Emergency brake handle removal #3191219
11/15/23 07:38 PM
11/15/23 07:38 PM
BlueRacer69 Offline OP
Hello guys. Got a question. How the heck does the emergency brake handle come off. Just the handle itself. It's a 69 A body and my handle is busted. Would like to replace it but can't get the old one off. Thanks.
Re: Emergency brake handle removal [Re: BlueRacer69] #3191231
11/15/23 08:19 PM
11/15/23 08:19 PM
Eagle, Idaho
Neil Offline
The Doctor is in.
Neil  Offline
The Doctor is in.
Eagle, Idaho
Don't those have a roll pin that goes thru the T handle thru the steel shaft? Roll pins come out with a small punch and a hammer.
Make sure the punch is not so big that it gets caught in the hole as the roll pin is being driven out. You can use a nail that is just slightly smaller than the poll pin OD to tap in thru I suppose.
Re: Emergency brake handle removal [Re: Neil] #3191243
11/15/23 08:52 PM
11/15/23 08:52 PM
MoreParts Offline
MoreParts  Offline
I've done it pretty easily in car without having to remove the assembly with a roll pin remover like this.
Re: Emergency brake handle removal [Re: Neil] #3191348
11/16/23 12:54 PM
11/16/23 12:54 PM
Hey Neil, thanks for that info.
Re: Emergency brake handle removal [Re: MoreParts] #3191351
11/16/23 12:56 PM
11/16/23 12:56 PM
Hey MoreParts where can I get one of those tools?
Re: Emergency brake handle removal [Re: Neil] #3191356
11/16/23 01:07 PM
11/16/23 01:07 PM
iagree hammer wrench up scope
Re: Emergency brake handle removal [Re: BlueRacer69] #3191360
11/16/23 01:18 PM
11/16/23 01:18 PM
MoreParts Offline
MoreParts  Offline
There are some on ebay right now. Here's about the cheapest.
And here's the part number if you want to check other sources. EZ RED PPT13 Pin Remover
https://www.ebay.com/itm/385029128267?epid=1200170799&hash=item59a586404b:g:lpYAAOSwX2pfmbn7&amdata=enc%3AAQAIAAAA4HCT8ehaqxylrx%2FYK%2FR8sTdidx0hxuU5l79eFP6RIlTNsDC5bzTpKlVwP8CHd7aAET8nzMeg4gvE1TquxcLA2w6kvgkGn2VtSi%2FOejynxa7umC8pAuK1zV%2BIJj7VgEwqlyLp%2FYJCMlNJYLS4PISe9rUOvkQMgTArhg8sLV4jCgTtHZ0ilPCLdjFNbE8XtmVsseNSo6rBUI0m8LrEQ4yaA5fUPLJ4cBFGg9HORAOM%2FBQ1L%2BCNhssriBW2%2Bi4BOW%2BACtKKvw3JGO7HeislgUd206iYaQ%2Fj5N2Q2GzsOXWF23Zt%7Ctkp%3ABk9SR7D4lpL7Yg
Re: Emergency brake handle removal [Re: MoreParts] #3191362
11/16/23 01:21 PM
11/16/23 01:21 PM
moparx Offline
moparx  Offline
Re: Emergency brake handle removal [Re: moparx] #3191435
11/16/23 07:26 PM
11/16/23 07:26 PM
BDW Offline
BDW  Offline
That looks interesting, but it only does 1 size?
Seems like it would be a better design if it had different size inserts?
Wouldn't work on the steering coupler?
Re: Emergency brake handle removal [Re: BDW] #3191443
11/16/23 07:47 PM
11/16/23 07:47 PM
MoreParts Offline
MoreParts  Offline
Nope. It'll just do standard size roll pins.
Re: Emergency brake handle removal [Re: MoreParts] #3191500
11/16/23 10:45 PM
11/16/23 10:45 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
not trying to be a D-ck but Roll pins come in many sizes and lengths. I agree with the different size insert idea. up beer
Re: Emergency brake handle removal [Re: TJP] #3191533
11/17/23 05:30 AM
11/17/23 05:30 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
The specialized tool is well worth the money,
but it was inspired by
a large C clamp and
a standard pin punch
Re: Emergency brake handle removal [Re: TJP] #3191618
11/17/23 02:54 PM
11/17/23 02:54 PM
moparx Offline
moparx  Offline
i also agree with the different size inserts idea.
also, when using a standard flat face punch instead of a roll pin punch, the flat nose punch used will be just a whisker smaller than the roll pin, causing the punch to insert itself into the pin, which results in untold aggravation while trying to remove said pin. however, learning "new words" and expressing them in the process, can be greatly "educational" to young minds if they are within earshot. biggrin
a couple different size roll pin punch sets are well worth the money spent, even if a guy only uses a few different ones over his lifetime.
beer
