Challenger radiator hose help
#3199713
12/23/23 07:27 PM
12/23/23 07:27 PM
Posts: 466 Ohio
fiddlestix
Ohio
I have a 70 Challenger I put a 31” wide aluminum radiator in. I am trying to find an upper hose that will fit this application. It is passenger side 1-1/2” and measures 13” center to center. Does anyone have a part number for something that might work? Thank you in advance!!
Re: Challenger radiator hose help
[Re: fiddlestix]
#3199851
12/24/23 02:14 PM
12/24/23 02:14 PM
Posts: 2,926 A shed in England
Tig
A shed in England
Buy some silicone bends (spendy) or cut up a stock hose, add the appropriately sized tube (swaged) and job done as per pic. I did pretty much the same on the lower hose to clear the oil lines for the remote filter
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: komninon]
#3200481
12/28/23 01:28 PM
12/28/23 01:28 PM
Posts: 19,485 north of coder
moparx
i have one of those replacement "heat stove tubes" from a 70's something [universal perhaps ?] i just bend it to whatever shape i need, then go to the local parts store [o'reily's and napa] and match it up to something on the wall. most of the time the hose needs trimmed on both ends. i also bend some 1/16" wire around a broom handle, then insert it into the lower hose to prevent it from collapsing if it wants to do that.
[Re: 727specialist]
#3217530
03/02/24 06:00 PM
03/02/24 06:00 PM
Posts: 4,072 Mo.
racerx
Mo.
I used gates hose part # 21511. Just had to trim the radiator end. Keith I know this thread is an old one but,any ideal on the lower hose (part #) on this car?
[Re: racerx]
#3217544
03/02/24 06:49 PM
03/02/24 06:49 PM
Posts: 4,570 Motor City
6PKRTSE
Motor City
I don't like trusting a .50 hose clamps from blowing a hose going down the track. I welded up some -20 weld bungs and made some -20 AN upper and lower hoses.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
