5.7 engine 2004 Ram #3194966
12/02/23 07:05 PM
12/02/23 07:05 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
My 04 Ram has 261,000 miles, it runs great but I'm wondering how long it will go.
It uses maybe a quart of oil between 7500 mile oil changes. Are these engines rebuild able?
Some say yes, some say no.
Re: 5.7 engine 2004 Ram [Re: MO_PA] #3194981
12/02/23 08:00 PM
12/02/23 08:00 PM
okla.
sam64 Offline
sam64  Offline
okla.
If you have got that many miles out of an 04 drive it till it quits,then buy a reman engine.
Re: 5.7 engine 2004 Ram [Re: sam64] #3194986
12/02/23 08:13 PM
12/02/23 08:13 PM
Big Sky Country
MO_PA Offline OP
MO_PA  Offline OP
Big Sky Country
That's what I've been thinking, Thanks!!
Re: 5.7 engine 2004 Ram [Re: MO_PA] #3194997
12/02/23 08:50 PM
12/02/23 08:50 PM
Central Michigan
N
nuthinbutmopar Offline
N
Central Michigan
The Hemi in my '04 Durango was running great at 135k miles. Left Home Depot one day, made a left at the next stoplight and it coughed and stalled. Popped it in N and cranked it back up, but it had a miss and was smoking from under the hood. Called my towing guy to bring a rollback, drove it on, started it up before we unloaded it at the house, looked at the engine from underneath and saw a hole in the right side of the block. I drove it into the garage to swap the engine. Number 5 rod broke and punched windows in BOTH sides of the block just above the pan rail. No coolant or oil leaks. I've got 2 other Hemis now, one with 217k. Same plan, drive it until it pops and swap it out.
Re: 5.7 engine 2004 Ram [Re: nuthinbutmopar] #3195094
12/03/23 12:28 PM
12/03/23 12:28 PM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
I'm surprised you made it to 200k. I had an 04...the engine was fine but the rest of the truck wasn't. I replaced more parts on that truck than all my other trucks combined. I sent it down the road at 70k
Re: 5.7 engine 2004 Ram [Re: Dcuda69] #3195099
12/03/23 12:49 PM
12/03/23 12:49 PM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Getting close to 130k on the 03 5.7 in my 55 Dodge pickup. Still running like the day I put it in. Only problem is occasional flooding on start when engine is warm. Put throttle to the floor and it starts. Probably computer related.
Re: 5.7 engine 2004 Ram [Re: nuthinbutmopar] #3195139
12/03/23 03:32 PM
12/03/23 03:32 PM
A Red State
SNK-EYZ Offline
SNK-EYZ  Offline
A Red State
What happens on that era (2004-2006) Durango is that water runs down off the cowl and drips on the intake and when the engine has over 100k miles it seeps past the intake port o-ring and ends up in a cylinder.
It hydraulic locks that cylinder on start up and the powder forged rods break and sometimes split out the side of the block.
When I bought a really clean 2004 Durango that had done that is when I got educated on how often it happens.
Search the internet and you see it's pretty common, usually after a hard rainstorm. laugh2
Re: 5.7 engine 2004 Ram [Re: SNK-EYZ] #3195306
12/04/23 01:52 PM
12/04/23 01:52 PM
5thAve Offline
5thAve  Offline
My 04 has been a pretty reliable truck, no complaints from me. The biggest repair I've ever done to it was the oil pan started rusting pretty bad.
Re: 5.7 engine 2004 Ram [Re: 5thAve] #3195491
12/05/23 02:38 PM
12/05/23 02:38 PM
moparx Offline
moparx  Offline
rusty oil pans have amazed me for some time, not just on ram pickups.
on a couple of caravans i have owned over the years, if one looks close at the paint when it starts to lift off the pan, it seems like a kind of powder coat, so ???? shruggy
beer
Re: 5.7 engine 2004 Ram [Re: moparx] #3195498
12/05/23 03:21 PM
12/05/23 03:21 PM
5thAve Offline
5thAve  Offline
The only other time I had a rusted pan was on a 350.
The hemi one was double layer (maybe that says something) and would have probably lasted quite a while longer but you couldn't tell that without removing it and it looked bad enough we didn't want to poke at it much.
Re: 5.7 engine 2004 Ram [Re: 5thAve] #3195595
12/06/23 01:09 AM
12/06/23 01:09 AM
Dandridge TN
Dabee Offline
Dabee  Offline
Dandridge TN
Had a 84 D150 318 tha was my winter beater in Michigan. After moving to Tennessee while changing the oil I noticed the pan had some rust pin holes in it and was leaking. Cleaned it real good with carb cleaner and spread Right Stuff over the bad area. Temporarily fix until I could replace the pan. Never got around to replacing the pan and drove that truck five more years before selling it. Pan never leaked again.
Re: 5.7 engine 2004 Ram [Re: Dabee] #3195785
12/06/23 10:09 PM
12/06/23 10:09 PM
Central Michigan
N
N
Central Michigan
I bought a 2017 Promaster City with the 2.4L in 2020, with 120,000 miles. After the first oil change I replace the pan because it was so far gone. It's not unique to Mopars either. When I ran the local city vehicle fleet, we had all International dump trucks, both single and tandem axle, all with the DT466. After the first one got to be about 5 years old, I started keeping an oil pan and a set of bolts (like 28 of them in 2 different sizes) in inventory. Not only would the pans rust out, the bolt heads would rust away. We didn't use any of the high-tech ice melt products, just plain old salt from the Detroit salt mine. The rest of the undercarriage would still be painted black with the oil pan rusted and seeping oil...
Re: 5.7 engine 2004 Ram [Re: nuthinbutmopar] #3195817
12/07/23 06:55 AM
12/07/23 06:55 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
The oil pan is much higher temperature than the rest of the painted metal undercarriage.
I guess it is the combination of hot, acid water and salt.
This is another spot where a replaceable “boat zinc” might be cost effective.
As much of a fan of stainless steel as I am, the salt would just create deep pits in a stainless steel oil pan.
