stock 69 B body shifter converted to Slap stick for RMVB??? #3194465
11/30/23 01:05 PM
11/30/23 01:05 PM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Just put a RMVB trans in the GF's 69 GTX. Id really like to keep the console and original shifter (stock look) Has anybody modified one to work like a slap stik but for a RMVB?
Re: stock 69 B body shifter converted to Slap stick for RMVB??? [Re: mercman1] #3194471
11/30/23 01:19 PM
11/30/23 01:19 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
I can't tell you how well it works, but CRT offers this: https://www.coperacingtrans.com/?product=crt-shift-r-gate-66-70-floor-shifter-copy
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: stock 69 B body shifter converted to Slap stick for RMVB??? [Re: Brad_Haak] #3194492
11/30/23 02:01 PM
11/30/23 02:01 PM
Connecticut
FurryStump Offline
FurryStump  Offline
Connecticut
Slap stick not really, put I modified my stock A body shifter to work with my RMVB. The way it now works is the shifter can be moved backward from neutral, through 1st, into 2nd without pushing on the button. I ground down the original Drive to 2nd step on the shifter. So now I launch in first and just smack the shifter back. It hits the original 2nd to manual 1st step and stops. When I want to shift 2nd to third. I push the button and pull it back into third. There is NOTHING stopping you from bumping/hitting the shifter forward into a lower gear or neutral. So be careful.
best of 11.24 at 119 mph 1.60 60’. 68 340 S Barracuda Fastback F.A.S.T [IMG]http://i67.tinypic.com/2mnnnnt.jpg[/IMG]
Re: stock 69 B body shifter converted to Slap stick for RMVB??? [Re: Brad_Haak] #3194616
12/01/23 01:05 AM
12/01/23 01:05 AM
Dandridge TN
Dabee Online content
Dabee  Online Content
Dandridge TN
Don’t waste your money. I bought one for my 69 Bee and it sucked. Ended up putting a Hurst ratchet shifter in. Was all that hard to do. Just had to modified the counsel a little.
Re: stock 69 B body shifter converted to Slap stick for RMVB??? [Re: Brad_Haak] #3194855
12/02/23 10:28 AM
12/02/23 10:28 AM
Stuart FL
mercman1 Offline OP
mercman1  Offline OP
Stuart FL
Brad, This looks perfect! Thanks for passing on the "Mopar" Knowledge.
