Soaping slicks #3190646
11/13/23 04:24 PM
11/13/23 04:24 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
Going to be mounting new slicks in the next week or two. Tubeless, of course, and I was wondering if the practice of soaping the inside really makes a difference in how well they hold air. I know it will matter to some, the tires are Phoenix brand 14 x 32 - 15. Thank you for any input. bow
Re: Soaping slicks [Re: cagebob1] #3190648
11/13/23 04:31 PM
11/13/23 04:31 PM
Richmond, Indiana
19swinger70 Offline
19swinger70  Offline
Richmond, Indiana
I soap my tires when I mount them. Do I have some kind of scientific evidence that it makes a difference - no.
My perception is that it helps the bead seat and seal, and I mount all my own stuff for the classic and race cars I have now.
1970 340 swinger. sublime
1967 barracuda fastback BB
55 Plymouth Project
Re: Soaping slicks [Re: 19swinger70] #3190650
11/13/23 04:36 PM
11/13/23 04:36 PM
Mesa, AZ
cagebob1 Offline OP
cagebob1  Offline OP
Mesa, AZ
I also use a soap solution when mounting tires. Specifically, I was referring to the practice of coating the inside with dish soap to reduce air loss thru the sidewalls. bow
Re: Soaping slicks [Re: cagebob1] #3190659
11/13/23 05:04 PM
11/13/23 05:04 PM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
I use baby oil on the inside of the tire to keep the sidewalls from leaking air if no tubes are going to be used. If tubes are to be used, then corn starch to keep from pinching the tubes when the tires wrinkle on launch.
Re: Soaping slicks [Re: jwb123] #3190688
11/13/23 07:34 PM
11/13/23 07:34 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Dawn dish soap helps for sure. Glop it on inner side walls while laying flat. Let it dry a bit. Then flip the tires over and do the other sides. M/T 's will leak badly w/o soap. I've had them only lose 5-6 lbs setting over the winter with this method.
Doug
Re: Soaping slicks [Re: dvw] #3190703
11/13/23 08:40 PM
11/13/23 08:40 PM
MO.
CROWBAR Offline
CROWBAR  Offline
MO.
Dawn liquid here as well Definitely part of the new slick routine RC
Re: Soaping slicks [Re: jwb123] #3190728
11/13/23 11:07 PM
11/13/23 11:07 PM
Baby powder works well also to seal the tubeless slicks as well as with tubes, I use a soapy solution on the beads when mounting them here at home on my old manual tire machine, I inflate them to the same circumstance + or -1/4 inch circumference on the O.D. measure in the middle of the tires, inflate them above 15.0 Lb. up to 25.0 Lb. to make them as large as a I can on the O.D. for 3 to 5 days before racing them at the lower race pressures up scope
Re: Soaping slicks [Re: cagebob1] #3190776
11/14/23 09:20 AM
11/14/23 09:20 AM
Minn
SportF Offline
SportF  Offline
Minn
I used to really soap mine down, now I don't. The results for me is exactly the same. Radials or bias. I kept a big paint brush and bought Palmolive by the 64 oz jug to do this.
Re: Soaping slicks [Re: SportF] #3190827
11/14/23 01:30 PM
11/14/23 01:30 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
Tubeless get soaped here...doesn't stop them from airing down but greatly lengthens the time - From days to months.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Soaping slicks [Re: cagebob1] #3191258
11/15/23 09:30 PM
11/15/23 09:30 PM
western PA
stevet340 Offline
stevet340  Offline
western PA
Murphy's oil soap works great on tubeless slicks.
Re: Soaping slicks [Re: stevet340] #3191678
11/17/23 09:22 PM
11/17/23 09:22 PM
S.E. Michigan
cl440 Offline
cl440  Offline
S.E. Michigan
We Dawn dish soap ours a night or two before we take them to be mounted and then let the person mounting them soap them up again. They hold air really well that way.
Re: Soaping slicks [Re: cagebob1] #3192355
11/21/23 07:30 AM
11/21/23 07:30 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
If you have to soap a tire so it holds air, the tire is defective. If you buy a brand that needs soaped every time, you're buying a defective brand.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
