402 Magnum Crate engine
#3193865
11/28/23 11:59 AM
11/28/23 11:59 AM
Posts: 1,550 Michigan
Kiddart
Hi Moparts community. I have a Magnum create engine the 402 magnum. it is advertised at 9.5/9.75 to 1, pending where you are getting the info. I would like to wake it up just a little. if i changed the head gaskets to something just a little thinner would i be able to get around 10.5 to 1. and is the work going to be worth the effort. I can't find too much on this motor as they don't make the motor any more out of the catalog. I am trying to find the thickness of the current head gasket.
the car is a streetcar just a little on the slow side for my liking. it ran 12.50 this last fall at Ubly Dragway.
I don't really want to pull the motor apart to get very little gains. It is a really nice car and cruiser.
Thank you Kiddart
Re: 402 Magnum Crate engine
[Re: Kiddart]
#3193875
11/28/23 12:38 PM
11/28/23 12:38 PM
Posts: 4,672 Wichita
GY3
Wichita
I don't really want to pull the motor apart to get very little gains. It is a really nice car and cruiser. Sounds like a prime candidate for a 150 shot of nitrous!
