Muncie question - Kicks out of 3rd gear #3190339
11/11/23 10:14 PM
11/11/23 10:14 PM
Tucson AZ,
MadMopars Offline OP
Tucson AZ,
Hey guys, not necessarily a Mopar question but if it helps it's hooked to a Dana so maybe it can be asked here.. That being said, my father in law has a Muncie that kicks out of 3rd gear after about 4000 RPM. Doesn't matter how hard you try to hold the shifter, it'll kick out. He's swapped shifters, shift rods, shift levers and adjusted things multiple times with no real improvement. I've got a couple thoughts on what it may be but am not an expert by any means so I figured I would inquire here as to what the experts may think the problem may be. Hoping to get this resolved soon without sacrificing another 833 input shaft so I appreciate any help. wink Thanks guys!
For what it's worth, it does have a Supercase if that matters...
[img]https://s9.postimg.cc/6fbjxzfvv/48-2016-_Drag-_Weekend-_Best-_Burnouts-lpr.jpg[/img]
73 GTX *440*727*8 3/4*
69 DART GT *440*4 SPEED*DANA*
73 ROAD RUNNER *451*4 SPEED*DANA*
64 F100 *383*4 SPEED*9"*
75 DODGE D300 *440*4 SPEED*DANA*
99 DODGE RAM 3500 4X4 DUALLY... ON 38"s
Re: Muncie question - Kicks out of 3rd gear [Re: MadMopars] #3190366
11/12/23 04:02 AM
11/12/23 04:02 AM
Minnesota
Hemi_Joel Online content
Hemi_Joel  Online Content
Minnesota
Has the bellhousing been indicated in to concentricity with the crankshaft? Have the engagement teeth on 3rd gear and the internal splines on the slider been checked for rounding/wear/damage? I'd start by pulling the side cover and inspecting the teeth, that's the easiest.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Muncie question - Kicks out of 3rd gear [Re: Hemi_Joel] #3190403
11/12/23 11:27 AM
11/12/23 11:27 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Well, he does have a Dana, but the Chevy forums or something like the Yellow Bullet are probably a much more effective place to find an answer about Muncie transmission tech, althouh there are some very knowlegable folks on this site, hence the bump.
Re: Muncie question - Kicks out of 3rd gear [Re: jbc426] #3190412
11/12/23 11:46 AM
11/12/23 11:46 AM
Minnesota
Minnesota
A transmission is a transmission. If you understand an 833, you understand a Muncie.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Muncie question - Kicks out of 3rd gear [Re: Hemi_Joel] #3190426
11/12/23 12:40 PM
11/12/23 12:40 PM
Tucson AZ,
Tucson AZ,
You may be on to something with the bellhousing. Years ago when we assembled the car, I dialed in the bellhousing with the new motor and we installed a used Muncie behind it. When measuring for the driveshaft we discovered the output shaft splines were twisted and in a rush to get the car together for Drag Weekend we stole the Muncie from his Corvette to use (worked fine). Long story short, shortly after returning from Drag Weekend he ended up pulling the clutch and the transmission back out of the car to swap in a new clutch and the previously removed damaged Muncie which he had since rebuilt. From that day forward, it's always kicked out of 3rd gear. He did make a comment about the shim stock I had put between the block and scatter sheild and I'm wondering if maybe they didn't go back as previously installed.
As I recall, the sliders and internal splines looked good when he had it apart but I can't speak to that with certainty at this point as its been quite some time. Certainly worth looking into though.
As much as I hate to do it, it's sounding like that transmission should probably come out to check that scatter sheild again. Could it really be that far out to cause this? Would it not affect any of the other gears?
Re: Muncie question - Kicks out of 3rd gear [Re: MadMopars] #3190433
11/12/23 12:54 PM
11/12/23 12:54 PM
Minnesota
Minnesota
4th is on the input shaft, 3rd is on the main shaft. Bellhousing misalignment creates misalignment between the input shaft and the main shaft and is most likely to mess up high gear or third gear.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Muncie question - Kicks out of 3rd gear [Re: Hemi_Joel] #3190438
11/12/23 12:59 PM
11/12/23 12:59 PM
Canada
RobR Offline
RobR  Offline
Canada
The 3-4 hub and slider are worn out,that's why it is jumping out of gear.
Re: Muncie question - Kicks out of 3rd gear [Re: RobR] #3190711
11/13/23 09:39 PM
11/13/23 09:39 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
Originally Posted by RobR
The 3-4 huYEP b and slider are worn out,that's why it is jumping out of gear.
Yep that is the issue. Pull trans apart the clutching teeth should have chisel sharp edges, they will be rounded over and worn.
Re: Muncie question - Kicks out of 3rd gear [Re: jwb123] #3190737
11/13/23 11:26 PM
11/13/23 11:26 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
Synchro rings ?
