Page 1 of 3 1 2 3
Indy 440-1 4500 intake manifold #3198503
12/19/23 12:31 AM
12/19/23 12:31 AM
Kansas
Thelma133 Offline OP
Kansas
Any of you gents Know where you can purchase a new Indy max wedge intake manifold with a 4500 dominator top? Indy has one on their site, but it’s $900.00 bucks. Trying to find it somewhere for less. Thanks for any help.
Re: Indy 440-1 4500 intake manifold [Re: Thelma133] #3198511
12/19/23 04:44 AM
12/19/23 04:44 AM
Which motor, low deck or RB?
Which version do you want, 1st or 2nd ?
I'll look in the shop in the morning and see which one I have left luck
Re: Indy 440-1 4500 intake manifold [Re: Thelma133] #3198516
12/19/23 06:54 AM
12/19/23 06:54 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
They come up on Facebook Marketplace once in a while. Just saw one the other day, for just over half that price, but can't remember the location. maybe around INDY?
69 GTX 68 Road Runner
Re: Indy 440-1 4500 intake manifold [Re: Thelma133] #3198520
12/19/23 08:35 AM
12/19/23 08:35 AM
Mo.
racerx Offline
racerx  Offline
Mo.
shock...Sure hope that's a misprint.
Re: Indy 440-1 4500 intake manifold [Re: racerx] #3198525
12/19/23 09:21 AM
12/19/23 09:21 AM
an8sec70cuda Offline
See em on Facebook for sale all the time it seems like.
I know a lot of folks hate Facebook and refuse to get on there, but if you want to buy or sell anything...it's the best game in town.
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Indy 440-1 4500 intake manifold [Re: Cab_Burge] #3198577
12/19/23 12:28 PM
12/19/23 12:28 PM
Kansas
Kansas
Cab this will be for an RB 572. I don’t know the difference between first or second, so you will have to educate me. Thanks for answering.
Re: Indy 440-1 4500 intake manifold [Re: racerx] #3198578
12/19/23 12:28 PM
12/19/23 12:28 PM
Kansas
Kansas
No, it’s not a misprint, it’s $900 bucks, and I called INDY to verify the price and it’s correct. Unfortunately, I spent a lot of money having BES port an INDY manifold for a 4150. 572 will need a lot more fuel than a street manifold. A costly mistake, UGHHH
Re: Indy 440-1 4500 intake manifold [Re: Thelma133] #3198588
12/19/23 12:42 PM
12/19/23 12:42 PM
So. Burlington, Vt.
fast68plymouth Online content
fast68plymouth  Online Content
So. Burlington, Vt.
Just use an adapter for the 4500 carb.
Re: Indy 440-1 4500 intake manifold [Re: fast68plymouth] #3198593
12/19/23 12:51 PM
12/19/23 12:51 PM
Kansas
Kansas
Thanks FAST, will that work???
Re: Indy 440-1 4500 intake manifold [Re: Thelma133] #3198594
12/19/23 12:53 PM
12/19/23 12:53 PM
So. Burlington, Vt.
So. Burlington, Vt.
Depending on who you talk to, some people prefer it.
But, you’ll need an extra 2” of hood clearance.
Re: Indy 440-1 4500 intake manifold [Re: fast68plymouth] #3198595
12/19/23 12:55 PM
12/19/23 12:55 PM
Kansas
Kansas
Thanks. I have a large hood scoop, maybe it will fit.
Re: Indy 440-1 4500 intake manifold [Re: Thelma133] #3198619
12/19/23 01:38 PM
12/19/23 01:38 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Just have someone redrill the bolt pattern on the carb pad and plend in the are under the carb a bit.
Re: Indy 440-1 4500 intake manifold [Re: Al_Alguire] #3198637
12/19/23 02:41 PM
12/19/23 02:41 PM
Kansas
Kansas
I guess that may work Al. When I look on Indy’s website, the 4150 and 4500 are adjacent to each other, so it’s Very obvious how much larger the opening of the 4500 is. Going to have to mull this over a bit.
Re: Indy 440-1 4500 intake manifold [Re: Thelma133] #3198640
12/19/23 02:54 PM
12/19/23 02:54 PM
So. Burlington, Vt.
So. Burlington, Vt.
Re: Indy 440-1 4500 intake manifold [Re: fast68plymouth] #3198667
12/19/23 04:13 PM
12/19/23 04:13 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We have redrilled MANY Indy intakes to take a 4500 carb and done some simple blending and they worked great. When I went put a 446 out of my 67 D100 into our dragster for my kid to learn in I drilled the very same Indy intake you have from a 4150 to 4500 and did some blending. The car went from running 8.40's here in Vegas to 8.teens...
Re: Indy 440-1 4500 intake manifold [Re: Al_Alguire] #3198756
12/19/23 10:26 PM
12/19/23 10:26 PM
Kansas
Kansas
Thanks Al and Fast. Al do you attribute your reduction in ET to your blending, or the change to a bigger carburetor??
Re: Indy 440-1 4500 intake manifold [Re: Thelma133] #3198765
12/19/23 10:46 PM
12/19/23 10:46 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
If you've already got the 440-2, everything I've read mentions after porting that is a great intake, and better than the discontinued 440-3 with the dominator pattern. The 440-2 with a 4150-4500 spacer is arguably as good as the 440-3x.
Re: Indy 440-1 4500 intake manifold [Re: Blusmbl] #3198792
12/20/23 01:23 AM
12/20/23 01:23 AM
Kansas
Kansas
Im wondering , is the plenum and are the runners the same size as the larger dominator manifold. If the 4150 is smaller, I don’t understand from an airflow perspective why that manifold would be a better choice???
Re: Indy 440-1 4500 intake manifold [Re: Thelma133] #3198803
12/20/23 07:55 AM
12/20/23 07:55 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
The 4150 and 4500 manifolds are the same casting. There have been variations in castings through the years. They are just machined for the different carb sizes. The 440 X manifold is a different casting.
Re: Indy 440-1 4500 intake manifold [Re: fbs63] #3198833
12/20/23 11:01 AM
12/20/23 11:01 AM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Low deck versions but you can see they are the same intake. Bolt holes would need filled on the 4150 before you re drilled for a 4500 as they slightly overlap. I backed to backed these on my 512, the 4150 with a 4500 adaptor was slightly faster and had better distribution. I did run a 2” spacer on the 4500 as well to even the plenum volume. I’ve also been told by numerous people the 4150 works better before I even tried it.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Page 1 of 3 1 2 3
