Don't open this with a closed mind
#3191556
11/17/23 09:30 AM
11/17/23 09:30 AM
Posts: 22,696 Bitopia
jcc
Bitopia
Being I don't want to waste your time or challenge your beliefs of thinking outside the box.
So here goes.
Ever notice how a "one legged" burn out left on the street is almost always perfectly straight?
Notice how few posi/locked rear burn outs are equally as straight?
Ever pushed sideways on the rear of a car while doing a low-speed burn out, and learn how easy it is to move the car sideways?
Ever hear how proud racers are of how straight their car leaves while accelerating and the effort they make to achieve that result?
My assumption here is it takes very little rear sideways grip and/or force to keep a car going straight under heavy acceleration.
Would not the simple addition of a free rolling lightly suspended non steerable fairly narrow rear middle mounted tire slightly behind the rear axle achieve the sought after directional stability so cherished?
Of course, likely is 100% illegal in sanctioned racing,
Maybe it could be deployable at speeds say under 30mph when throttle reaches 100% or wheel spin occurs?
Re: Don't open this with a closed mind
[Re: jcc]
#3192504
11/21/23 07:38 PM
11/21/23 07:38 PM
Posts: 270 Anchorage, Alaska
metallicareload
Anchorage, Alaska
…. Would not the simple addition of a free rolling lightly suspended non steerable fairly narrow rear middle mounted tire slightly behind the rear axle achieve the sought after directional stability so cherished?
Maybe it could be deployable at speeds say under 30mph when throttle reaches 100% or wheel spin occurs? I get what you’re laying down, I think wheelie bars do exactly what you are describing
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: metallicareload]
#3192520
11/21/23 09:59 PM
11/21/23 09:59 PM
jcc
Bitopia
Not sure I can argue that statement, except, is that their intent, since they are named "wheelie bars" for a reason or just a seldom mentioned benefit? I wonder how much grip they have to reduce side slip with the normal small and hard wheel, but granted they do at times have a lot of weight on them to gain traction, helped by their lever arm mounting.
[Re: jcc]
#3192725
11/22/23 09:08 PM
11/22/23 09:08 PM
Posts: 5,816 ohio
ruderunner
ohio
Don't forget the physics in having the wheelies behind the drive tires. That's very similar to what you proposed.
Angry white pureblood male
[Re: IMGTX]
#3193146
11/25/23 02:03 AM
11/25/23 02:03 AM
jcc
Bitopia
Never the less, that was cool.
[Re: jcc]
#3201215
12/31/23 06:29 PM
12/31/23 06:29 PM
Posts: 4,748 Star Idaho
67vertman
Star Idaho
In addition. Front wheel drive cars, with a posi, seldom do burnouts that are not in a straight line.
So is it a weight thing? pulling instead of pushing.
My Monster are real!
Living within your means makes life pretty easy.
[Re: 67vertman]
#3201248
12/31/23 09:48 PM
12/31/23 09:48 PM
jcc
Bitopia
My first guess is the driver can add minor correction steering inputs directly into the wheels that have lost direction control, which can't be done on RWD FS cars? I don't know.
[Re: jcc]
#3201770
01/02/24 06:36 PM
01/02/24 06:36 PM
Posts: 4,406 Michigan
MarkZ
Worthy
Worthy
So here goes.
Maybe it could be deployable at speeds say under 30mph when throttle reaches 100% or wheel spin occurs? Not saying it couldn't work, but why? This type of behavior can be tuned out of the suspension with a lot simpler, already in use designs. A pair of Cal Tracks fixed this issue for my Dad's car after a couple of runs and adjustments. Car tracks true on the street now instead of going squirrelly. Modern traction control does the same.
[Re: MarkZ]
#3201817
01/02/24 09:16 PM
01/02/24 09:16 PM
Posts: 15,869 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
Definitely have noticed sure grip rear gives a lot of "oversteer" and one tire fryer tracks straight. Always figured it's because one wheel of the axle is still tracking versus neither.
Facts are stubborn things.
[Re: larrymopar360]
#3201821
01/02/24 09:37 PM
01/02/24 09:37 PM
67vertman
Star Idaho
From CalTracs Website.....Calvert Racing’s patented CalTracs combines the best of both systems. It connects from the rear axle to a triangular-shaped bracket mounted to the front leaf spring eyelet. The lower hole in this triangle bracket attaches to the new bar, the center hole is aligned with the leaf spring eyelet and the top hole has a pin through it that will ride on top of the leaf spring pack. As you throttle, the axle will have a tendency to wrap, which will push the Calvert Force Transfer Link forward. The pivot at the front leaf eyelet then forces the pin riding on top of the springs downward into the spring pack itself. This downward force of the pin on the leaf springs causes down force on the entire axle assembly and pushes your tires down onto the pavement/dirt. The harder you’re on the throttle, the harder the downward force on your tires.
[Re: MarkZ]
#3202117
01/03/24 11:40 PM
01/03/24 11:40 PM
jcc
Bitopia
Modern traction control; I understood applies brakes on any single wheel needed to maintain directional control, and IMO applying any brakes when trying to accelerate is seldom the fastest solution. A few years back I clearly remember a big fancy Mercedes driven by a low skill driver would often give off nice short puffs of black brake dust as the driver accelerated out of the road track corners at Daytona. Kept him on the track, but not sure that was the fastest track outcome for the car.
[Re: jcc]
#3202534
01/05/24 05:27 PM
01/05/24 05:27 PM
Posts: 4,672 Wichita
GY3
Wichita
Watch the Lucid Sapphire Youtube video on the Engineering Explained channel. Lots of interesting tech there.
[Re: dvw]
#3208194
01/25/24 10:57 PM
01/25/24 10:57 PM
jcc
Bitopia
What you seem IMO to be overlooking, is when both tires are spinning. I mentioned it in my opening observation a car sitting while in a burnout, is extremely easy push sideways by hand with very little effort, no matter which tire is more loaded, as long as both tires are spinning, I also think the open axle single tire perfect straight burnout line proves my contention rather well. Whatever, this was just a lighthearted mind experiment question.
[Re: Pacnorthcuda]
#3229026
04/24/24 09:47 PM
04/24/24 09:47 PM
jcc
Bitopia
So do inline (V8) powered motorcycles have that same torque reaction? A transverse motor orientation is the ideal I suppose.
