What causes a sluggish 1 - 2 shift, 727 TA valve body? #319525
05/16/09 09:20 AM
05/16/09 09:20 AM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
727 behind a small block. Nothing special about the tranny, bolt in sprag, TA reverse pattern valve body. the 1 -2 shift is sluggish but the 2 - 3 shift is quick and hard. It seems to shift solid it just doesn't go into 2nd right when you shift...
Any ideas?
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: What causes a sluggish 1 - 2 shift, 727 TA valve body? [Re: WadeMetzinger] #319526
05/16/09 10:41 AM
05/16/09 10:41 AM
off the grid
340B5 Offline
340B5  Offline
off the grid
Band adjustment, broken band, or maybe something binding in the actuator piston. Could be a piece of dirt in the valve body.
Yeah, it's got a smallblock.
Re: What causes a sluggish 1 - 2 shift, 727 TA valve body? [Re: 340B5] #319527
05/16/09 11:31 AM
05/16/09 11:31 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
I second band adjustment.
Re: What causes a sluggish 1 - 2 shift, 727 TA valve body? [Re: WadeMetzinger] #319528
05/16/09 12:56 PM
05/16/09 12:56 PM
Any ideas?
check the shifter adjustments, the pin on the cable clevis should drop into the shifter arm when adjusted correctly with no effort If it doesn't try adjusting it so it does on all three forward gears, one turn of the clevis on the cable can make the difference between working good and not shifting right
Re: What causes a sluggish 1 - 2 shift, 727 TA valve body? [Re: Cab_Burge] #319529
05/16/09 01:26 PM
05/16/09 01:26 PM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
also see if the band strut is bent...
Tony
70 AARCuda Vitamin C
