Don't open this with a closed mind #3191556
11/17/23 09:30 AM
11/17/23 09:30 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Being I don't want to waste your time or challenge your beliefs of thinking outside the box.
So here goes.
Ever notice how a "one legged" burn out left on the street is almost always perfectly straight?
Notice how few posi/locked rear burn outs are equally as straight?
Ever pushed sideways on the rear of a car while doing a low-speed burn out, and learn how easy it is to move the car sideways?
Ever hear how proud racers are of how straight their car leaves while accelerating and the effort they make to achieve that result?
My assumption here is it takes very little rear sideways grip and/or force to keep a car going straight under heavy acceleration.
Would not the simple addition of a free rolling lightly suspended non steerable fairly narrow rear middle mounted tire slightly behind the rear axle achieve the sought after directional stability so cherished?
Of course, likely is 100% illegal in sanctioned racing,
Maybe it could be deployable at speeds say under 30mph when throttle reaches 100% or wheel spin occurs?
Re: Don't open this with a closed mind [Re: jcc] #3191576
11/17/23 11:21 AM
11/17/23 11:21 AM
Kirkland, Washington
Pacnorthcuda Offline
I get what you’re saying. The wheel would have to have some weight on it of course, maybe not too much though. It would be an interesting experiement.
Re: Don't open this with a closed mind [Re: Pacnorthcuda] #3191604
11/17/23 01:51 PM
11/17/23 01:51 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Or just run FWD
Re: Don't open this with a closed mind [Re: Sniper] #3191607
11/17/23 01:58 PM
11/17/23 01:58 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Or burn out in reverse?
Re: Don't open this with a closed mind [Re: jcc] #3192504
11/21/23 07:38 PM
11/21/23 07:38 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
I get what you’re laying down, I think wheelie bars do exactly what you are describing drive
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Don't open this with a closed mind [Re: metallicareload] #3192520
11/21/23 09:59 PM
11/21/23 09:59 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Not sure I can argue that statement, except, is that their intent, since they are named "wheelie bars" for a reason or just a seldom mentioned benefit?
I wonder how much grip they have to reduce side slip with the normal small and hard wheel, but granted they do at times have a lot of weight on them to gain traction, helped by their lever arm mounting.
Re: Don't open this with a closed mind [Re: jcc] #3192725
11/22/23 09:08 PM
11/22/23 09:08 PM
ohio
ruderunner Offline
ruderunner  Offline
ohio
Don't forget the physics in having the wheelies behind the drive tires. That's very similar to what you proposed.
Angry white pureblood male
Re: Don't open this with a closed mind [Re: jcc] #3193139
11/25/23 12:37 AM
11/25/23 12:37 AM
IMGTX Offline
IMGTX  Offline
My first thought was this.
Totally not what you were thinking about though or even useful when moving forward.
https://youtu.be/ki9otMeiRP0?si=VkegMHgGh1OVfrMs
Re: Don't open this with a closed mind [Re: IMGTX] #3193146
11/25/23 02:03 AM
11/25/23 02:03 AM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Never the less, that was cool.
Re: Don't open this with a closed mind [Re: jcc] #3201214
12/31/23 06:26 PM
12/31/23 06:26 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
work The third wheel wouldn't even need to be driven to be effective. Wouldn't its purpose only be to keep the rear tires from moving left or right.
Great observation and discussing topic jcc. up
My Monster are real!
Living within your means makes life pretty easy.
Re: Don't open this with a closed mind [Re: jcc] #3201215
12/31/23 06:29 PM
12/31/23 06:29 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
In addition. Front wheel drive cars, with a posi, seldom do burnouts that are not in a straight line.
So is it a weight thing? pulling instead of pushing.
Re: Don't open this with a closed mind [Re: 67vertman] #3201248
12/31/23 09:48 PM
12/31/23 09:48 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
My first guess is the driver can add minor correction steering inputs directly into the wheels that have lost direction control, which can't be done on RWD FS cars?
I don't know.
