Will this AC hose crimper do the job?
#3197733
12/15/23 02:02 PM
12/15/23 02:02 PM
Posts: 4,748 Florida
BDW
I'm going to be hooking up my AC, not a factory install, so I'll be figuring it as I go. Anyone have experience with these low cost crimpers? I don't need a commercial grade tool to last a lifetime. Would this meet the need? REDLOONG hydraulic hose crimper ac crimping tool machine with dies Handheld Hydraulic Hose Crimping Tool Hydra-Krimp 71500 Manual A/C Hose Crimper Kit Air Conditioning Repair https://www.amazon.com/dp/B09W8HT3N...ent=4&dealEvent=1&language=en-US
Re: Will this AC hose crimper do the job?
[Re: RJS]
#3198000
12/16/23 04:31 PM
12/16/23 04:31 PM
Posts: 15,462 Omaha Ne
TJP
Omaha Ne
Search around I bought a differen t brand for less $$$ but looks and functions exactly the same. They work perfectly and much better than the bench vise type when and if you ever have to work on an existing system in a car. Ron Agreed, doesn't look like there is much difference price wise
[Re: Moparite]
#3198058
12/16/23 09:24 PM
12/16/23 09:24 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Visit a hydraulic hose shop, Get the fittings and measure how much hose you need for each and have them crimp them. Waste of time. To many variables going back and forth to a shop. Buying the tool will accomplish the job. I did a custom job when I bought my Chinese knock off hydraulic crimper and it was worth every penny.
[Re: TJP]
#3198088
12/17/23 09:04 AM
12/17/23 09:04 AM
Posts: 1,007 rust belt
Moparite
rust belt
Waste of time. To many variables going back and forth to a shop. Buy the fittings and the length of hose you need to make all of them. Do all the figuring and mark the hose-fitting configuration. Then take them to get crimped. I would trust the crimper more at the hydraulic shop than something you got off Amazon/ebay. If it doesn't crimp it tight enough and leaks is it a waste of time then?
[Re: Moparite]
#3198100
12/17/23 10:41 AM
12/17/23 10:41 AM
NITROUSN
Waste of time. To many variables going back and forth to a shop. Buy the fittings and the length of hose you need to make all of them. Do all the figuring and mark the hose-fitting configuration. Then take them to get crimped. I would trust the crimper more at the hydraulic shop than something you got off Amazon/ebay. If it doesn't crimp it tight enough and leaks is it a waste of time then? That tool will do the job as well as any hydraulic shops tools. Having the tool allows you to be able to make necessary fitment of the line. To many times I have had lines done and then installing you wish they were just a little longer a little shorter or turned a few degrees left or right. I put the fitting on one end then fit the hose. Cut it, slide the end on and recheck fitment. Then do the final crimp. My tool has been paid for 3 times over with tips and beer helping other friends.
[Re: NITROUSN]
#3198114
12/17/23 12:21 PM
12/17/23 12:21 PM
Posts: 6,224 JERSEY
RJS
JERSEY
Owning the tool for $100, (I think mine was $85) is well worth the freedom to do what you want when you want and these tools make perfect crimps or I wouldn't recommend it here to another user. Having to deal with going to a shop is timely and costly period. Ron
[Re: RJS]
#3198138
12/17/23 01:43 PM
12/17/23 01:43 PM
Posts: 6,292 nowhere
Sniper
nowhere
Owning the tool for $100, (I think mine was $85) is well worth the freedom to do what you want when you want and these tools make perfect crimps or I wouldn't recommend it here to another user. Having to deal with going to a shop is timely and costly period. Ron I wonder how much having all those crimps done at a shop, even of perfect the first time out, will cost? Will it get close enough to the cost of the tool, not even taking your time into account, to make it worthwhile to just buy the tool, even of only for one job? I mean we are talking at least 6 crimps? More if you run rear AC too.
[Re: Sniper]
#3198270
12/17/23 09:13 PM
12/17/23 09:13 PM
BDW
I spent 8hrs today struggling to get done what I expected to only take 2hrs. And all I did was put in the condenser, not a single hose, nothing else, just mounted a condenser. This definitely made up my mind to get the crimper. I have absolutely no doubt there will be several hiccups along the way. With work, I don't have the opportunity to make multiple trips to a shop to fix all my mistakes. I'll be able to do it myself when time permits. Down to these 2 and can't see a difference, same manufacturer, 1 blue and the other is black. Why the $25 price difference? IBOSAD Hydraulic AC Hose Crimper Hydra-Krimp 71500 Manual A/C Hose Crimper Kit Air Conditioning Repaire Handheld Hydraulic Hose Crimping Tool for BH Air Conditioner Hose & Beadlock A/C Fittings https://a.co/d/eKbvQOjIBOSAD Hydraulic Hose Crimper Hydra-Krimp 71500 Manual A/C Hose Crimper Kit Air Conditioning Repaire Handheld Hydraulic Hose Crimping Tool https://a.co/d/0Wck2Ql
[Re: BDW]
#3198277
12/17/23 10:40 PM
12/17/23 10:40 PM
TJP
Omaha Ne
I spent 8hrs today struggling to get done what I expected to only take 2hrs. And all I did was put in the condenser, not a single hose, nothing else, just mounted a condenser. This definitely made up my mind to get the crimper. I have absolutely no doubt there will be several hiccups along the way. With work, I don't have the opportunity to make multiple trips to a shop to fix all my mistakes. I'll be able to do it myself when time permits. Down to these 2 and can't see a difference, same manufacturer, 1 blue and the other is black. Why the $25 price difference? IBOSAD Hydraulic AC Hose Crimper Hydra-Krimp 71500 Manual A/C Hose Crimper Kit Air Conditioning Repaire Handheld Hydraulic Hose Crimping Tool for BH Air Conditioner Hose & Beadlock A/C Fittings https://a.co/d/eKbvQOjIBOSAD Hydraulic Hose Crimper Hydra-Krimp 71500 Manual A/C Hose Crimper Kit Air Conditioning Repaire Handheld Hydraulic Hose Crimping Tool https://a.co/d/0Wck2Ql maybe the cheaper one was pre current uhh bitem 🤣🤣🍻
[Re: RJS]
#3198563
12/19/23 11:54 AM
12/19/23 11:54 AM
Posts: 19,535 north of coder
moparx
over the years, i have bought tools such as this for one time job use, and have been quite impressed with the function of them, as well as being in house hose routing and fitting selection. just my personal experience. your mileage will vary.
