Cam bearing bore shot in BB, how to fix? #3190367
11/12/23 05:17 AM
11/12/23 05:17 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Hi!
Had a cam bearing failure in my Indy aluminum block. It went so bad that the block actually have melted a little in the #3 and 4 cam bearing bores, so just can't install new bearings. Others are ok. You can't get it welded either, no room for that.
So, does someone make needle bearing cams (and bearings) for a bigblock? It could be one solution to drill the cam tunnel bigger for roller bearings.
Any other ideas?
Plynouth VIP '67 TT IC EFI
Re: Cam bearing bore shot in BB, how to fix? [Re: jyrki] #3190390
11/12/23 10:05 AM
11/12/23 10:05 AM
IL
E
EchoSixMike Offline
EchoSixMike  Offline
E
IL
Go to a larger bearing, either roller or babbit or have it sleeved. S/F....Ken M
Re: Cam bearing bore shot in BB, how to fix? [Re: jyrki] #3190392
11/12/23 10:13 AM
11/12/23 10:13 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
I'm sure this guy could do it. Sorry, I don't have any contact info for him.
https://www.google.com/search?sca_esv=581711571&rlz=1C1CHBF_enCA949CA949&q=robwendland&tbm=isch&chips=q:robwendland,online_chips:block+repair:A6GdU-cpMKU%3D&usg=AI4_-kR7ymvhENoxAr-QLs51CvOJxc2WLw&sa=X&ved=2ahUKEwjKw5j70b6CAxUnHjQIHe6dC_oQgIoDKAN6BAgzEB4&biw=1024&bih=700&dpr=1.25
Re: Cam bearing bore shot in BB, how to fix? [Re: Stanton] #3190413
11/12/23 11:47 AM
11/12/23 11:47 AM
Rogue River, OR
Jeremiah Offline
Jeremiah  Offline
Rogue River, OR
Your choices are 55mm roller or 60mm babbit. I like babbit however there can be some caveats. Is the block standard cam height or +.250? I would give Indy a call in this one.
Re: Cam bearing bore shot in BB, how to fix? [Re: Stanton] #3190414
11/12/23 11:48 AM
11/12/23 11:48 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
Rob Wendland search. -> clickable Rob Wendland Google search <-
Re: Cam bearing bore shot in BB, how to fix? [Re: John Brown] #3190437
11/12/23 12:58 PM
11/12/23 12:58 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
If it were mine, I would probably attempt to sleeve it. I assume there is enough meat there for a sleeve - I would leave a slight shoulder for the sleeve to rest against. I would do it on a horizontal boring mill. Trickiest part is the setup.
Tony Bischoff (BES) is my engine builder. I would trust whatever he says. Why don't you send him an email and ask?
Re: Cam bearing bore shot in BB, how to fix? [Re: markz528] #3190445
11/12/23 02:01 PM
11/12/23 02:01 PM
AndyF Offline
AndyF  Offline
I agree, not a hard problem to fix with the correct equipment. But, it could be difficult to find a shop with that kind of equipment. It is more of an industrial type of problem than an engine repair issue.
Re: Cam bearing bore shot in BB, how to fix? [Re: AndyF] #3190449
11/12/23 02:35 PM
11/12/23 02:35 PM
Don't forget he is in Finland work
I'm wondering if you could have it spray welded shruggy or not and then have it remachine back to stock work
I agree with Jeremiah if you can have that machine work done there and buy another cam core for the bearings you use luck
I had a similar experience with a 1971 6 pack 440 motor, it spun the #4 cam bearing and cause a lot of problems getting that block fixed rant whiney shruggy Dang Mopar on using five different cam bearing sizes rant nervous mad whistling
Re: Cam bearing bore shot in BB, how to fix? [Re: Cab_Burge] #3190481
11/12/23 04:49 PM
11/12/23 04:49 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Can you find anyone with a portable line bore machine like this? 60mm cam bearings and cam cores are available. Or use it to overbore for sleeves.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Cam bearing bore shot in BB, how to fix? [Re: Hemi_Joel] #3190490
11/12/23 05:25 PM
11/12/23 05:25 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
The bore for a 60mm roller bearing is going to be 68mm from memory. A babbit bearing bore will be around 63mm. Obviously a 55mm babbit bore will be smaller, but I don't believe Cam cores to be as plentiful. If you have to replace the camshaft as well, this might be the best option??