Re: Don't open this with a closed mind [Re: jcc] #3201770
01/02/24 06:36 PM
01/02/24 06:36 PM
MarkZ Offline
Worthy
MarkZ  Offline
Worthy
So here goes.
Not saying it couldn't work, but why? This type of behavior can be tuned out of the suspension with a lot simpler, already in use designs. A pair of Cal Tracks fixed this issue for my Dad's car after a couple of runs and adjustments. Car tracks true on the street now instead of going squirrelly. Modern traction control does the same.
Re: Don't open this with a closed mind [Re: MarkZ] #3201817
01/02/24 09:16 PM
01/02/24 09:16 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
Definitely have noticed sure grip rear gives a lot of "oversteer" and one tire fryer tracks straight. Always figured it's because one wheel of the axle is still tracking versus neither.
Facts are stubborn things.
Re: Don't open this with a closed mind [Re: larrymopar360] #3201821
01/02/24 09:37 PM
01/02/24 09:37 PM
Star Idaho
67vertman Offline
67vertman  Offline
Star Idaho
From CalTracs Website.....Calvert Racing’s patented CalTracs combines the best of both systems. It connects from the rear axle to a triangular-shaped bracket mounted to the front leaf spring eyelet. The lower hole in this triangle bracket attaches to the new bar, the center hole is aligned with the leaf spring eyelet and the top hole has a pin through it that will ride on top of the leaf spring pack. As you throttle, the axle will have a tendency to wrap, which will push the Calvert Force Transfer Link forward. The pivot at the front leaf eyelet then forces the pin riding on top of the springs downward into the spring pack itself. This downward force of the pin on the leaf springs causes down force on the entire axle assembly and pushes your tires down onto the pavement/dirt. The harder you’re on the throttle, the harder the downward force on your tires.
Re: Don't open this with a closed mind [Re: MarkZ] #3202117
01/03/24 11:40 PM
01/03/24 11:40 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
Modern traction control; I understood applies brakes on any single wheel needed to maintain directional control, and IMO applying any brakes when trying to accelerate is seldom the fastest solution.
A few years back I clearly remember a big fancy Mercedes driven by a low skill driver would often give off nice short puffs of black brake dust as the driver accelerated out of the road track corners at Daytona. Kept him on the track, but not sure that was the fastest track outcome for the car.
Re: Don't open this with a closed mind [Re: jcc] #3202534
01/05/24 05:27 PM
01/05/24 05:27 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Watch the Lucid Sapphire Youtube video on the Engineering Explained channel. Lots of interesting tech there.
'63 Dodge 330
11.19 @ 121 mph
Re: Don't open this with a closed mind [Re: GY3] #3208180
01/25/24 09:16 PM
01/25/24 09:16 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
The car goes sideways because the load on the rear tires isn't equal. Ever wonder why the right tire is always the one that spins on a one wheel peal? For every action there is an equal oposite reaction. Engine rotational torque causes the body to go down on the right. This forces the axle up into the wheel well. Less load on the right allows it to spin. Now with a suregrip the right still has less load. The left has more traction. This drives the car to the right. Not metion most cars are drivers side heavy which adds to the problem. Get the load adjusted on the rear tires and it'll go straight.
Doug
Re: Don't open this with a closed mind [Re: dvw] #3208194
01/25/24 10:57 PM
01/25/24 10:57 PM
Bitopia
jcc Offline OP
jcc  Offline OP
Bitopia
What you seem IMO to be overlooking, is when both tires are spinning. I mentioned it in my opening observation a car sitting while in a burnout, is extremely easy push sideways by hand with very little effort, no matter which tire is more loaded, as long as both tires are spinning,
I also think the open axle single tire perfect straight burnout line proves my contention rather well.
Whatever, this was just a lighthearted mind experiment question.
Re: Don't open this with a closed mind [Re: jcc] #3228792
04/23/24 03:22 PM
04/23/24 03:22 PM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
The Camaro SS 1LE has (had, no longer made) an electric rear diff purposely for road racing. It would switch to open when turning and snap back to posi when acceleratingout of the corner
