7.75x14" blue streak repro tires choices?
#3198926
12/20/23 05:16 PM
12/20/23 05:16 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
What are people using for 7.75x14" Blue Streak (blue sidewall) replacement tires?
I see they offer 6.75 Blue Streaks with blue side wall and raised white letters (GT 350 tire). But cant find 7.75x14" blue side wall only's.
Is there something that is close?
Re: 7.75x14" blue streak repro tires choices?
[Re: autoxcuda]
#3199074
12/21/23 10:21 AM
12/21/23 10:21 AM
Posts: 21,454 It's a dry heat
gtx6970
It's a dry heat
I think it's Coker makes or at least made them
But they are a BFG Silverton tire
Yep. They show them Almost $500 EACH
Not for me though
Diamondback has a blue line radial
[Re: gtx6970]
#3199155
12/21/23 03:23 PM
12/21/23 03:23 PM
autoxcuda
So Cal
Not for me though
Diamondback has a blue line radial Yea. That’s what I’m seeing. Bummer. I was considering a blackwall or whitewall 7.75x14 Goodyear. Then having the blue line added. There used to be a local dude that did this. But I can’t even frind 7.75x14” any Goodyears.
[Re: autoxcuda]
#3199250
12/21/23 08:59 PM
12/21/23 08:59 PM
Posts: 21,526 N.E. OHIO, USA
A12
N.E. OHIO, USA
Not for me though
Diamondback has a blue line radial Yea. That’s what I’m seeing. Bummer. I was considering a blackwall or whitewall 7.75x14 Goodyear. Then having the blue line added. There used to be a local dude that did this. But I can’t even frind 7.75x14” any Goodyears. You can do it too, just head over to the local hobby or craft store and pick up an assortment of blue permanent markers. You'll be amazed at the results. I had a Goodyear white (line) with the same width sidewall "line" as a red line and made it into a perfect spare red line tire for the '68 RR. Find a bad white wall junk tire to practice on to get the color right and save lots and lots of $$$$. This used to be a white-line tire.
[Re: A12]
#3199273
12/21/23 10:42 PM
12/21/23 10:42 PM
autoxcuda
So Cal
Not for me though
Diamondback has a blue line radial Yea. That’s what I’m seeing. Bummer. I was considering a blackwall or whitewall 7.75x14 Goodyear. Then having the blue line added. There used to be a local dude that did this. But I can’t even find 7.75x14” any Goodyears. You can do it too, just head over to the local hobby or craft store and pick up an assortment of blue permanent markers. You'll be amazed at the results. I had a Goodyear white (line) with the same width sidewall "line" as a red line and made it into a perfect spare red line tire for the '68 RR. Find a bad white wall junk tire to practice on to get the color right and save lots and lots of $$$$. This used to be a white-line tire. Nice !! Problem is, I can't find a 7.75x14 Goodyear bias ply to start with. And then to add a blue line to. I would consider something wider than 7.75 in a Goodyear. But must be 14"
[Re: autoxcuda]
#3199310
12/22/23 02:50 AM
12/22/23 02:50 AM
Posts: 17,518 Las Vegas, NV
6bblgt
Las Vegas, NV
M = 1966 U = February can you post a picture of the tread
[Re: 6bblgt]
#3199311
12/22/23 03:44 AM
12/22/23 03:44 AM
autoxcuda
So Cal
M = 1966 U = February can you post a picture of the tread Here you go!
[Re: 6bblgt]
#3199475
12/22/23 05:56 PM
12/22/23 05:56 PM
autoxcuda
So Cal
COOL!! what is that, 4-1/2" of tread width? Looks like a whopping 5”
[Re: 6bblgt]
#3199647
12/23/23 02:59 PM
12/23/23 02:59 PM
gtx6970
It's a dry heat
M = 1966 U = February can you post a picture of the tread Damn, That would be PERFECT for the trunk of my car. But no way would I try to drive on it.
[Re: gtx6970]
#3199672
12/23/23 04:37 PM
12/23/23 04:37 PM
autoxcuda
So Cal
M = 1966 U = February can you post a picture of the tread Damn, That would be PERFECT for the trunk of my car. But no way would I try to drive on it. Sorry, it’s staying with the car it was delivered with under its original trunk mat. .
[Re: gtx6970]
#3199742
12/23/23 11:58 PM
12/23/23 11:58 PM
autoxcuda
So Cal
Just weird detail shots on this phone. 68k miles. 1981 Hot Rod “Supercar Shootout” article said 60K miles. The red-ish hue you see in the fender well is factory primer. Not rust Working on fine cleaning the little corners and such. Q-tip, small soft bristle, ultra low aggressive stuff.
[Re: gtx6970]
#3200838
12/30/23 02:13 AM
12/30/23 02:13 AM
autoxcuda
So Cal
[Re: autoxcuda]
#3200997
12/30/23 07:16 PM
12/30/23 07:16 PM
Posts: 20,834 A collage of whims
topside
A collage of whims
Yup,, Nobu's was well known back in the day. In the Valley, Jennings' place was popular - the son did my 1st Road Runner. He told me that on his post-dyno test drive, he annihilated a Camaro
[Re: cudaman1969]
#3201030
12/30/23 11:23 PM
12/30/23 11:23 PM
autoxcuda
So Cal
Looks super great, can’t wait to get my 66 that close to driving around to shows. Survivor Hemi car. Original paint and interior. Front bumper rechromed. Rest of original brightwork is extremely nice. SoCal car. Always garaged and extremely well cared for. Might recognize it from print back in the day. This book was published in 1989
