Challenger door differences #3200053
12/26/23 10:16 AM
12/26/23 10:16 AM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Replaced the driver's door on my 70 with a 71 door, in the process of putting the car back together, the glass and window guides went back in fine. I am having an issue with the rear window guide holding the glass out about 3/16 farther than the front (at the door where the cat whiskers go). It appears the rear guide is holding the window out. Does anyone know if the rear guide on a 71 door is different? I should have kept the guides from the 71 door but i didn't. Not having much luck finding other posts about this particular issue. The only visual differences i can find is the 70 door has oval holes for the anti rattle and the 71 door has slots like the bottom, the rest of the door looks like the 70 including the cat whisker holes. I cant find a way to adjust the glass to get it tighter to the door in the up position.
2017 Challenger R/T Scat Pack Shaker
2021 T/A 392
1970 Challenger R/T 383,727, 3.55, (Wife's car)
1970 Challenger R/T SE 440-4, 4-speed, 4.10 Dana
1972 Dodge Demon 396 W-2,904, 4.30, 10.660 @ 125.85
2020 Hellcat redeye
Re: Challenger door differences [Re: moparfan] #3200091
12/26/23 02:28 PM
12/26/23 02:28 PM
Rio Linda, CA
John_Kunkel Online content
John_Kunkel  Online Content
Rio Linda, CA
According to the Hollander Interchange, the '70 door does not interchange with the later models.
Re: Challenger door differences [Re: John_Kunkel] #3200094
12/26/23 02:43 PM
12/26/23 02:43 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The problem with Hollander's is that unless it's pretty much a no mod swap they don't list it as interchangeable.
Re: Challenger door differences [Re: Sniper] #3200114
12/26/23 04:14 PM
12/26/23 04:14 PM
Rio Linda, CA
Rio Linda, CA
So, if a hammer and torch make it fit, it's an interchange?
Hollander states that the glass is the reason there's no interchange.
Re: Challenger door differences [Re: John_Kunkel] #3200116
12/26/23 04:17 PM
12/26/23 04:17 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
If it can be made to fit with a bit of effort, then yes. Since that is what the OP is asking.
You think that would have been helpful? Especially since that is exactly what the OP was up against?
Typical.
Re: Challenger door differences [Re: Sniper] #3200172
12/26/23 10:25 PM
12/26/23 10:25 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
I did some measuring tonight and the drivers door from the mounting point of the guide to the inner structure of the door is 5/8 difference from the passenger door. I believe this door is a 71 by the milar sticker that was on it, just cant remember if it was early or late build. i'm seeing lots of different info, some say the 70 is alone and some say the 70 and 71 are the same and the later ones are different but only the glass is different. They make repop guides just not sure which ones i need. I can not find any in and out adjustment for the glass at the bottom when it is rolled all the way up, the bottom adjustment moves the top in and out but the bottom is fixed.
2021 T/A 392
2020 Hellcat redeye
Re: Challenger door differences [Re: moparfan] #3200214
12/27/23 10:34 AM
12/27/23 10:34 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Curious if the '70's had side impact beams?
'63 Dodge 330
11.19 @ 121 mph
Re: Challenger door differences [Re: GY3] #3200223
12/27/23 11:11 AM
12/27/23 11:11 AM
an8sec70cuda Offline
Not sure about a Challenger, but my '70 cuda doors have side impact beams.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Challenger door differences [Re: an8sec70cuda] #3200227
12/27/23 11:26 AM
12/27/23 11:26 AM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
yes the 70 challenger doors have side impact beams
2021 T/A 392
2020 Hellcat redeye
Re: Challenger door differences [Re: moparfan] #3200238
12/27/23 11:57 AM
12/27/23 11:57 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
Here's a picture I often share whenever any talk of door differences comes up
Re: Challenger door differences [Re: EW1BH27] #3200242
12/27/23 12:10 PM
12/27/23 12:10 PM
It's a dry heat
gtx6970 Online content
gtx6970  Online Content
It's a dry heat
1970 Doors the window sweep are attached with clips. and the vertical chrome strip for the rear edge weatherstrip is 1970 only
1971 and later doors the window sweeps attach with screws.
And best I remember early 70 doors do not have the impact beam in them
Re: Challenger door differences [Re: gtx6970] #3200245
12/27/23 12:17 PM
12/27/23 12:17 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
ALL 1970 E- body doors had side impact beams, see the page at https://www.hamtramck-historical.com/images/serviceHighlights/70%20sh%2048.jpg
1970 E-body doors also have their own inner door latches & more holes at the bottom for door panel clips.
Re: Challenger door differences [Re: gtx6970] #3200247
12/27/23 12:22 PM
12/27/23 12:22 PM
Marysville Wa
moparfan Offline OP
moparfan  Offline OP
Marysville Wa
Thanks for the help. I may not have the guide in the track all the way thanks to Alan at autolan. the pic shows the anti rattle mounting for the 70 which is oval. the new door has all the 70 shapes at the glass with slotted holes. both pics attached
411305142_1086674009424153_1406338526334190585_n.jpg409599100_733898354964116_2182507572523177773_n (1).jpg
2021 T/A 392
2020 Hellcat redeye
Re: Challenger door differences [Re: GY3] #3203846
01/11/24 04:34 PM
01/11/24 04:34 PM
albany ny
0
05dakota Offline
05dakota  Offline
albany ny
THEY DO
5549 post on old board
Re: Challenger door differences [Re: Alaskan_TA] #3204075
01/12/24 02:10 PM
01/12/24 02:10 PM
Kirkland, Washington
Pacnorthcuda Offline
I owned BH23C0E100327 and it most certainly did NOT have impact beams in the doors. I took the doors off and apart, no beams. My BS23N0E108362 DOES have beams.
Re: Challenger door differences [Re: Pacnorthcuda] #3204107
01/12/24 03:32 PM
01/12/24 03:32 PM
IMGTX Offline
IMGTX  Offline
Interesting. How many days difference on the build dates?
8000 cudas made in between them.
I wonder if it happened along with the hood crime zone additions?
Re: Challenger door differences [Re: IMGTX] #3204141
01/12/24 06:06 PM
01/12/24 06:06 PM
I don’t know, the earliest car is gone. Obviously that was a Very early car. Weight difference tween the doors was huge.
