Dyno Results 540 CID Indy 345 CNC
#3198549
12/19/23 10:56 AM
12/19/23 10:56 AM
Posts: 16,928 NC
440Jim
NC
This is the results of a friend's new big block Mopar engine.
New BMP aluminum block, new Indy heads 2023 540 CID, 4.500” x 4.250” Aluminum rods Indy 440-1 CNC 345 heads (Some work done after receiving from Indy, i.e. not Out-Of-The-Box) Indy 4500 intake 1050 Dominator Carb 285/292 at 0.050", 108 LSA Comp roller cam (318/330 at 0.020") Lift 0.753”/0.753” at 1.6, cam card 0.706”/0.706” at 1.5 rocker ratio
745 ft-lb at 5600 rpm 919 hp at 6900 rpm
Re: Dyno Results 540 CID Indy 345 CNC
[Re: 440Jim]
#3198558
12/19/23 11:34 AM
12/19/23 11:34 AM
Posts: 10,032 MN
JERICOGTX
MN
Nice numbers. Compression ratio? Alchohol?
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3198562
12/19/23 11:50 AM
12/19/23 11:50 AM
Posts: 16,928 NC
440Jim
NC
~13 CR 12.7 CR Racing gas vacuum pump
[Re: 440Jim]
#3198564
12/19/23 11:56 AM
12/19/23 11:56 AM
Posts: 10,032 MN
JERICOGTX
MN
12.7 CR Racing gas vacuum pump Interesting. Makes more Trq, and HP than my 563 with 345CNC heads, with less compression, cam, cubes, and carb. I must have done something wrong.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3198566
12/19/23 12:03 PM
12/19/23 12:03 PM
Posts: 13,369 Marion, South Carolina [><]
an8sec70cuda
12.7 CR Racing gas vacuum pump Interesting. Makes more Trq, and HP than my 563 with 345CNC heads, with less compression, cam, cubes, and carb. I must have done something wrong. Precisely why there isn't a dyno racing class.
[Re: 440Jim]
#3198606
12/19/23 01:14 PM
12/19/23 01:14 PM
Posts: 22,696 Bitopia
jcc
Bitopia
What does that -8 +26 HP sequence indicate at 6700? Would a carb spacer help smooth that out?
[Re: jcc]
#3198614
12/19/23 01:29 PM
12/19/23 01:29 PM
Posts: 19,373 Las Vegas
Al_Alguire
Las Vegas
As we all know what it runs in the car is the ultimate gauge. Dynos are dynos as they say. Dont get to caught up in those numbers especially when you dont have things like BSFC and correction to look at
[Re: jcc]
#3198616
12/19/23 01:30 PM
12/19/23 01:30 PM
Al_Alguire
Las Vegas
What does that -8 +26 HP sequence indicate at 6700? Would a carb spacer help smooth that out? Could easily just be an issue with the dyno.....
[Re: jcc]
#3198656
12/19/23 03:27 PM
12/19/23 03:27 PM
Posts: 14,506 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
What does that -8 +26 HP sequence indicate at 6700? Would a carb spacer help smooth that out? The dyno measures tq, and calculates the hp. Since all the results are above 5252rpm, the differences from the tq curve will be exaggerated in the HP curve. My guess is, looking at the jog in the tq curve, it was some sort of brief misfire(drop in tq), then the load cell gets a little tug when the misfire recovers(spike in tq). If you applied some “smoothing” to the curve, in that area of the curve, the numbers should be more representative of reality. Unless of course you see the same jog in the data on every run, in the same place…….. which still wouldn’t rule out a misfire, but would indicate something is creating the misfire(if that’s in fact the problem), and that it’s not completely random.
[Re: AndyF]
#3198676
12/19/23 04:41 PM
12/19/23 04:41 PM
Posts: 10,032 MN
JERICOGTX
MN
What is it going into Jim?
69 GTX
68 Road Runner
[Re: fast68plymouth]
#3198685
12/19/23 05:25 PM
12/19/23 05:25 PM
Posts: 16,928 NC
440Jim
NC
If you applied some “smoothing” to the curve, in that area of the curve, the numbers should be more representative of reality. Me being a numbers guy... I did a curve fit of the dyno torque, and then calculated the HP at each point from the "smoothed" torque equation. Here it is:
#3198701
12/19/23 06:59 PM
12/19/23 06:59 PM
jcc
Bitopia
What does that -8 +26 HP sequence indicate at 6700? Would a carb spacer help smooth that out? The dyno measures tq, and calculates the hp. Since all the results are above 5252rpm, the differences from the tq curve will be exaggerated in the HP curve. My guess is, looking at the jog in the tq curve, it was some sort of brief misfire(drop in tq), then the load cell gets a little tug when the misfire recovers(spike in tq). If you applied some “smoothing” to the curve, in that area of the curve, the numbers should be more representative of reality. Unless of course you see the same jog in the data on every run, in the same place…….. which still wouldn’t rule out a misfire, but would indicate something is creating the misfire(if that’s in fact the problem), and that it’s not completely random. Thank you