Alternatively, you can sleeve the number 3, 4 and 5 bores to facilitate the repair. Maybe pin them with some aluminium rod to minimise the possibility of the sleeves moving.
Alan Jones
Re: Cam bearing bore shot in BB, how to fix? [Re: Cab_Burge] #3190545
11/12/23 10:57 PM
11/12/23 10:57 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
Finland????? LOL!
I know - he was kind enough to give me a beer when I visited him........ Got nothing but the highest respect for what they do.
Re: Cam bearing bore shot in BB, how to fix? [Re: Hemi_Joel] #3190563
11/13/23 04:33 AM
11/13/23 04:33 AM
I'm wondering how many people on here recognize what era, years and brand block that pictures is of work whistling grin
Hint it isn't recent and it is not a Mopar brand block grin
Re: Cam bearing bore shot in BB, how to fix? [Re: Cab_Burge] #3190564
11/13/23 05:04 AM
11/13/23 05:04 AM
LA360 Offline
LA360  Offline
A favourite of a lot of early Hot Rodders!
Alan Jones
Re: Cam bearing bore shot in BB, how to fix? [Re: LA360] #3190573
11/13/23 09:13 AM
11/13/23 09:13 AM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Yes, the cam is shot too, so have to get new one or two anyway. So,only the available cam core is the limit for the cam bearings that will be used.
Re: Cam bearing bore shot in BB, how to fix? [Re: jyrki] #3190608
11/13/23 01:26 PM
11/13/23 01:26 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
My KB blocks didn't have cam bearings (other than the bores that had been repaired) , ran on the machined block material. An option may be to open the bores and have straight aluminum bushings pressed in and re line hone. Tap the feed hole(s) in the block, then drill out a dog point set screw as an anti rotation pin. twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Cam bearing bore shot in BB, how to fix? [Re: LA360] #3190836
11/14/23 02:01 PM
11/14/23 02:01 PM
moparx Offline
moparx  Offline
ford flathead, 8BA block maybe ?
beer
Re: Cam bearing bore shot in BB, how to fix? [Re: moparx] #3190849
11/14/23 02:42 PM
11/14/23 02:42 PM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
Close. It's a Lincoln 337 flathead. Basically a big block version of the Ford flathead. up
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Cam bearing bore shot in BB, how to fix? [Re: moparx] #3190895
11/14/23 05:40 PM
11/14/23 05:40 PM
beer
8 AB maybe confused work I can't tell without seeing the top of the motor to see if it had a cam driven distributors on the front of the motor or the later top mounted distributor and I don't know how to tell the differences visibly between the Ford and Mercury blocks, let alone the bigger Lincoln blocks shruggy
I started getting interested in cars in the later 1950s, I especially liked the 1958 Chevy Impalas, still do up boogie
Re: Cam bearing bore shot in BB, how to fix? [Re: LA360] #3191599
11/17/23 01:21 PM
11/17/23 01:21 PM
Finalnd, Perkele
jyrki Offline OP
jyrki  Offline OP
Finalnd, Perkele
Seems that the camcores for BB rollerbearings is next to impossible to find. So far one offer for 54mm bearings, 1500$.
Re: Cam bearing bore shot in BB, how to fix? [Re: jyrki] #3191626
11/17/23 03:35 PM
11/17/23 03:35 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
The direction I’d be leaning would be to bore & sleeve the two bad cam bores back to the original sizes.
