Will this tire be enough? #3194192
11/29/23 03:46 PM
11/29/23 03:46 PM
Suffolk County, New York
1mean340 Offline OP
1mean340  Offline OP
Hey everyone, could use some advice in choosing a tire for my 70 challenger. I knew I should have done the mini tub while I was doing some of the rust repair work, but I couldn't take the stench of burning factory undercoating permiating my house anymore and now the rear is all powder coated LOL
The setup is a 2018 Hellcat pullout, MMX cam, ATI 10% lower, E85. Should make around 800whp now, but may possibly do an upper pulley in the future for a little more power. I'm using the 8HP90 trans
Strange S60 w/ 3.23 (lowest I could put in it)
1' offset hangers/b body width
2nd gear in the 8hp90 is 3.1, I'd be launching from 2nd.
the issue I have is speaking to Mark Williams, the critical speed of the slip section driveshaft will be somewhere in the neighborhood of 6500 RPM's.
Originally I wanted to run a 325/50/15 ET street R (I like to drive the car on the street as well as to and from the track). I could fit it just BARELY, but it should work. I'm a little concerned about the height though, I think the car will benefit from a taller tire and it'll keep me further away from critical speed
I don't think i'll be able to fit a 315/60/15 ET-R with the added height and width, so the only taller option I have is a 295/65/15 which gives up a bit of tread width.
DS speed of 6500 occurs at 168 mph with the 28" tire
DS speed of 6500 occurs at 180 mph with the 30" tire
Do you guys think a 295/65/15 is going to be enough tire for this car? I know the rollout will help along with reducing the effective gear ratio, but just worried about giving up the width. I think I really need to run a 30" tire, that brings me to about the same effective gear ratio as a factory Hellcat with a 28" tire and 3.09 rear so I know it should work decent. Just don't know if it's enough tire to plant the power with caltracs.
Re: Will this tire be enough? [Re: 1mean340] #3194220
11/29/23 05:31 PM
11/29/23 05:31 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Car weight w/ driver?
Front and rear suspension?
Street car or race car with license plates?
People are laying down amazingly quick passes on 275/60R15 "pro style" DOT radials, but those cars are seriously scienced out. If the chassis doesn't work, it really doesn't matter how much meat you stuff under it.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: Will this tire be enough? [Re: Brad_Haak] #3194238
11/29/23 07:19 PM
11/29/23 07:19 PM
1mean340 Offline OP
1mean340  Offline OP
Your guess is as good as mine for race weight. I never weighed it with the old setup, but it’s manual everything with no AC, RMS front end, all steel except for the hood and I welded in a mild steel 8.5 cert cage and some pretty hefty rectangle stock subframe connectors. .
Some pretty significant weight shaved off between the weld wheels, seats, hood, k member but then a lot added back with the cage and who knows how much the 6.2/8hp90 weighs.
I’m planning for it to be a street car that sees the track fairly often but can still be driven sort of comfortably there
I would imagine the weight would be around 3450 without me in it but I could be wrong,
Read is caltracs mono leaf with their low profile sliders.
First time using caltracs so really not sure what to expect.
Re: Will this tire be enough? [Re: 1mean340] #3194271
11/29/23 08:34 PM
11/29/23 08:34 PM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
Almost every fast leaf spring racer uses Caltracs, you should be good to go there, especially if you have stiffly valved adjustable shocks in the rear.
I wouldn’t sweat 20 mm of tire at all, guys are running mid 4’s in the 8th on a 235 drag radial, but it takes lots of work with the tune and suspension at that level.
I would expect yours is going to need at least some power management on the starting line though- between the trans, the explosive power delivery of a supercharger, and I assume a tighter converter than a normal street strip 727. On a radial prepped track it will be ok but on a normal t&t night it might be a struggle.
Re: Will this tire be enough? [Re: 1mean340] #3194289
11/29/23 09:14 PM
11/29/23 09:14 PM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Tires are only one part of the equation. Not the only part. And has been pointed out here, some really impressive numbers are being laid down with those tires. But they have spent a lot of time to get the rest of the combo right.
