AC gauges, use 134A for R1234yf? #3193010
11/24/23 12:42 PM
11/24/23 12:42 PM
BDW Online content OP
BDW  Online Content OP
I have the HF AC gauges for 134A, go to check my daughters Hyundai and quickly find the hoses won't fit.
So I learn there is now a much more expensive freon, R123yf, good thing they made the fittings different.
I see I can buy the 1234yf fitting adapters for the 134 hoses, good or bad idea?
Any downside to the residual R1234yf in the lines for the next time I use it for 134?
Not interested in buying another gauge set for the 1234 freon.
Thx
Re: AC guages, use 134A for R1234yf? [Re: BDW] #3193022
11/24/23 01:24 PM
11/24/23 01:24 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Sorry I don't know the answer to the question but this smells a lot like the r-12 change to environmentally friendly 134 that is suddenly now BAD spank for the environment. Or is it we did it once, hmm about time to do it again and refill our banks accounts twocents
And the price of 134 is doing what r-12 did along with R U RDY 4 IT again ( What I call the "NEW" replacement).
keep in m mind it's not just the cost of the freon but the equipment required by all small business owners.
Watched the same thing in Ca. with the ever changing emissions laws. SBO buys a 50K machine that is useless 5 years later. This is not a political comment but rathe an observation of mine. Pleases delete if deemed to offensive or political twocents beer
Re: AC guages, use 134A for R1234yf? [Re: TJP] #3193032
11/24/23 01:44 PM
11/24/23 01:44 PM
IMGTX Offline
IMGTX  Offline
I agree this is another money grab by dupont or whomever. If you follow the patents , patent expiration and regulation changes by date it seems more corrupt than environmentally friendly. I'll stop there.
As for the Y1234 vs R134a, The small amount left in the hoses should not make a difference.
If I remember correctly Y1234 is a low pressure refrigerant so make sure the guages will read the pressures needed for a proper charge and go to town.
Re: AC guages, use 134A for R1234yf? [Re: IMGTX] #3193033
11/24/23 01:54 PM
11/24/23 01:54 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
OMG Say it ain't so 🀣🀣πŸ€ͺπŸ€ͺ🀣🀣🍻
the ethanol deal is another whistling
one other important detail, they reccommend KY for the orings as they say it slips in easier whistling
Thanks for the response as I have wondered myself up
Re: AC guages, use 134A for R1234yf? [Re: TJP] #3193056
11/24/23 04:04 PM
11/24/23 04:04 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Originally Posted by TJP
one other important detail, they recommend KY for the o rings as they say it slips in easier whistling
Also works well for installing windows. Always gets looks for the clerks when a 70+ male is buying multiple tubes.
Re: AC guages, use 134A for R1234yf? [Re: 6PakBee] #3193060
11/24/23 04:32 PM
11/24/23 04:32 PM
hooziewhatsit Offline
I think I'd mostly be concerned about any residual oil in the lines, since they're probably different and incompatible? But even that should be negligible.
Nylog blue works well for o-rings.
After you weigh it in, close the red valve at the engine, then slowly let any freon in the red hose into the blue hose, and back into the system. Then you won't lose the high pressure freon, and your weights won't be off twocents
Re: AC guages, use 134A for R1234yf? [Re: 6PakBee] #3193129
11/24/23 11:36 PM
11/24/23 11:36 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
LOL Grab some Viagra or other enhancing product to really get them wondering 🀣🍻
Re: AC guages, use 134A for R1234yf? [Re: hooziewhatsit] #3193162
11/25/23 09:50 AM
11/25/23 09:50 AM
Not understanding the above, gauge instructions say to never open high side during charge, Freon is sucked in low side?
I agree this is a money grab, this β€œnew” crap is $50/can compared to $10 for the R134.
From what I read a lot of people purge the new stuff and fill system with R134.
Servicing the β€œnew” system is $500 or more compared to $200.
Re: AC guages, use 134A for R1234yf? [Re: BDW] #3193192
11/25/23 11:59 AM
11/25/23 11:59 AM
IMGTX Offline
IMGTX  Offline
There are 4 valves on modern hoses.
Two at the hose ends and two on the guages.
When charging you open the hose end valves and the low pressure / blue valve on the guages.
Closing the high / red hose end traps high pressure gas in the red hose.
Opening the red / high valve on the guage let's the high pressure feed over to the low side.
I usually just close them all and hang the hoses because I feel that little bit is not a big deal. But its those little things like that that make a difference in so many things so it isn't a bad idea.
Re: AC guages, use 134A for R1234yf? [Re: TJP] #3193230
11/25/23 03:10 PM
11/25/23 03:10 PM
moparx Offline
moparx  Offline
especially if you are like me, and wobble bad using a cane. laugh2
being accompanied by a 20 something hotty would really be a plus ! boogie
beer
Re: AC guages, use 134A for R1234yf? [Re: moparx] #3193297
11/25/23 09:29 PM
11/25/23 09:29 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
beer
