Page 1 of 3 1 2 3
Battery Maintainers: Which One Won't Burn Down the Garage #3200273
12/27/23 02:32 PM
12/27/23 02:32 PM
State of Confusion
hp383 Offline OP
Just a normal tag again
hp383  Offline OP
State of Confusion
So I am looking for a very dependable and reliable battery maintainer for a vehicle that is being stored all winter, and I will have very limited access to both the building and car.
I don't want to lose everything, and want to keep the battery going over winter I just got it going. I hope to drive it here and there, but on a daily basis I won't be able to oversee the operation so to speak.
I remember a member here lost everything from one of these devices, that was several years ago and hopefully technology has improved.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: hp383] #3200277
12/27/23 02:42 PM
12/27/23 02:42 PM
Banana Republic
FM3AAR Offline
FM3AAR  Offline
Banana Republic
I've been running the Battery Tender brand of battery maintainers for many years. Between my lawn mowers, my cars and my son's car, I currently have 9 Battery Tenders running.
Never ever had an issue with the Battery Tender brand. twocents
“You’ll own nothing” — And “you’ll be happy about it.”
K. Schwab
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: FM3AAR] #3200284
12/27/23 03:19 PM
12/27/23 03:19 PM
5thAve Offline
5thAve  Offline
In that situation it woyld be better to disconnect the battery and bring it home.
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: 5thAve] #3200298
12/27/23 03:56 PM
12/27/23 03:56 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
While I haven't had anything close to an overheating or fire problem - knocking on wood as I type this - Rhinodart's fire photos chill my spine.
I've had as many as 7 maintainers going at once.
Best of the ones I've bought were Schumachers & Duralast (AutoZone).
This year I've just disconnected the 2 Road Runner batteries, but am running maintainers on the 2 later models that have computers.
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: topside] #3200337
12/27/23 06:36 PM
12/27/23 06:36 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
I have a battery tender .75 amp unit on my sportster, my fury I've had need to start it about every 2 weeks so I can pull it out and work on other stuff in my garage..... The last 2 years I've been able to park that at moms house in her garage, and with no charger/maintainer at all it started right up without a jump after sitting 6-8 months...
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: hp383] #3200340
12/27/23 06:55 PM
12/27/23 06:55 PM
Kirkland, Washington
Pacnorthcuda Offline
For about 10-12 years I’ve been using battery tenders and BT jrs. Lately one crapped out (sort of) by no longer going into full float. I just switched to NOCO Genius 1s and so far so good. I like wall warts as opposed to corded on both ends.
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: hp383] #3200343
12/27/23 07:05 PM
12/27/23 07:05 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
I had been using Battery Tenders for many years until I had one short out and burn up. The case was totally warped and very hot.
I called corporate and reported the issue, they didn't seem very concerned sent me a new one.
Then a week later their chief engineer called me in a panic and wanted me to send the defective unit back for evaluation but it was already tossed into the dumpster.
Then I learned about desuflating process, won't use another Battery Tender gave the new replacement unit away. And I upgraded to the Battery Minder, great investment.
Here is the one I bought from Amazon..
Just my $0.02... wink
https://www.amazon.com/BatteryMINDe...y-Motorcycles/dp/B00D7HZ6FC/ref=sr_1_28?
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: Sinitro] #3200349
12/27/23 07:58 PM
12/27/23 07:58 PM
Round Lake Beach, Illinoisy
Rhinodart Offline
Rhinotruck
Rhinodart  Offline
Rhinotruck
I still use Battery Tenders but do not put the negative clamp on the battery. I leave the ground connected to the battery and put the negative on a clamp on a body ground. I have had some issues with battery tender not working correctly if I put both clamps on the battery... twocents
JB Rhinehart, Realist
A-Body's RULE!
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: 5thAve] #3200365
12/27/23 09:03 PM
12/27/23 09:03 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I totally agree. Hopefully we won’t be reading about this in another thread down the road. Ask Rhinodart.
Abe Lincoln
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: dart4forte] #3200376
12/27/23 09:49 PM
12/27/23 09:49 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Put it in a small fire proof box.
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: dart4forte] #3200377
12/27/23 09:53 PM
12/27/23 09:53 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Bring the battery home and keep it in a warm spot is the best thing you can do. Stored right it should hold a charge for a long time.
I have let past old cars I've owned sit from October to March or April and the battery still had enough juice to spin the engine over with plenty of speed. If you have batteries that need to be put on a charger several times a year you need to get a better brand of battery when those are used up.
