Good magnetic screwdriver bits? #3198911
12/20/23 04:28 PM
12/20/23 04:28 PM
Virginia
BSharp Online content OP
BSharp  Online Content OP
Virginia
I sometimes work on equipment with lots of small Phillips screws, and dropping one down inside would be a major headache. Do you know of any #2 Phillips, 1/4" hex drive bits that have some real holding power?
Re: Good magnetic screwdriver bits? [Re: BSharp] #3198923
12/20/23 04:56 PM
12/20/23 04:56 PM
St. Charles, MO
wingman Online happy
Uncreative Title
wingman  Online Happy
Uncreative Title
St. Charles, MO
Usually it's the bit holder/driver that provides the magnetic force, not the bit itself. I'm curious to see what you find...
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
Re: Good magnetic screwdriver bits? [Re: BSharp] #3198924
12/20/23 04:57 PM
12/20/23 04:57 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Well Amazon has all sorts of cool tools these days, I just searched "magnetic #2 phillips bits" and got tons of results.
Hope this helps.
Re: Good magnetic screwdriver bits? [Re: A990] #3198937
12/20/23 06:19 PM
12/20/23 06:19 PM
Virginia
Virginia
I’m not real picky about whether it’s the bit or the holder. And yeah, been to Amazon and bought a couple that said magnetic. And they are, but just barely. I was hoping someone here is using something they really like.
Re: Good magnetic screwdriver bits? [Re: BSharp] #3198980
12/20/23 08:39 PM
12/20/23 08:39 PM
SW Fla.
CYACOP Offline
CYACOP  Offline
SW Fla.
Re: Good magnetic screwdriver bits? [Re: CYACOP] #3198982
12/20/23 08:49 PM
12/20/23 08:49 PM
New Jersey
P
Powerflow Online content
Powerflow  Online Content
P
New Jersey
In addition to magnetic bits or nut drivers, I'd get a magnetic cup to hold the screws once they're removed. You can find them reasonably priced at Harbor Freight.
Re: Good magnetic screwdriver bits? [Re: BSharp] #3199005
12/20/23 11:10 PM
12/20/23 11:10 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I have always preferred the Spring loaded-clamp type that holds the screw by its head. I have a couple of older craftsman units that work well. Klein and Greenlee both offer a version of the Craftsman. I found a closed listing on the bay with the Craftsman version. It does have the part number wink
You might search for Phillips screw starter. There are some that lock on with spring loading the slots down
beer
Klein /Greenlee
Craftsman Version
Re: Good magnetic screwdriver bits? [Re: BSharp] #3199015
12/21/23 12:12 AM
12/21/23 12:12 AM
N.W. Florida
Fat_Mike Offline
Fat_Mike  Offline
N.W. Florida
Those "rare Earth magnets" are what's needed in those things, but I haven't seen them either.
Re: Good magnetic screwdriver bits? [Re: Fat_Mike] #3199019
12/21/23 12:19 AM
12/21/23 12:19 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
weird but if you place your srewdriver shaft against the alternator pulley while running it will magnetize it.
Re: Good magnetic screwdriver bits? [Re: TJP] #3199054
12/21/23 09:23 AM
12/21/23 09:23 AM
Virginia
Virginia
Something like that Klein may be the ticket. Can it be fitted to a loosened screw to withdraw it? Sounds tedious, but a lot less so than fishing out a dropped screw.
This ring magnet would be a nice fit over my #2 bit and doesn't have a real big OD.
Re: Good magnetic screwdriver bits? [Re: BSharp] #3199058
12/21/23 09:32 AM
12/21/23 09:32 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That magnet is a great idea, but the one you linked is only 0.02" inside diameter, might be too small?
Re: Good magnetic screwdriver bits? [Re: Sniper] #3199064
12/21/23 09:49 AM
12/21/23 09:49 AM
Virginia
Virginia
I have some Dewalts that are 0.195" forward of the hex.
