Re: A-body center link question
[Re: 6PAX]
#3196260
12/09/23 02:41 PM
12/09/23 02:41 PM
Posts: 6,291 nowhere
Sniper
nowhere
I know, at one point, that V8 A bodies used a dropped center link and slant A bodies did not. At some point they commonized on the V8 one, not sure when that happened though. I want to say it was in 73, because when I swapped a 360 into my 72 Dart to replace the slant I believe I changed out the center link as well, but that was in 93, so I might be misremembering.
So I went digging into the parts manuals, 1966 is th last year that my manuals call out a different center link for a 6 or and 8, so you should be good.
[Re: topside]
#3196362
12/09/23 09:44 PM
12/09/23 09:44 PM
Posts: 20,699 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
From what I'm seeing looking here and on FABO the 67-72 are the same regardless of the engine. In 73 they changed the design and those are also the same slant 6 or V8. No such thing as a V8 center link from 67 and up basically. https://board.moparts.org/ubbthread...4053/center-link-differences-a-body.htmlYears ago there was some discussion on here about guys selling V8 center links in the for sale section taking advantage of slant six owners doing V8 swaps thinking they needed the V8 center link.
[Re: Neil]
#3196393
12/10/23 01:35 AM
12/10/23 01:35 AM
Posts: 2,079 CA
crackedback
CA
From what I'm seeing looking here and on FABO the 67-72 are the same regardless of the engine. In 73 they changed the design and those are also the same slant 6 or V8. No such thing as a V8 center link from 67 and up basically. https://board.moparts.org/ubbthread...4053/center-link-differences-a-body.htmlYears ago there was some discussion on here about guys selling V8 center links in the for sale section taking advantage of slant six owners doing V8 swaps thinking they needed the V8 center link. Correct 67-72 and 73-76 no difference. Only the 63-66 cars used a different link between /6 and V8 cars.
[Re: 6PAX]
#3196533
12/10/23 05:34 PM
12/10/23 05:34 PM
Sniper
nowhere
The k-member is a Direct Connection big block spool mount. The steering linkage and power steering box are the originals that were on the car. I forget the details of the DC k member, what is is based on? 73 and up K member? If so, maybe that's the issue?
[Re: Jim_Lusk]
#3196589
12/10/23 10:36 PM
12/10/23 10:36 PM
Posts: 5,645 Detroit area
6PAX
Detroit area
The center link will hit there without massaging the pan. I don't know how different the factory big block pan is, but it is different. BUT, if you use a '73-76 center link and associated idler and pitman arms you can run just about any passenger car pan. I have a B-body baffled pan (no notch) in my Barracuda with the 440. My car already had complete '73 suspension/steering parts. I thought about using a later steering setup but it will be a nightmare getting the current steering box out and replacing it with the later box. Should have went with all the 73-up parts in the first place but I read several different threads that said it was no problem to use the earlier steering parts with the spool k-frame and 73-up brakes, control arms and spindles.
[Re: 6PAX]
#3196598
12/11/23 01:35 AM
12/11/23 01:35 AM
Posts: 27,471 So Cal
autoxcuda
So Cal
The center link will hit there without massaging the pan. I don't know how different the factory big block pan is, but it is different. BUT, if you use a '73-76 center link and associated idler and pitman arms you can run just about any passenger car pan. I have a B-body baffled pan (no notch) in my Barracuda with the 440. My car already had complete '73 suspension/steering parts. I thought about using a later steering setup but it will be a nightmare getting the current steering box out and replacing it with the later box. Should have went with all the 73-up parts in the first place but I read several different threads that said it was no problem to use the earlier steering parts with the spool k-frame and 73-up brakes, control arms and spindles. What about using the 73-76 A-body manual pitman? It’s small spline and the pitman stud points down. Then get a new 73-76 idler and a used 73-76 centerlink.
