Re: 79 RamCharger 4x4
[Re: cudaman1969]
#3194626
12/01/23 06:48 AM
12/01/23 06:48 AM
Guitar Jones
You just need to change the output shaft and extension housing.
[Re: Guitar Jones]
#3194665
12/01/23 11:29 AM
12/01/23 11:29 AM
Posts: 19,480 north of coder
moparx
You just need to change the output shaft and extension housing. in other words, use the above on the big block transmission. i did this on a 440 swap back in the late 70's on my 318 engine'd 72 w100.
[Re: volaredon]
#3194776
12/01/23 09:57 PM
12/01/23 09:57 PM
Posts: 5,886 ohio
ruderunner
ohio
There was, long ago, a kit to convert the small lug pattern full time axles to lockouts.
You'll have a better chance of winning the lottery.
IF you already have the larger lug pattern, then yes you can add lockouts, use parts from 85 to 93 plus the hubs, or 80 to 84.
Or plans on a rear axle swap and matching wheels.
Fwiw, keep the existing 203 case and full-time 4wd. You don't save enough to make a conversion worthwhile.
Angry white pureblood male
[Re: ruderunner]
#3194790
12/01/23 10:50 PM
12/01/23 10:50 PM
Guitar Jones
You also need to do something with the transfer case as the 203 case needs both axles engaged to work. You could swap to a 205 case but the adapter housing is different. After that you could also use everything off a mid 80's Chevy on the front axle housing, knuckles, spindles, stub shafts, hubs, rotors and brakes. The up side to that is you can still buy hubs for the Chevy stuff, the Dodge stuff not so much.
[Re: cudaman1969]
#3194842
12/02/23 08:00 AM
12/02/23 08:00 AM
Posts: 5,886 ohio
ruderunner
ohio
Even if it was a long distance truck, converting to part time is a waste of time and money.
[Re: ruderunner]
#3194991
12/02/23 08:28 PM
12/02/23 08:28 PM
Guitar Jones
Even if it was a long distance truck, converting to part time is a waste of time and money. I can attest to this. I spent over $2K installing the free spin hubs on my '06 2500 Cummins quad cab, didn't even get a 0.8 MPG increase.
