96 Dakota aftermarket wheels #3200072
12/26/23 12:40 PM
12/26/23 12:40 PM
n.e. pa.
65rbdodge Offline OP
n.e. pa.
I’m putting together a 96 Dakota 2wd, it’s been changed over to 5x4.5bp. I want to put some 17x7”wheels on it. I know the factory wheels are 15x6” w/5”bs. I’m looking at 17x7” w/5.5”bs wheels. Has anyone done this before? What have you used?
I lowered the truck 4” all around and I don’t want rubbing or the tires sticking out past the fender.
Re: 96 Dakota aftermarket wheels [Re: 65rbdodge] #3200109
12/26/23 03:50 PM
12/26/23 03:50 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Your aftermarket wheels are going to have to have a deeper rear wheel spacing. The stock wheels on a 96 Dakota sit inward at least an inch from center, maybe more.
Since you have lowered the truck from its original height, want to go with 17" diameter, and will need a deeper then centered rear offset, I believe some serious measurements are going to be needed to be done on your truck to assure clearance.
Re: 96 Dakota aftermarket wheels [Re: poorboy] #3200152
12/26/23 08:29 PM
12/26/23 08:29 PM
ILLINOIS
V
volaredon Offline
volaredon  Offline
V
ILLINOIS
Yeah he's not asking for much.
That said I went the other way with my 96, lifted instead of lowered... But only a couple of inches the only thing I don't like about the 96 is that the tinworm is taking possession
Re: 96 Dakota aftermarket wheels [Re: 65rbdodge] #3201846
01/02/24 10:40 PM
01/02/24 10:40 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
17" Dakota RT wheels from later model versions have been used on the 92-96 Daks with no problem. Might check sizes on some of the old build threads on the other sites.