Master, again and still
Re: Will this tire be enough? [Re: DaveRS23] #3194337
11/29/23 11:44 PM
11/29/23 11:44 PM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
With good shocks and a free moving suspension - no problem. I have seen more power on a 275 radial at no prep so you should be good to go with a prepped track.
Re: Will this tire be enough? [Re: Jeremiah] #3194416
11/30/23 11:06 AM
11/30/23 11:06 AM
MI
I
IROC78 Offline
IROC78  Offline
I
MI
Keep in mind that the 315/60/15 is slightly narrower and also taller than the 325/50/15. If I am reading your post correctly, if the 325/50/15 is just a tad too wide, and you want something slightly taller, the 315/60/15 may be just what you're looking for.
Re: Will this tire be enough? [Re: IROC78] #3194499
11/30/23 02:12 PM
11/30/23 02:12 PM
1mean340 Offline OP
1mean340  Offline OP
Thanks everyone, sounds like I might be able to make it work (with some work on the suspension tuning, which I figured would be the case). The car should be set up pretty good to hook with the coil over/double adjustable shocks up front, caltracs adjustable shocks out back and the split mono leaf/caltrac slider so it'll just me a matter of me getting it sorted out.
IROC78, I know plenty of guys have run the 325/50/15 with this setup and my measurements seem to confirm that. the 315/60/15 has a slightly wider section width though (despite the tread width being narrower). M/T says the section width is only wider by something like .3 IIRC but I think the height combined with the added section width would get me. I think the issue would come from where the inner wheel houising tapers into the 1/4 panel lip, the added height would put it much closer to that tapered section.
I could be wrong and it might fit, but from what i've heard the 325/50/15 is a very tight fit, so I would assume .3" wider and a whole 2" inches taller in diameter would be too much. I could be wrong, but it would be so close I think I'd need a tire for mockup to make a determination and I don't know if it's worth looking for one when i'm almost positive it won't fit without rubbing pretty bad.
If anyone has successfully done it though, please chime in as that might give me some motivation to find a mockup tire and see if it'll work on mine.
Re: Will this tire be enough? [Re: 1mean340] #3194503
11/30/23 02:29 PM
11/30/23 02:29 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Dizusters 62 Turbo Savoy hooked fine with the same M/T 275/60-15 driven on the street Cal tracks, good shocks, trans brake, 9.55@142
Doug
Re: Will this tire be enough? [Re: 1mean340] #3194519
11/30/23 03:50 PM
11/30/23 03:50 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
My friend Douglas' '70 runs MT 295/65R15s. I like the taller tire myself, but I don't have the gears and/or cubes to pull that so I stick w/ 275/60R15s. That's his car below.
Re: Will this tire be enough? [Re: 1mean340] #3194639
12/01/23 09:31 AM
12/01/23 09:31 AM
an8sec70cuda Online content
an8sec70cuda  Online Content
I run the 295-65 M/T ET Street R radial on my cuda. It weighs around 3800 lbs and has been 8.70s at 156+ mph. It will go just as fast on a 275-60. twocents
CHIP
'06 GMC 2500HD LBZ Duramax
Re: Will this tire be enough? [Re: an8sec70cuda] #3194682
12/01/23 12:51 PM
12/01/23 12:51 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
315/60/15"s on mine. It is amazing the times being run these days on little 275's and 28x10's.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Will this tire be enough? [Re: 6PKRTSE] #3194712
12/01/23 04:10 PM
12/01/23 04:10 PM
Cab_Burge Online work
Cab_Burge  Online Work
How about them guys on 235 shock bow up scope
Re: Will this tire be enough? [Re: Cab_Burge] #3194713
12/01/23 04:18 PM
12/01/23 04:18 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
Yes, them too.
Re: Will this tire be enough? [Re: 6PKRTSE] #3194743
12/01/23 07:26 PM
12/01/23 07:26 PM
London, England
mopar_mark Offline
mopar_mark  Offline
London, England
I used to run MT Street Radial 315 60 15, but no longer available, also not allowed in our Street Eliminator Class, This season we all switched to MT Street Radial 295 60 15.
Initially, I was concerned in going to a smaller width tyre, but has been great & no issues. My PB o 295 to date is 7.40 @204.
Most of the cars in our class also run the 295, with 4 Bar, most are within the 1.15 to Low 1.20’s range for 60fts
