Bench testing gauges #3198164
12/17/23 04:04 PM
12/17/23 04:04 PM
MN
JERICOGTX Offline OP
MN
Has anyone ever bench tested their gauges before installing into the dash? If so how did you do it? I’d like to test mine before installing in the dash frame.
Thanks.
69 GTX 68 Road Runner
Re: Bench testing gauges [Re: JERICOGTX] #3198204
12/17/23 06:35 PM
12/17/23 06:35 PM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Here is a step by step article showing how to build a gauge tester and how to use it. It also has a video demo.
https://moparconnectionmagazine.com...t-2-testing-restoring-the-gauge-cluster/
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: Bench testing gauges [Re: MOPARMIKE69] #3198322
12/18/23 09:28 AM
12/18/23 09:28 AM
Canada
E
EW1BH27 Offline
EW1BH27  Offline
E
Canada
I bench tested everything on an Ebody rallye dash before selling it using a car battery and a 5 volt power supply.
Speedometer: spare speedo cable and drill
Clock: + / - connections using the battery
OIL, FUEL, TEMP: + / - connections using the 5v power supply, just looking for movement not accuracy.
ALT: I put 2 road lamps in series with the ammeter and battery, the needle deflected to "D" (as pictured).
Re: Bench testing gauges [Re: EW1BH27] #3198328
12/18/23 09:49 AM
12/18/23 09:49 AM
MN
MN
Thanks for the help guys. I only have to test the fuel, water, and amp gauge. That's all the car has.
Re: Bench testing gauges [Re: JERICOGTX] #3198774
12/19/23 11:07 PM
12/19/23 11:07 PM
Hinckley, Ohio
KWF340 Offline
KWF340  Offline
Hinckley, Ohio
Here ya go.
Calibration Link
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
