Page 1 of 3 1 2 3
Flying magnet crank trigger VS dist., ATI magnet damper #3194756
12/01/23 08:57 PM
12/01/23 08:57 PM
Minnesota
Hemi_Joel Offline OP
Minnesota
I get it with the rear distributor small blocks. But on a Hemi or B/RB with the front distributor, does the crank trigger offer any proven advantage?
Has anybody used the ATI damper with the magnets in the outer ring to eliminate the extra magnet ring bolted on the front and save $$?
Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: Hemi_Joel] #3194774
12/01/23 09:53 PM
12/01/23 09:53 PM
AndyF Offline
AndyF  Offline
Yes, a crank trigger will provide more stable timing than a distributor. You can see the difference with a timing light.
FHO uses ATI dampers with the four magnets built in. I sell them a trigger bracket for that application. I used to sell the same bracket to Best Machine before they closed up. I've never seen a TCI damper.
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: AndyF] #3194786
12/01/23 10:37 PM
12/01/23 10:37 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I run a crank trigger with an ATI damper on one of my engines. Yes, it does help as mentioned, seen with a timing light.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: 6PKRTSE] #3194788
12/01/23 10:44 PM
12/01/23 10:44 PM
Minnesota
Minnesota
Oops, I meant ATI super damper, not TCI. TCI is the rattler.
Good info, thanks!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: Hemi_Joel] #3194793
12/01/23 11:02 PM
12/01/23 11:02 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
Thanks, Joel
The ATI with the magnets is soooo sexy. It's expensive, but that other stuff is so 1980's.
2011 Drag Pak Challenger
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: rickseeman] #3194796
12/01/23 11:32 PM
12/01/23 11:32 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Rock steady. Put a crank trigger on, you will never go back.
I always used a wheel with the magnets in it. No reason not to. Have spare engines, you can just swap the stuff as needed.
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: Hemi_Joel] #3194807
12/02/23 01:09 AM
12/02/23 01:09 AM
AndyF Offline
AndyF  Offline
Good info, thanks!
Talk to Tim at FHO is you're going to go that way. He should have the correct ATI damper in stock as well as the TDC pointer and trigger pickup assembly. I think I'm the only person that makes those parts although you could also fabricate your own setup. It isn't rocket science, but you do need the pickup in the correct location for the timing to be correct and it does need to be adjustable since moving the trigger is how you change the timing. Rotating the distributor only changes the rotor phasing when you use a crank trigger.
https://arengineering.com/home-page/crank-trigger
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: AndyF] #3194808
12/02/23 01:10 AM
12/02/23 01:10 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Andy, what is the part number for that bracket? Does it come with the pick up?
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: CMcAllister] #3194809
12/02/23 01:12 AM
12/02/23 01:12 AM
AndyF Offline
AndyF  Offline
Depends on what is going on in terms of pulley spacing or what else is being driven off the front. There are a lot of reasons to get rid of the magnet wheel such as dry sump engines or engines that don't have much space for pullies.
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: mopar dave] #3194810
12/02/23 01:13 AM
12/02/23 01:13 AM
AndyF Offline
AndyF  Offline
There are different brackets for different setups and different pickups. I don't sell pickups, you'll have to get them from MSD or Holley depending on which ignition system you are using.
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: AndyF] #3194866
12/02/23 11:41 AM
12/02/23 11:41 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
BMP aluminum hemi. Thanks
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: mopar dave] #3194872
12/02/23 11:55 AM
12/02/23 11:55 AM
AndyF Offline
AndyF  Offline
The block doesn't matter, the bracket used depends on the timing cover. Billet cover, Jesel cover, etc.
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: Hemi_Joel] #3194876
12/02/23 12:13 PM
12/02/23 12:13 PM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
In an NA application, I can't imagine it would make any difference on the time slip. Unless you're running nitrous on the ragged edge, what's the justification for it? Rock steady timing is neat, but if your timing jumps around that much you need a new chain.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: A39Coronet] #3194881
12/02/23 12:58 PM
12/02/23 12:58 PM
Minnesota
Minnesota
I assume the timing locked out with a crank trigger. How does that work out in a street car?
Andy, if the magnets are in the damper, do you make the bracket thinner to compensate?
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: Hemi_Joel] #3194899
12/02/23 02:06 PM
12/02/23 02:06 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Works great. Idles at 800 in gear at a light with the biggest cam.. Throttle response is sharp. Runs great. Might have to use a start retard. Might.
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: A39Coronet] #3194902
12/02/23 02:18 PM
12/02/23 02:18 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Chain, gear slop, driveshaft moving around, oil pump affecting the whole mess. Plus cam twist if it's a small block. If you're okay with it moving around a couple degrees, then it doesn't matter.
Crank trigger, what you see with a timing light is like a snapshot. Zero movement.
With the ignition stuff available now, you can set the base timing ahead of where you want it and dial in a retard curve. Some guys I know are using various amounts of retard at different places on the track. No reason it couldn't be done on the street. Even dialing in the timing precisely on each cylinder, if you are collecting data.
Re: Flying magnet crank trigger VS dist., ATI magnet damper [Re: Hemi_Joel] #3194925
12/02/23 03:39 PM
12/02/23 03:39 PM
AndyF Offline
AndyF  Offline
I sell a different bracket for that application. Part number is on the website or contact Tim at FHO.
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: AndyF] #3194928
12/02/23 03:54 PM
12/02/23 03:54 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Ok, i get it now. Using the Milodon gear drive combo.
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: mopar dave] #3194940
12/02/23 05:35 PM
12/02/23 05:35 PM
AndyF Offline
AndyF  Offline
You'll probably need something custom to fit a gear drive. Could start with one of my parts and have it modified by a machine shop to fit the gear drive.
Re: Flying magnet crank trigger VS dist., TCI magnet damper [Re: AndyF] #3195018
12/02/23 10:53 PM
12/02/23 10:53 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Thanks.
Page 1 of 3 1 2 3