Re: Good magnetic screwdriver bits? [Re: BSharp] #3199067
12/21/23 09:53 AM
12/21/23 09:53 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Hmm, I was thinking the magnet would choke up on the bit, not be at the end. It's 1/4" thick, might be doable.
Re: Good magnetic screwdriver bits? [Re: BSharp] #3199068
12/21/23 09:54 AM
12/21/23 09:54 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
I feel your pain about fishing out dropped screws.
Notice in the picture the Blue “magnetic paper holder” at far left.
This has a very small “super magnet” you see attached to the Phillips bit in the Red handled extendable screwdriver, which is less than 1/4.
Attaching the small super magnet to the long shank screwdriver set at right also greatly increases holding of screws.
You will have to search for the Blue paper holder, but similar small diameter super magnets are in other consumer objects.
Note also the silver telescoping “magnetic extendable wand” attached to the tweezer handle.
Re: Good magnetic screwdriver bits? [Re: 360view] #3199070
12/21/23 10:06 AM
12/21/23 10:06 AM
Virginia
Virginia
I've tried sticking a high-strength magnet to the shaft, but found it wants to jerk the scerwdriver to any nearby steel, jarring the screw off the bit. The ring magnet may want to do this too, but I think I could place it on the shaft such that the magnet is in contact with the screw when the bit is engaged. Worth a few dollars to find out, and Grainger has both the Klein and the magnet.
Re: Good magnetic screwdriver bits? [Re: BSharp] #3199147
12/21/23 02:53 PM
12/21/23 02:53 PM
moparx Offline
moparx  Offline
i have a bunch of super magnets that came from water meter readers that were scrapped at work many, many, years ago.
they are approximately 1/2x1/2x1/4" or so, and those things are so strong that you better not have your fingers in the vicinity of two of them when they decide to "meet" each other !
you will get a pinch blister like you wouldn't believe !
i sent several members a few of these, and like everyone at work, i wished i had obtained a bunch more !
there were over 800 [yes, 800 ! eek] 4ft. square x 3ft. deep bins heaped at least a foot, foot and a half, of these tiny items that contained two coils and two magnets, separated by two 1/8x1/8x1/2" pins, contained in a plastic cage affair.
after one took a few apart, it became apparent how to do this quickly, just to obtain the magnets.
anyway, i have a couple of these things "stuck" [biggrin] around i occasionally put my driver bits on, and it doesn't take long to get the bits magnetized. they las quite a long time that way as well, before a fresh "charge" is needed.
i use them for so many other tasks it's unbelievable.
beer
Re: Good magnetic screwdriver bits? [Re: BSharp] #3199175
12/21/23 04:43 PM
12/21/23 04:43 PM
USA
3
360view Offline
360view  Offline
3
USA
Seen screws with this odd head?
It is a “Clutch Head Screw”
It was briefly popular around 1968 and designed to stay on the screwdriver during assembly or disassembly.
My grandfather bought a “radio with reach” Motorola XP7C which has those.
https://radiojayallen.com/motorola-xp7c-xp7ce-am-portable-radio/
Re: Good magnetic screwdriver bits? [Re: 360view] #3199201
12/21/23 06:28 PM
12/21/23 06:28 PM
moparx Offline
moparx  Offline
seen those many times.
also have seen those with a little tIt in the middle of them as a tamper proof screw.
super cheap tamper proof bit sets on amazon and the bag. everyone should have them.
such as : https://www.ebay.com/itm/404091018520?
and : https://www.amazon.com/10048A-Secur...of+bit+set&qid=1703197569&sr=8-6
and many more like them in a ton of price ranges.
beer
Re: Good magnetic screwdriver bits? [Re: BSharp] #3199285
12/21/23 11:13 PM
12/21/23 11:13 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
The OD is listed at 23/64 wink
Re: Good magnetic screwdriver bits? [Re: 360view] #3199313
12/22/23 07:00 AM
12/22/23 07:00 AM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Buddy had a 46 Chevy that was full of those screws. Not a fan at all.
