Re: Aluminum Hemi Indy Maxx block HELP
[Re: maximus]
#3196088
12/08/23 02:38 PM
12/08/23 02:38 PM
Posts: 2,645 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
I drilled the block deck corner holes out to 3/8" because that's what someone told me to do. Stock street hemi is 7/16", KB is 1/2" but I didn't want to drill bigger than I was told for obvious reasons. I can't tell you all the hassles I had out of that block. Russ was the biggest POS that ever lived.
2011 Drag Pak Challenger
[Re: earlymopar]
#3196222
12/09/23 10:41 AM
12/09/23 10:41 AM
rickseeman
Stuttgart, Arkansas
He is a photo of the 1" hole in the china wall and the opened up lifter valley holes I did in the response to advise from Todd Marsh and others. Without these mods (and the deck mods) the engine ran out of oil in 45 seconds after startup with oil pouring out around around all the lower valve cover bolt holes. This was after spending a day trying to get the engine in the car. I had 3 brands of starters. None would fit the block. A lot of time was spent grinding and trying different starters. By the way, the engine sat crooked in the car. I worked a month on that. (Never did get it straight.) I can't say enough bad things about Russ.
[Re: maximus]
#3196863
12/12/23 12:36 AM
12/12/23 12:36 AM
rickseeman
Stuttgart, Arkansas
Wow, I'm having a little trouble understanding that. Can you back up a little for a photo? What is the other side like?
