Almost there. #3199693
12/23/23 06:24 PM
12/23/23 06:24 PM
Las Vegas
Al_Alguire Offline OP
Las Vegas
Finally have everything together and in the truck. She makes noise. Still some stuff to do like the exhaust eventually. Need to go over the whole truck again to final set alignment 4 link stuff. Do some paint touch ups and the correct and coat the paint itself for now. But its been a long road and its finally just about there. A quick video of the first fire up link below. Enjoy
https://youtube.com/shorts/Fs_X1cv3ZLk?si=raeRuSvlWBHzTpQr
Re: Almost there. [Re: Al_Alguire] #3199697
12/23/23 06:35 PM
12/23/23 06:35 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Ready for that Super StreeT points chase.
Doug
Re: Almost there. [Re: Al_Alguire] #3199716
12/23/23 07:55 PM
12/23/23 07:55 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
Simply awesome!!
Re: Almost there. [Re: 80arrow] #3199729
12/23/23 10:09 PM
12/23/23 10:09 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Sounds great Al!
Re: Almost there. [Re: Al_Alguire] #3199740
12/23/23 11:47 PM
12/23/23 11:47 PM
Trumbull,CT.
jim sciortino Offline
Trumbull,CT.
When will the extended video version come to a theater near me???
Re: Almost there. [Re: jim sciortino] #3199822
12/24/23 12:35 PM
12/24/23 12:35 PM
Las Vegas
Las Vegas
Im gonna guess never....Or maybe not until I can win another NHRA Championship...
Re: Almost there. [Re: Al_Alguire] #3199869
12/24/23 04:37 PM
12/24/23 04:37 PM
Monrovia, So-Cal, USA
racerhog Offline
racerhog  Offline
You be looking good up there in Top Eliminator.... Or just wave at Ryan for me when you go by him.... Cheers and good luck with that ride Al !!!
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Almost there. [Re: racerhog] #3199880
12/24/23 05:20 PM
12/24/23 05:20 PM
Chesterfield Twp. Mi.
John Burdine Offline
Al, can you give a quick run down on the engine specs?
Re: Almost there. [Re: Al_Alguire] #3199918
12/24/23 09:45 PM
12/24/23 09:45 PM
Trumbull,CT.
Trumbull,CT.
Work on it. wink
Re: Almost there. [Re: Al_Alguire] #3199923
12/24/23 10:58 PM
12/24/23 10:58 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
we'll be rootin for you.
Re: Almost there. [Re: GomangoCuda] #3199935
12/25/23 07:47 AM
12/25/23 07:47 AM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
Something you don't see everyday. That was probably a ton of work but it's paying off now. Looking/sounding great, Congrats!!!
Re: Almost there. [Re: Al_Alguire] #3199939
12/25/23 08:19 AM
12/25/23 08:19 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Re: Almost there. [Re: jim sciortino] #3200078
12/26/23 01:32 PM
12/26/23 01:32 PM
Las Vegas
Las Vegas
Work on it. wink
Always do smile
Re: Almost there. [Re: Al_Alguire] #3200081
12/26/23 01:40 PM
12/26/23 01:40 PM
Indiana
Gabby63 Offline
Gabby63  Offline
Indiana
That does sound really good Al . Gary
Re: Almost there. [Re: John Burdine] #3200082
12/26/23 01:46 PM
12/26/23 01:46 PM
Las Vegas
Las Vegas
Nothing fancy. A KB Block, 4.625" Bryant crank, Aluminum rods, BME pistons, 55MM Bullet roller, Isky red zone lifters, intake is just port matched deal. Milodon pump, Moroso pan, Jesel Belt drive and distributor. Compression is 15.5-1. Cam is 286/302@.050 lobe lift is .5295"/.5066" on a 115 lobe sep. Carb is a 2.200" Braswell. It is just a bracket deal, well likely more .90 stuff than brackets. Can get into more specifics if anyone likes.
FWIW truck has a Glide, sheet metal 9" with 4.29 gear and a 15x33 tire. link strut 6.0 moly chassis. Truck is all steel except front clip. Stock dash and power windows still intact. We still need to build the exhast just waiting on some of the tubing to show up.
Re: Almost there. [Re: racerhog] #3200083
12/26/23 01:47 PM
12/26/23 01:47 PM
Las Vegas
Las Vegas
Just a sklow poke. Running S/ST hope I have enough to run 10.90. Maybe a little bracket racing too.
Re: Almost there. [Re: Al_Alguire] #3200092
12/26/23 02:30 PM
12/26/23 02:30 PM
I'm curious as to how well the cast single 4 intake works without extensive porting.
Re: Almost there. [Re: John Burdine] #3200101
12/26/23 03:20 PM
12/26/23 03:20 PM
Las Vegas
Las Vegas
This one has not been touched other than a port match and carb pad blending. Something I may do at a later date but for what I am doing with it should work fine. FWIW it makes good power now.
Re: Almost there. [Re: Al_Alguire] #3200104
12/26/23 03:39 PM
12/26/23 03:39 PM
racerhog Offline
racerhog  Offline
up cool
Bob(Cowboy)Hogan
Monrovia So-Cal
Re: Almost there. [Re: Al_Alguire] #3200113
12/26/23 04:06 PM
12/26/23 04:06 PM
birdtracker Offline
birdtracker  Offline
" It makes GREAT power now the way it is." Al: auto correct kicked in!!!! Birdtracker