Re: Muncie question - Kicks out of 3rd gear [Re: RobR] #3190746
11/14/23 02:42 AM
11/14/23 02:42 AM
Does that year Muncie have rooster combs shift levers for the shift rods or scissor type ?
If rooster combs have him check the check ball bearing engagement compared to e 1/2 lever engagement and rooster comb wear wrench scope up
Let us know wat you find please luck
Re: Muncie question - Kicks out of 3rd gear [Re: Cab_Burge] #3190754
11/14/23 07:21 AM
11/14/23 07:21 AM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
The best thing about a Muncie, is they are fairly light, making it easier to toss it into a dumpster.
69 GTX 68 Road Runner
Re: Muncie question - Kicks out of 3rd gear [Re: Cab_Burge] #3190813
11/14/23 12:42 PM
11/14/23 12:42 PM
Tucson AZ,
Tucson AZ,
The transmission will be coming out hopefully in the next week or two. We decided to make a last minute go at the Power Tour West in my GTX so the 442 will be 2nd on the priority list for a bit while I get the GTX prepped. I appreciate the input though and will be sure to report back with our findings as soon as we get it pulled. Thanks to all. up -Trent
Re: Muncie question - Kicks out of 3rd gear [Re: MadMopars] #3190852
11/14/23 02:45 PM
11/14/23 02:45 PM
Minnesota
Minnesota
Man, I REALLY want to do that power tour west. But we have a family Christmas party that weekend so I can't.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Muncie question - Kicks out of 3rd gear [Re: Hemi_Joel] #3191002
11/15/23 01:06 AM
11/15/23 01:06 AM
Tucson AZ,
Tucson AZ,
That's a bummer you can't make it. Would have been great to catch up. We don't get much activity over here on the West coast but when we do I try to participate. Some day I'll make it out East to one of the bigger events but with a wife and 4 kids, building a house and now starting a new business, it's hard to even justify keeping the cars some days let alone playing with them. I think that's partly why I decided to go though. The opportunity to create some good memories with the family and to get back in the seat for even just a bit should be good for soul. Some day I'll get out East though, some day... luck
Re: Muncie question - Kicks out of 3rd gear [Re: JERICOGTX] #3191003
11/15/23 01:16 AM
11/15/23 01:16 AM
Tucson AZ,
Tucson AZ,
That's a valid point... I have an E body 833 sitting on the shelf that has a GM input shaft already installed by a previously disappointed Muncie owner. I originally planned on undoing their butchery but this may be a game changer. work
Re: Muncie question - Kicks out of 3rd gear [Re: MadMopars] #3191006
11/15/23 01:24 AM
11/15/23 01:24 AM
Minnesota
Minnesota
I tried to get the party date changed, but that went over like a pig roast at a PETA convention. I wanted to add those 3 tracks to my list, especially Pomona.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Muncie question - Kicks out of 3rd gear [Re: JERICOGTX] #3191007
11/15/23 01:28 AM
11/15/23 01:28 AM
Minnesota
Minnesota
Well, that and that they power shift like a motocross bike. After I got used to banging gears with a Muncie, the doug nash and the 833 felt like a truck trans.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Muncie question - Kicks out of 3rd gear [Re: Hemi_Joel] #3191089
11/15/23 12:52 PM
11/15/23 12:52 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My experience was also that they shifted really well until they didn't shift at all. boogie
Re: Muncie question - Kicks out of 3rd gear [Re: slantzilla] #3191119
11/15/23 02:18 PM
11/15/23 02:18 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Well, if we're talking about powershifting...over the last 50 years, I've had Toploaders, Muncies, T-10s, a T-5, a T-45, and numerous A833s in 23-spline and a couple 18-splines.
Of the bunch, the T-10 was my favorite for that; like throwing a switch.
The yardstick, as exemplified by the Greats like Ken Dondero & etc, is no RPM flare, just next gear.
The Tremecs and 833s require, for me at least, a more - shall we say - hostile attitude...
Re: Muncie question - Kicks out of 3rd gear [Re: MadMopars] #3191876
11/18/23 06:18 PM
11/18/23 06:18 PM
Tucson AZ,
Tucson AZ,
Update: Got the transmission pulled out and opened up. The teeth on the 3/4 slider don't look great and the teeth on 3rd gear don't look much better. Additionally, the slider seems to have more play on the hub than 1/2 in comparison so we placed an order for all 3 items. I can't speak with certainty as to what shape they were in when the transmission went together but will try to be investigative as it goes back together to determine if there are any other underlying issues or causes. It seemed like it didn't engage well on the bench when moving the slider into 3rd but I'll take another look when it goes back together, ultimately where the shift fork puts it. Lastly, I'm thinking we'll try to dial in that scatter shield again tomorrow with the shims that were there and see how things line up. I'm hoping it checks good. As previously said, I appreciate the input and will keep you guys posted as things progress... Thanks again! -Trent
