Re: Emergency brake handle removal
[Re: Neil]
#3191243
11/15/23 08:52 PM
11/15/23 08:52 PM
MoreParts
I've done it pretty easily in car without having to remove the assembly with a roll pin remover like this.
[Re: MoreParts]
#3191351
11/16/23 12:56 PM
11/16/23 12:56 PM
Posts: 737 Michigan
BlueRacer69
I've done it pretty easily in car without having to remove the assembly with a roll pin remover like this. Hey MoreParts where can I get one of those tools?
[Re: BlueRacer69]
#3191360
11/16/23 01:18 PM
11/16/23 01:18 PM
MoreParts
I've done it pretty easily in car without having to remove the assembly with a roll pin remover like this. Hey MoreParts where can I get one of those tools? There are some on ebay right now. Here's about the cheapest. And here's the part number if you want to check other sources. EZ RED PPT13 Pin Remover https://www.ebay.com/itm/385029128267?epid=1200170799&hash=item59a586404b:g:lpYAAOSwX2pfmbn7&amdata=enc%3AAQAIAAAA4HCT8ehaqxylrx%2FYK%2FR8sTdidx0hxuU5l79eFP6RIlTNsDC5bzTpKlVwP8CHd7aAET8nzMeg4gvE1TquxcLA2w6kvgkGn2VtSi%2FOejynxa7umC8pAuK1zV%2BIJj7VgEwqlyLp%2FYJCMlNJYLS4PISe9rUOvkQMgTArhg8sLV4jCgTtHZ0ilPCLdjFNbE8XtmVsseNSo6rBUI0m8LrEQ4yaA5fUPLJ4cBFGg9HORAOM%2FBQ1L%2BCNhssriBW2%2Bi4BOW%2BACtKKvw3JGO7HeislgUd206iYaQ%2Fj5N2Q2GzsOXWF23Zt%7Ctkp%3ABk9SR7D4lpL7Yg
[Re: BDW]
#3191443
11/16/23 07:47 PM
11/16/23 07:47 PM
MoreParts
That looks interesting, but it only does 1 size? Seems like it would be a better design if it had different size inserts?
Wouldn't work on the steering coupler? Nope. It'll just do standard size roll pins.
[Re: TJP]
#3191618
11/17/23 02:54 PM
11/17/23 02:54 PM
Posts: 19,629 north of coder
moparx
Wouldn't work on the steering coupler? Nope. It'll just do standard size roll pins. not trying to be a D-ck but Roll pins come in many sizes and lengths. I agree with the different size insert idea. i also agree with the different size inserts idea. also, when using a standard flat face punch instead of a roll pin punch, the flat nose punch used will be just a whisker smaller than the roll pin, causing the punch to insert itself into the pin, which results in untold aggravation while trying to remove said pin. however, learning "new words" and expressing them in the process, can be greatly "educational" to young minds if they are within earshot. ![biggrin biggrin](/ubbthreads/images/graemlins/custom/biggrin.gif) a couple different size roll pin punch sets are well worth the money spent, even if a guy only uses a few different ones over his lifetime. ![beer beer](/ubbthreads/images/graemlins/custom/beer.gif)
