Starter relay causing ignition problem #3197846
12/16/23 12:08 AM
12/16/23 12:08 AM
Nashport, OH
chargers777 Offline OP
Nashport, OH
Can this happen? I have a 74 d100 and it randomly stops running and won't start for awhile. I changed coil and ECU with known good ones but was wondering about the starter relay since it has a spot for ignition.
Re: Starter relay causing ignition problem [Re: chargers777] #3197880
12/16/23 09:02 AM
12/16/23 09:02 AM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Off the top of my head, the ignition wire at the relay is jut to bypass the ballast resistor when cranking. Unless it shorts out somewhere I don't see it causing a stall situation.
Assuming the problem persists after changing the ECU and coil, I'd be suspect of the pickup coil in the distributor.
Of course 50 year old wires are always suspect.
Angry white pureblood male
Re: Starter relay causing ignition problem [Re: ruderunner] #3198012
12/16/23 04:46 PM
12/16/23 04:46 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Agreed, and the ballast is bypassed in the start position so that eliminates it.
I would check the see if you're are getting spark when the problem occurs. If not, verify grounds even if you've already done so. I have in th epast run a small braided ground strap between the ECU and engine block making sure both surfaces are clean of paint etc.
Using a brass or non magnetic feeler gauge, check the reluctor gap to pick up coil, should be .008-.010" .
usually a good idea to check it in a couple of places. Then try the pickup coil.
Keep us posted beer
Re: Starter relay causing ignition problem [Re: chargers777] #3198015
12/16/23 04:57 PM
12/16/23 04:57 PM
Hamtramck, PA
Alaskan_TA Offline
Fluffy Balladeer
Alaskan_TA  Offline
Fluffy Balladeer
Hamtramck, PA
Make sure your voltage regulator has a good ground.
I have had to sand paint off the back where the screw holes are to get a good body ground. (I used dialectric grease on the bare metal)
I fought that die suddenly / no restart issue for months with one car, no issues years later after ensuring a good ground.
Re: Starter relay causing ignition problem [Re: chargers777] #3198061
12/16/23 09:38 PM
12/16/23 09:38 PM
nowhere
Sniper Online content
Sniper  Online Content
nowhere
Some troubleshooting rather than ransom parts swapping might help.
Are you even getting voltage to the coil when this happens?
Re: Starter relay causing ignition problem [Re: Alaskan_TA] #3198062
12/16/23 09:39 PM
12/16/23 09:39 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I had one that would randomly die and immediately restart until it died again. Could be 5 or 50 miles whistling shruggy One of the pickup wires inside the distributor had broken internally from the vacuum advance moving. Found it while trying to stretch the wires. One stretched the other didn't wink
Re: Starter relay causing ignition problem [Re: chargers777] #3198086
12/17/23 08:25 AM
12/17/23 08:25 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Every early one Ive had had a problem with the amp meter.Seems they burn and would let the vehivle die.Then they would restart.I pulled every one and used a small screw and nut then taped the 2 wires together eliminating the amp meter.Then install a volt meter
Chrysler Firepower
Re: Starter relay causing ignition problem [Re: chargers777] #3198135
12/17/23 01:32 PM
12/17/23 01:32 PM
A good volt Ohm meter and knowing how to use it are your friend on every electrical problems on our vehicles. scope wrench up
Re: Starter relay causing ignition problem [Re: Cab_Burge] #3198291
12/17/23 11:38 PM
12/17/23 11:38 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
No, the starter relay will not cause the car to die.The "I" terminal is the start signal from the ignition switch.
Re: Starter relay causing ignition problem [Re: Jim_Lusk] #3198292
12/17/23 11:45 PM
12/17/23 11:45 PM
Nashport, OH
Nashport, OH
I asked because a guy on YouTube said ignition relay was shorting out internally and caused his truck to die. Getting voltage to the coil. Of course I checked that. Problem is intermittent making typical voltage checks difficult.
Re: Starter relay causing ignition problem [Re: ruderunner] #3198304
12/18/23 03:32 AM
12/18/23 03:32 AM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
That’s just in lates 70 setup, where the ballast bypass comes from starter relay instead the ign switch like previous years. But by 74 the ballast bypass still comes straight from ign switch.
So by 74 there is no any kind of connection between starter relay and ign system where a short could make anything on ign system
Re: Starter relay causing ignition problem [Re: chargers777] #3198349
12/18/23 10:49 AM
12/18/23 10:49 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Not saying this is the issue but we chased a random / topend misfire on my wifes '68 Barracuda for a while, it would also cut out going round corners from time to time. Turned out to be the key ign switch.
Re: Starter relay causing ignition problem [Re: chargers777] #3198359
12/18/23 11:30 AM
12/18/23 11:30 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
When this happened to me it was the bulkhead connector. Pull it off and look for corroded, melted or burnt terminals. As Cab said a volt meter or even a 12v test light can be used to track down problems like this BEFORE you start swapping or buying parts.
Re: Starter relay causing ignition problem [Re: chargers777] #3198483
12/18/23 10:25 PM
12/18/23 10:25 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
hang a temporary light bulb inside somewhere visible and see what it does when the issue occurs wink
Re: Starter relay causing ignition problem [Re: ruderunner] #3198509
12/19/23 01:20 AM
12/19/23 01:20 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Some times after the pickup coil gets hot, being inside distributor, it will lose conductivity.
After cools somewhat, reestablishes conduct.
Bad wires, or an internal connection, possible.
Put ohmmeter on plug & wiggle around to see.
Or just replaces with new.
Re: Starter relay causing ignition problem [Re: chargers777] #3198510
12/19/23 04:40 AM
12/19/23 04:40 AM
The starter relay switch is a safety device intended to not let anyone engage the starter without the transmission being in in park or neutral. It is not involved in the ignition run circuit with the ignition switch in the run circuit, it is involved in the start circuit scope work twocents
Re: Starter relay causing ignition problem [Re: Cab_Burge] #3198696
12/19/23 06:33 PM
12/19/23 06:33 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
That's neutral safety switch.
For many years Dodge trucks did take the resistor bypass from the starter relay. Possibly not in a 74 though per one poster here.I don't have a diagram for that year.
Re: Starter relay causing ignition problem [Re: ruderunner] #3198764
12/19/23 10:46 PM
12/19/23 10:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Neutral safety switch supplies the ground for the starter relay. which has to be grounded to work therefore the safety device part.With a standard trans you can just ground the starter relay.
Re: Starter relay causing ignition problem [Re: stumpy] #3198815
12/20/23 09:58 AM
12/20/23 09:58 AM
St. Louis, Mo
3
318 Stroker Offline
318 Stroker  Offline
St. Louis, Mo
I had the same problem with my 73 Challenger. Car would run for 30 minutes or so, then die. Had to wait about 15 minutes before it would restart. Turns out it was the ignition switch.
Re: Starter relay causing ignition problem [Re: ruderunner] #3198897
12/20/23 03:23 PM
12/20/23 03:23 PM
The neutral safety switch, depending the car year and model will be either in the tranny or on the steering collum, the starter relay that activates the starter solenoid from the ignition switch is usually mounted on the firewall scope
