85.
Re: 1984 D100 Engine Wire Harness [Re: volaredon] #3199797
12/24/23 10:33 AM
12/24/23 10:33 AM
moparx Offline
moparx  Offline
all jokes aside, if your connector [plastic] pieces are in good condition, a handful of quality brass connectors, a good crimping tool or two, and a few spools of the correct color wire will easily duplicate a harness for a fraction of the cost of a reproduction harness.
it's not as hard as one would think, just take your time and be patient.
get extra terminal ends and practice on several chunks of junk wire until you get the crimping process down.
beer
Re: 1984 D100 Engine Wire Harness [Re: TooMany62s] #3199940
12/25/23 08:30 AM
12/25/23 08:30 AM
E
earlymopar Offline
earlymopar  Offline
E
Great looking truck.
What I would look to do if I was in a similar situation and wanted to retain a factory harness is to get an original harness and use it as a pattern for copying and making a new one. That way you can take your time to make it correct and you can keep driving your truck until you're ready to make the swap. This would also reduce the time your truck is down.
Re: 1984 D100 Engine Wire Harness [Re: earlymopar] #3199974
12/25/23 02:37 PM
12/25/23 02:37 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Yup.
The original harness off of my 85 was the worst butchered harness I'd ever seen.
The alternator wire was twisted and taped, changed colors and gauge size 3x in the length of the/6 valve cover, with bare strands hanging out of the tape job. One dangling within an inch of the fuel line to the carb. A lot of house wire, a lot of fried fusible links.... I went to the junkyard and got another, and undid all the original tape and went thru the whole thing closely/ I found a few suspect areas which I fixed with crimps solder and heat shrink. I also did away with every fusible link, instead I found an under hood fuse box from "something else" and wired everything that was previously run thru a fusible link to/thru that.
Its beyond me, what they were thinking when they decided to wire everything thru softer wire 3 gauge sizes smaller than the parent circuit, and the way they crimped it into the harness to where it couldn't be properly replaced if and when it cooked.
Re: 1984 D100 Engine Wire Harness [Re: TooMany62s] #3200031
12/25/23 11:36 PM
12/25/23 11:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
So your 84 harness has already been modified for a big block. If your bulkhead is good then just buy wire and make a new one. Its the engine harness so there is only about 8 wires.
Re: 1984 D100 Engine Wire Harness [Re: NITROUSN] #3200467
12/28/23 12:41 PM
12/28/23 12:41 PM
moparx Offline
moparx  Offline
i have been using marine grade heat shrink with the "glue" when heat shrink is required, for quite a few years now.
i highly recommend it.
beer
Re: 1984 D100 Engine Wire Harness [Re: moparx] #3200537
12/28/23 07:07 PM
12/28/23 07:07 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Yup agreed when it can be found.
The normal stuff from the hardware store sucks
Re: 1984 D100 Engine Wire Harness [Re: volaredon] #3200691
12/29/23 01:55 PM
12/29/23 01:55 PM
moparx Offline
moparx  Offline
Re: 1984 D100 Engine Wire Harness [Re: moparx] #3200859
12/30/23 09:11 AM
12/30/23 09:11 AM
Greer, SC
Greer, SC
It looks like the answer is: Make One. So, I'll give that a shot. Thanks!!
Re: 1984 D100 Engine Wire Harness [Re: TooMany62s] #3201123
12/31/23 01:06 PM
12/31/23 01:06 PM
moparx Offline
moparx  Offline
making one is not as hard as it is intimidating.
use quality wire [automotive grade] and quality terminals, crimped with the proper crimping tool, and take your time.
you will do a good job.
beer
Re: 1984 D100 Engine Wire Harness [Re: moparx] #3201331
01/01/24 06:10 AM
01/01/24 06:10 AM
Greer, SC
Greer, SC
beer
Where can I find the correct terminals?
Re: 1984 D100 Engine Wire Harness [Re: TooMany62s] #3201509
01/01/24 10:51 PM
01/01/24 10:51 PM
Wills Point, Texas
Hugh Jorgan Offline
Hugh Jorgan  Offline
Wills Point, Texas
Digikey. thumbs
Re: 1984 D100 Engine Wire Harness [Re: Hugh Jorgan] #3201665
01/02/24 02:13 PM
01/02/24 02:13 PM
moparx Offline
moparx  Offline
digikey indeed ! up
Digikey
https://www.digikey.com
beer
