Re: Will a 74 Duster 8.25 rear end fit a 71 Dart
[Re: Sniper]
#3195912
12/07/23 03:52 PM
12/07/23 03:52 PM
Posts: 74,978 U.S.S.A.
JohnRR
U.S.S.A.
It will bolt into the springs. Wheel bolt pattern will be different. Driveshaft length will be different probably too long, IIRC, odds are good the U joints are the same, 7260 type.
I can't remember if the shock mounting plates and U bolts will work from the 71, just use the 74 ones. Shocks will work. U bolts and shock plates will be different, also take note that the track width of the 8.25 is wider by roughly 3/4 inch.
