71 b body wiper conversion #3193869
11/28/23 12:10 PM
11/28/23 12:10 PM
Home of the Bluegrass
MoparJunkie Offline OP
Hey guys, anyone have the part numbers for the wiper crank arm and wiper transmission for 3 speed 71 b bodies? I am converting it from 2-3 speed. I need the correct arm and linkage... I'm told I need a 2822290 crank arm, but I'm just trying to verify to buy the right ones.... TIA up
"It takes a Mopar to catch a Mopar”
1971 Roadrunner FJ6 Sassy Grass 505"RB, 18 spline 4 speed, and Dana 60 with 3.54
2022 Hellcat Charger Widebody Redeye Jailbreak: Hellraisin with 8 speed auto
Re: 71 b body wiper conversion [Re: MoparJunkie] #3193910
11/28/23 02:28 PM
11/28/23 02:28 PM
Western Colorado High Desert
moparmarks Offline
moparmarks  Offline
71 B would use the 077 variable speed motor.
Crank 2822289
Main link 3431102 from crank to the first pivot.
The 290 crank is for 2-spd
Desert Mopar Metal
Grand Jct. CO
970-261-7039
http://moparmark.com/
motormangj@gmail.com
Re: 71 b body wiper conversion [Re: moparmarks] #3193914
11/28/23 02:34 PM
11/28/23 02:34 PM
Thanks! What about the number for the arm that goes over the crank????
Re: 71 b body wiper conversion [Re: MoparJunkie] #3193930
11/28/23 03:35 PM
11/28/23 03:35 PM
BDW Offline
BDW  Offline
Getting ready to convert my 70, these are the notes I have:
For a conversion on a 1970-1971 E-Body or a 1971 B-Body from a 2-spd to a 3 or variable spd motor, you will have to replace the wiper motor crank with part #2822289, also the link from the motor to the drivers side pivot with part #2822293 (1970) or 3431102 (1971). Note the part #s are stamped in these parts. The 1970 link will work on the 1971 and vice versa.
Parts List:
Motor: 3431077
Crank: 2822289
Switch: 2770380
Link: 2822293 or 3431102 (These interchangeable)
Although different PNs the E body and 71 B body links are supposed to interchange.
I have the 3431102, so I'll find out.
Re: 71 b body wiper conversion [Re: BDW] #3193977
11/28/23 05:54 PM
11/28/23 05:54 PM
So, the arm from the pivots really doesn't matter as long as it bolts up? The part number I have on the straight link from pivot to pivot is 3431103.... Is that correct for a 71 RR?
Re: 71 b body wiper conversion [Re: MoparJunkie] #3194071
11/29/23 01:50 AM
11/29/23 01:50 AM
moparmarks Offline
moparmarks  Offline
Yes, the link between the pivots is the same for 2-spd and 3/V-spd and is 3431103 for 71.
Yes B and E use the same motor, crank and links. Pivots and wiper arms are different.
Desert Mopar Metal
Grand Jct. CO
970-261-7039
Re: 71 b body wiper conversion [Re: moparmarks] #3194097
11/29/23 08:54 AM
11/29/23 08:54 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
As stated above you can use the 3431102 1971 B-body 3 speed arm in place of the 3 speed E-body 2822293 arm and it will work...I have done it.
There is an ever so slightly different bend on the 3431102 arm and the one end is slightly different but both function as they should for 3 speed conversion on either.
Pictured E-body on top B-body on bottom
Re: 71 b body wiper conversion [Re: mccannix] #3194098
11/29/23 09:01 AM
11/29/23 09:01 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
Here is the 102 on top of the 293...both brass fittings line up perfectly
Re: 71 b body wiper conversion [Re: mccannix] #3194100
11/29/23 09:15 AM
11/29/23 09:15 AM
Awesome! Thanks for the info and pics!