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: Neil] #3200394
12/27/23 11:20 PM
12/27/23 11:20 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I just unhook the battery on my B'cuda and leave it in the car all winter. Usually just hook it up in the spring and start the car. My 18 Mustang I start once /month during winter....too many computer relearns to disconnect it. At work we had a pole barn full of cars with Battery Tenders on them.....Fire inspector came through and said tsk Had to take them all off.
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: Dcuda69] #3200405
12/28/23 01:33 AM
12/28/23 01:33 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I’ve never fooled with one and I get at least as long a life as the battery is rated for. U hook the cable for the winter is all I do. always hear about issues with these tender things. My latest battery is an odyssey and it the best battery I’ve ever had. Claim is it will go two years without a tender and not lose a beat. Both springs so far it fired the car like lightning first try.
I want my fair share
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: SomeCarGuy] #3200436
12/28/23 11:05 AM
12/28/23 11:05 AM
St. Louis, Missouri area
Cometstorm Offline
"Beat It"
Cometstorm  Offline
"Beat It"
I’m no exprert, but I think it’s a “vintage Mopar vs. modern Mopar thing.”
Vintage Mopar, I suspect can do well without a tender while in winter storage.
Modern Mopars have a continual micro battery drain due to all the advanced micro circuits and such.
A good tender on such will keep it topped off, so to speak.
It’s the “up / down” storage charge factors that are very hard on their batteries.
My 2020 Challenger Scat Pack is stored in a drywall insulated garage, which is house attached.
It’s on a Deltran 1.25 amp tender for the winter.
Battery Tender Plus 12V Battery Charger and Maintainer: 1.25 AMP Powersport Battery Charger and Maintainer for Motorcycles, ATVs, UTVs - Smart 12 Volt Automatic Float Charger - 021-0128 https://a.co/d/ec44JJn
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: Cometstorm] #3200443
12/28/23 11:26 AM
12/28/23 11:26 AM
Portage,michigan
B3422W5 Online content
B3422W5  Online Content
Portage,michigan
Same I use, never an issue
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: Cometstorm] #3200448
12/28/23 11:44 AM
12/28/23 11:44 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Disconnect the battery and you have no drain.
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: Sniper] #3200466
12/28/23 12:41 PM
12/28/23 12:41 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
On many late model vehicles doing a battery disconnect can be way more complicated.
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: Dcuda69] #3200503
12/28/23 02:19 PM
12/28/23 02:19 PM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
Deltran 1.25 amp battery tender is good. That being said if you put the car away with a fully charged battery (12.7 volts with no loads) it should be fine for several months if there is no draw on it.
68 Barracuda Formula S 340
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: Bad340fish] #3200509
12/28/23 03:16 PM
12/28/23 03:16 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
I work in the commercial and industrial uninterruptible power supply industry.
We use a lot of batteries. Some things to consider based on my observations and talking solely about lead acid type batteries.
If the batteries go 6 months or more between charges the likelihood of thermal runaway increases. Thermal runaway is when the battery overheats under use (charge or discharge) to the point it goes up in flames. That said, does it happen all the time? Nope. But if it happens you know the customer is going to blame us and potentially cost the company millions of dollars in damages.
The device we use to maintain and charge these batteries costs way more than anything you are going to use, even our cheapest model. They are as scienced out as possible and are continuously monitored and updated to prevent issues, see the millions of dollars mentioned.
We recommend 5 year replacement intervals for the VRLA batteries, similar to a maintenance free, and 20 years for flooded cells, similar to old school add water type batteries. Now these are in climate controlled environments using state of the art technology with regular testing and maintenance. Something you in your garage cannot match.
With all of this there is still the, very, occasional issue with thermal runaway. So, I would never leave my battery on any kind of continual charge, especially unmonitored and unobserved.
I would go thru whatever monkeyshines I needed to unhook my fully charged battery during storage. I would attach a charger when I came back to prep it for the driving season and disconnect when I left, if I were the type to store a car for the season. I real life, I just drive them.
But what I never do is leave them on a charger and walk away.
Re: Battery Maintainers: Which One Won't Burn Down the Garage [Re: FM3AAR] #3200511
12/28/23 04:01 PM
12/28/23 04:01 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Basic problem with the Battery Tender products is that they don't have a current/thermal shutoff...
So if something is shorted the Battery Tender should shut down, rather than continuing outputting a voltage and eventually overheating/shorting out..
In my personal case, I caught it early enough before it started a fire.
The product is built in China and its basic design should be modified to include a current/thermal shutoff..
But then its price would likely double..
Page 1 of 3 1 2 3
